harrykheepal
Re: Is coil whine a serious issue with the ftw and sc cards?
2016/08/08 15:54:18
Yeah you need 2 8pins, so 2 6+2's should be good.
Adger
2016/08/08 16:55:04
Thanks Harrykheepal Appreciated mate.
post edited by Adger - 2016/08/08 17:40:32
My Affiliate Code: 0AXK9S2R5X My 1st EVGA product..it certainly wont be my last
DarkStarchild
2016/08/08 21:29:07
Hi Adger, I've had the graphics card for almost 2 weeks now, I think I have 28 days to return it to Ebuyer. I had originaly a 1080 ftw on order from Amazon but they still haven't had it in stock yet and I'd been waiting almost 2 months so I got fed up and ordered a 1070 ftw from ebuyer instead. I had been hoping Amazon would get the 1080 ftw sent out to me soon and perhaps it would have had less coil whine but no luck yet and I'm running out of time to return the 1070 to Ebuyer. I'm not sure about returning it as I'm worried I might get a card with worse coil whine and/ or other issues (Everything is pretty much fine except for the electric buzzing and coil whine) People on here say they get coil whine but they don't say if this still happens with vsync on capped at 60fps, I wouldnt mind if I had coil whine with vsync off since I always play games with it enabled on my 60hz hdtv.
If you do get a 1070 ftw let us know how it goes :) hopefully you get a card that isn't too bad.
J0NOX
2016/08/09 13:07:53
DarkStarchild Hi Adger, I've had the graphics card for almost 2 weeks now, I think I have 28 days to return it to Ebuyer. I had originaly a 1080 ftw on order from Amazon but they still haven't had it in stock yet and I'd been waiting almost 2 months so I got fed up and ordered a 1070 ftw from ebuyer instead. I had been hoping Amazon would get the 1080 ftw sent out to me soon and perhaps it would have had less coil whine but no luck yet and I'm running out of time to return the 1070 to Ebuyer. I'm not sure about returning it as I'm worried I might get a card with worse coil whine and/ or other issues (Everything is pretty much fine except for the electric buzzing and coil whine) People on here say they get coil whine but they don't say if this still happens with vsync on capped at 60fps, I wouldnt mind if I had coil whine with vsync off since I always play games with it enabled on my 60hz hdtv.
I just got my 1080 FTW from Amazon today (dispatched on the 8th)..unfortunately my card also has the coil whine issue. Been looking around and it seems others that bought an EVGA G2 850 helped solve their coil whine issues. Going to order a G2 myself and see if it helps, if not ill be sending it back. Edit: Yes, I also get coil whine with vsync on capped at 60fps...normal desktop use its fine, only when gaming.
post edited by J0NOX - 2016/08/09 13:12:40
sethleigh
2016/08/09 13:17:41
dasa43 my 1070sc only has coil whine at high fps gets rather loud when overclocked for benchmarking but at stock clocks with 60fps cap i dont hear it may be a problem if i had a 144hz monitor I honestly couldn't tell you whether I have coil whine with my 1080 SC or not. The machine itself is watercooled, and the fans are quiet enough, but some work computers on the other side of the room make enough background noise that I've simply never noticed. Which means for me, whether I have it or not, it's irrelevant. I also always have either headphones or loud speakers on when gaming, so even if it did produce coil whine that could be heard over the fans, I'd still never hear it. I do believe people who say it can be a problem with some machines, but it's not a problem I've ever experienced, with any of my computers or video cards, ever. To the OP: enjoy your new card!
Happy EVGA customer for over 11 years and counting. Affiliate Code: 0Y7-1VU-ATW2 EVGA X99 FTW K, Intel Core i7 6900@4.2ghz/3.5ghz cache, 32gb G.Skill DDR4 3200 MHz CL14 RAM, EVGA 1080 SC w/EK water block, 1TB 850 EVO SSD, EVGA Supernova G2 850W PS, Monoprice 4K monitor, Win 10 Anniv. 64-bit
DarkStarchild
2016/08/09 15:19:28
"I just got my 1080 FTW from Amazon today (dispatched on the 8th)..unfortunately my card also has the coil whine issue. Been looking around and it seems others that bought an EVGA G2 850 helped solve their coil whine issues. Going to order a G2 myself and see if it helps, if not ill be sending it back. Edit: Yes, I also get coil whine with vsync on capped at 60fps...normal desktop use its fine, only when gaming." Hi J0NOX, That's not good to hear. Amazon have just dispatched my 1080 ftw (its arriving in a day or 2 and I will compare it with my 1070 ftw. The EVGA super nova G2 850w is the power supply that I have. My coil whine problems started when I brought and installed that power supply (changed from OCZ ModXstream) < Note that PSU does not have 2x 8pin graphics card plug recquired for 1070 / 1080 FTW. If you do get the EVGA super nova G2 850w PSU Please keep in contact and let me know how it goes with the coil whine/ electric buzzing as I'm starting to believe my PSU is making the noise worse. Sure the 10 series nvidia cards have some noise issues but maybe that PSU is making it worse. Yea my normal desktop is fine also. The noise happens when gaming at 60fps for me too (even the slightest load)
post edited by DarkStarchild - 2016/08/09 15:24:27
J0NOX
2016/08/09 15:45:43
DarkStarchild Hi J0NOX, That's not good to hear. Amazon have just dispatched my 1080 ftw (its arriving in a day or 2 and I will compare it with my 1070 ftw. The EVGA super nova G2 850w is the power supply that I have. My coil whine problems started when I brought and installed that power supply (changed from OCZ ModXstream) < Note that PSU does not have 2x 8pin graphics card plug recquired for 1070 / 1080 FTW.
Oh, so you have the EVGA supernova G2 850 PSU and still have the coil whine buzzing?...I'm feeling doubtful a new PSU will help me now. I'm going to be taking my computer down to my local computer shop tomorrow and gonna throw some things in and out to see if it makes a difference to the coil whine. Prob try putting the 1080 into one of the owners machines and see if the coil whine is still present. If all else fails and the whine is still there, ill prob be looking at getting a replacement. All in all, the luck of the draw seems to play a big part with these 1080's. I'll keep you posted once I know more.
J0NOX
2016/08/09 16:59:58
Ok so I got a helpful reply back from the Evga team about the coil issue. Basically saying "Coil whine is common throughout all electronic devices, the causes of it can be affected by many different variables. It is not something that determines whether or not a product is going to be faulty. It is just an indication there is a current going through your component. One possible solution is to leave a benchmarking program like Heaven Benchmark 4.0 on overnight. This has helped some people but it may not work for you." As suggested i tried a burn-in-test to see if it would get rid of the noise. I left the benchmark on for only 30min (was running around 150-300fps) and then I decided to cap it to 60 and leave it on...soon as I went to 60fps vsync the coil was hardly noticeable. As i mentioned before the coil was happening at 60fps but it seems maybe the burn in technique might have helped out in my case. There is still a lot of noticeable buzzing @ 80-100fps, my last card was a Asus 970oc and that didn't make any noise when fps was high during any benchmarking software I used (Valley Benchmark + Heaven), I'm still going to see if another PSU will improve things.
post edited by J0NOX - 2016/08/09 17:08:08
DeathSOA
2016/08/09 18:47:51
My 1070 sc has coil whine, only with vsync off though, with vsync on it seems to not whine much at all. It's more like a buzzing noise not really a high pitched whine type noise. Have a EVGA G2 750w psu that I literally just got not long ago. Seems it's really 50/50 like others have said. Have tried burning it in with valley benchmark for about 7 or 8 hours, didn't really make a difference. I'm probably just going to keep it though, there is no advanced rma option in Canada, only an option to pay full price for another and then get your money back...don't have that cash :S. Good luck.
2016/08/09 18:56:46
Just got my 1080 SC, and so far, no coil whine. Very happy so far.
CM Cosmos II Ultra/ EVGA 750 G2/ Z87 Classy/ i7 4790K/ 8gb 2400mhz/ GTX 1080 SC/ Upstar 28" 4K/ Windows 10 64
2016/08/09 19:48:49
I've never had any coil whine on any of my cards, or PSU's. I've had several.
My Affiliate Code: 8WEQVXMCJL
DarkStarchild
2016/08/09 20:26:30
J0NOX Ok so I got a helpful reply back from the Evga team about the coil issue. Basically saying "Coil whine is common throughout all electronic devices, the causes of it can be affected by many different variables. It is not something that determines whether or not a product is going to be faulty. It is just an indication there is a current going through your component. One possible solution is to leave a benchmarking program like Heaven Benchmark 4.0 on overnight. This has helped some people but it may not work for you." As suggested i tried a burn-in-test to see if it would get rid of the noise. I left the benchmark on for only 30min (was running around 150-300fps) and then I decided to cap it to 60 and leave it on...soon as I went to 60fps vsync the coil was hardly noticeable. As i mentioned before the coil was happening at 60fps but it seems maybe the burn in technique might have helped out in my case. There is still a lot of noticeable buzzing @ 80-100fps, my last card was a Asus 970oc and that didn't make any noise when fps was high during any benchmarking software I used (Valley Benchmark + Heaven), I'm still going to see if another PSU will improve things.
Hi, thanks for the reply, yea I have the EVGA supernova G2 850w PSU, got it 8 months ago brand new from Amazon. Had coil whine also with an MSI r9 390 card and that PSU but it wasn't as bad (only with vsync off it got bad). It may be best to try another PSU but perhaps I just have a slightly faulty one- I'm not sure. I have heard about leaving a benchmark on overnight, I've never actully ran anything on my system like that before, I only have the stock intel cooler on my cpu and it's an i7-4790k that get quite hot anyway so would be worried it might overheat and crash. I'll try look more into it tho, thanks for the advice. I Know in my last post I said that my other OCZ ModXstream PSU didn't have enough power cables for the 1070 / 1080 FTW but it turns out after reading another thread on here it is possible to use it with those graphics cards using the supplied adaptor by evga. I can't seem to be able to post links on here unfortunately- title is called: "PCIE Power Connections Question". So this means I will be able to test the 1070 ftw and 1080 ftw with both my PSU's now and see which combo has the most coil whine/ buzz.
DarkStarchild
2016/08/09 20:43:37
DeathSOA My 1070 sc has coil whine, only with vsync off though, with vsync on it seems to not whine much at all. It's more like a buzzing noise not really a high pitched whine type noise. Have a EVGA G2 750w psu that I literally just got not long ago. Seems it's really 50/50 like others have said. Have tried burning it in with valley benchmark for about 7 or 8 hours, didn't really make a difference. I'm probably just going to keep it though, there is no advanced rma option in Canada, only an option to pay full price for another and then get your money back...don't have that cash :S. Good luck.
Hi DeathSOA, Yea my 1070 FTW with Vsync on 60fps is more like a buzzing/ electric razor sound (sound gets louder when I equip a sword in Elder scrolls Oblivion or use a skill in Battleborn games or just move around looking at different objects in the game - Same with Witcher 3) With vsync off the sound is closer to a whine and the buzzing is there but louder.
DarkStarchild
2016/08/09 21:12:41
Tweaked Just got my 1080 SC, and so far, no coil whine. Very happy so far.
Do you get a electric buzzing sound (like an electric razor) coming from where the two pcie cables connect on the graphics card? I'd be happy with my 1070 FTW if I didn't get that sound. Mine wont't go away even with vsync on.
2016/08/09 21:53:02
DarkStarchild
No noise whatsoever as far as I can tell. But then again my car has very thick doors and gold in the nose very well.
MagicBee
2016/08/10 08:02:10
I just ordered my EVGA 1070 SC via Ebay (on 10% discount). Will test this upon arrival and update here if there's any whine.
DarkStarchild
2016/08/10 08:13:32
MagicBee I just ordered my EVGA 1070 SC via Ebay (on 10% discount). Will test this upon arrival and update here if there's any whine.
Ok, would be great to hear back from you. See if you get the noise with or without vsync (at 60fps) enabled. Also if it makes a electric buzzing sound, like an electric razor near where the pcie connections go on the graphics card. I'm trying to find out if some of these noises is normal for the 10 series Nvidia cards. Thanks
q2klepto
2016/08/10 08:20:49
So after a few more days - the coil whine is pretty bad, and the fact that i have open headphones or speakers (no closed back) makes it worse. With the 14day Return/RMA would i have to ship the card back to EVGA in Canada?
How long is downtime normally for this 14 day window?
Ill try and installing it on a different machine to see how it behaves.
Rapidisimo
2016/08/10 08:32:24
Greetings My last evga card was gforce 8600 I believe. The card I upgraded from was an MSI GTX 570 twin frozr iii. So now I have a glorious evga gtx 1070 FTW with...coil whine. It only comes up during benchmarks and maybe some gaming. Most of it is dulled by my ATX case. I contacted support and they say maybe it's your PSU, Motherboard, try it on a different PC. Ok...should I have a whole spare build for testing? lol My PSU is a brand new EVGA 650w Supernova P2 (platinum!), I bought an adapter for my older 600w Seasonic PSU just to test it on another PSU and the card still made buzzing noise. I don't have motherboard for further testing.
J0NOX
2016/08/10 11:31:23
DarkStarchild Ok, would be great to hear back from you. See if you get the noise with or without vsync (at 60fps) enabled. Also if it makes a electric buzzing sound, like an electric razor near where the pcie connections go on the graphics card.
Thanks
I just checked my 1080, yes it seems there is an electric razor razor like buzzing coming from where the pci-e connection go, even when idle. This is were the buzzing gets louder when in a game. Edit: Still using my old PSU, getting new one this Friday (12th) let you know this Saturday if the buzzing/coil changes.
post edited by J0NOX - 2016/08/10 11:40:41
arokhantos
2016/08/10 12:41:22
Heard buzzing when firing up division without vsync on only hear it if i tilt my head certain way and its just to low volume to be annoyance, never noticed it before i think probably cos its gotten a lot colder now then usually, think if heard same buzzing in the past on my gtx 480 but it never bothered me.
asus x99-a | i7 5820k @ 4.2 ghz h2o | gtx 1080 founders @ +200 +500 h2o | 1x tb crucial mx100 512 gb| evga 1300 g2
Krystm
2016/08/11 06:30:29
My 1080 FTW, I had a similar situation. I had a 550W Antec PSU and when it ramped up it was pretty loud. I opted for the 550 since I didn't feel the need to use the 1200W. Well... guess who's using the 1200W.... I swapped it in and Whine COMPLETELY gone. Defiantly check your PSU.... in most cases people suggesting it, they aren't wrong. You can also test it, rolling a piece of paper up to make a tube and listen various places while benchmarking so your whine is going good and strong. That's what I did, then swapped PSU without mounting everything just to be sure.
Jenova | Build Log Specs: Cooler Master HAF XB | 4770K | ASUS Sabertooth Z87 | G.Skill Sniper 16GB0 RAM | GPU -1x 1080 FTW | 120Gb Plextor SSD (OS) | 1x 500GB Sandisk Extreme SSD (Games) | Antec 1200-TPQ | 1x LG 34UM94 | 1x Asus VH242H Monitor | My HeatWare
2016/08/11 06:51:41
Tried listening very closely to my 1080 FTW under several different conditions (case panel off, gaming, benchmarks, idle) and don't hear any coil whine. None at all. I do have a very good PSU though, a SeaSonic XP2 860 watt Platinum. But maybe I just got lucky.
i7 6700K, Corsair H80iGT, 16GB Corsair Vengeance DDR4 @3000MHz, EVGA GTX1080 FTW, MSI Z170A Gaming M7, Samsung 950 Pro 512GB, Samsung 840 EVO 250GB, WD 1TB, Creative SB Zx, Dell P2715Q 4K/UHD @60Hz, Samsung B2230HD 1080p @60Hz, Windows 10 Pro, Corsair Air 540, Seasonic 860watt XP2, Corsair K70 RGB, Razer Deathadder Chroma
jbgrobler
2016/08/11 07:48:02
I just got my 1080 FTW DT and happy to report no coil whine during any benchies or games, so far! However, I do get soft coil whine when running some of the Vulkan samples from Sascha Willems, like the ParticelFire and TextureCubemap samples. Then again, I even got coil whine with those on my old GTX 680. Nothing during normal games. I am running 1080P though and not 4K. Here are those Vulkan samples if interested: http://vulkan.gpuinfo.org/examples.php
Windows 10 Anniversary (Version 1607 Build 14393.351)EVGA X79 DARK (150-SE-E789-K2) Firmware v2.13 | Intel i7-3820 (BX80619I73820) EVGA GTX 1080 FTW DT (08G-P4-6284-KR) - Driver v375.76 Corsair HX850W (CMPSU-850HX) | G-Skill Ripjaw 32GB (F3-2133C10D-16GXM) CM Storm Trooper (SGC-5000-KKN1) | Pioneer BDR-20 | RealTek HD Audio v6.0.1.7940 WD Caviar Black 500G x2 (WD5002AALX) - Intel RSTe (RAID0) v13.2.0.1022ASMedia ASM1042 Driver v1.16.35.1
Adger
2016/08/11 15:04:29
Hi all OP here.. i said id update and here i am. Put the FTW in bout 5 hrs ago,ive done plenty of benchmark tests (Firestrike,Valley and Heaven Benchmark 4.0) and im very impressed. Coil whine yes i do have it but..its very,very slight,i only have it in GPU intensive stuff benchmarks, GTA V,Witcher 3 etc ..and im only on a Corsair TX650 PSU. Boosted to 1987Mhz without touching anything. after a slight OC +40 on the core clock and +45 on the memory clock ,and a custom fan profile it boosts to 2025 and 4050 on the mem. I haven,t even touched the power limit. Eats games for breakfast runs everything beautifully on my U2715H Dell 2k ultrasharp. I7 4790K cpu Anyway to cut a long story short im very very happy with this card..it oozes class. The packaging,the folder that comes with it with your bits and bobs in ..everything just looks so good. This is my 1st EVGA card..it wont be my last, im seriously looking at upgrading my warranty already!! just to stay with this company. A few Pics of benchmarks if thats ok. Ive received so much helpful advice on my questions from forum members and also EVGA staff. For that i thank you all. EVGA you,ve a customer for life.. All the very best Adger
post edited by Adger - 2016/08/11 15:30:29
zyther
2016/08/11 18:09:46
Can someone with a FTW download and run ATITool, then click the 3D button, this will push your card at high fps and see if it has louder coilwhine
GhostlyBG
2016/08/11 18:19:11
hapkiman Tried listening very closely to my 1080 FTW under several different conditions (case panel off, gaming, benchmarks, idle) and don't hear any coil whine. None at all. I do have a very good PSU though, a SeaSonic XP2 860 watt Platinum. But maybe I just got lucky.
Well, I've got a 1080 FTW and it started "whining" this evening. Two things happened this night though. First I bought and installed a new monitor - ASUS ROG Swift PG279Q, running at 165 Hz. I played some games after that and I don't think there was any coil whine then, but then my SeaSonic XP2 860W Platinum just died out of the blue. The PC shut down and did not show any sign of life. Luckily I still had my old Corsair CX750W (a really cheap bronze grade one), so I put the old back in and the PC powered up without a problem. However, now when I get into a game and it starts running over 80+ frames, the coil whine begins and it gets progressively worse, the worst being at 165 fps. So the cause is either running games at fps above 60 (my old monitor was 60 hz v-sync on), or the lower quality PSU, or both. Can't really tell right now. I will wait for my replacement PSU and see what happens then. The coil whine is really annoying at 165 fps though and that is sad because I want to utilize my new monitor to its full potential.
zyther
2016/08/12 01:46:44
Running ATITool 3d View Cube: youtube.com/watch?v=JO6_8KuEXRI Running Uniengine Valley, when there is a small pause in the whine at 6secs, it is changing scenes in the benchmark: youtube.com/watch?v=Iew8qSGVpqE
post edited by zyther - 2016/08/12 01:48:58
- Ribbons : 44
2016/08/12 03:11:02
Adger Hi all OP here.. i said id update and here i am. Put the FTW in bout 5 hrs ago,ive done plenty of benchmark tests (Firestrike,Valley and Heaven Benchmark 4.0) and im very impressed. Coil whine yes i do have it but..its very,very slight,i only have it in GPU intensive stuff benchmarks, GTA V,Witcher 3 etc ..and im only on a Corsair TX650 PSU. Boosted to 1987Mhz without touching anything. after a slight OC +40 on the core clock and +45 on the memory clock ,and a custom fan profile it boosts to 2025 and 4050 on the mem. I haven,t even touched the power limit. Eats games for breakfast runs everything beautifully on my U2715H Dell 2k ultrasharp. I7 4790K cpu Anyway to cut a long story short im very very happy with this card..it oozes class. The packaging,the folder that comes with it with your bits and bobs in ..everything just looks so good. This is my 1st EVGA card..it wont be my last, im seriously looking at upgrading my warranty already!! just to stay with this company. A few Pics of benchmarks if thats ok. Ive received so much helpful advice on my questions from forum members and also EVGA staff. For that i thank you all. EVGA you,ve a customer for life.. All the very best Adger
Woot  another EVGA customer for life. Glad to see your sorted out Adger Game On
1) ASUS Z97-WS, i7-4790K@4.9GHz, 2-Way-SLI - EVGA GTX Titan X SC - EK block/plate, Custom loop, 32GB GSkill Ripjaws DDR3-2400, Samsumg Pro 850 SSD, 2-2TB WD Black, Phanteks Primo Case, Win 10 Pro 64bit, 4K Acer XB280HK monitor, EVGA 1600 P2 Supernova PSU, Fire Strike 1.1 = 21,842 2) EVGA X99 Classified, I7-5960X, 2- Titan X Pascal, 32GB GSkill Ripjaws DDR4-3000, Intel NVMe PCIe 750 SSD, Win10 Pro,PSU EVGA 1200 P2 Folding 2.5M PPD Affiliate code 05MLLDCG6B
Adger
2016/08/12 07:32:12
Cheers for your kind words Cool GTX. Its a beautiful beast of a card,im loving it  Cheers Adger
