I just need something cleared.
Look at the "max power draw" listed here:
http://www.evga.com/Products/Product.aspx?pn=02G-P4-2962-KR Does the 128W refer to the TDP rating of the GPU? Why is this above the 120W listed by Nvidia for a GTX 960? And does this 128W refer to the ENTIRE graphics card, or more specifically just the GPU chip?
When I use GPU-Z which shows the Power Consumption in % terms of the TDP, does 100% correspond to 120W or 128W? Why does GPU-Z reading spike as high as 110% sometimes?
It's a bit confusing. I wish I never bothered finding out about my GPU power consumption, but the more I find out the more questions I have and the more confused I get.
Thanks!
post edited by himmatsj - 2016/06/30 02:54:19
