oaklinda
Re: Individually Sleeved Cables for EVGA G2/P2 Power Supplies
2021/06/29 16:31:01
Niam2020
2021/06/30 14:08:15
They look amazing will have to cop one soon.
nezff
2021/07/03 05:51:02
need the white ones for a G2 850 unit. Cant find them
Use my Associates code at checkout and get up to 10% off! 95M1DJFALLX3K3L i7 11700k * Asus ROG Strix z590a WiFi * EVGA 3080 FTW3 Ultra * 32GB Corsair 3200Mhz * Samsung 970 Pro 512GB & 970 Evo Plus 1TB M.2 * Samsung 860 Evo SSD 1TB & 2TB * Lian Li Dynamic white * Corsair QL fans x9 * Corsair H150i Pro XT * Corsair Rm1000x * Samsung G7 Faker 1440p 27"
Governator
2021/07/03 11:43:29
HEATWARE Mobo: Asus Z690 Maximus Extreme (BIOS 2103) | CPU: Intel Alder Lake i9-13900K (@6.2Ghz) w/EK-Quantum Velocity² D-RGB Nickel + Acetal | GPU: Evga 3080Ti FTW3 Ultra w/EKWB Quantum Vector | RAM: 64GB DDR5 (2x32GB) Kingston Fury Beast KF556C40BBK2-64 @XMP2 | SSD: 2x WD SN850 2TB NVMe (m.2_2, m.2_3) | Power Supply: EVGA SuperNOVA 1600 P2 | Cooling: Dual Loop 2x EK-Quantum Kinetic TBE 300 D5 PWM D-RGB - Plexi / HWL 420GTS/Corsair XR5 420 Rads | Case: Corsair 7000D Airflow | OS: Microsoft Windows 11 Pro 64 Bit | Monitor: ROG Strix XG438Q | KB: CORSAIR K100 RGB Optical-Mechanical | Sound: Onboard Realtek via SPDIF (Logitech Z625 THX)
TwoEvilOne
- Location: NW Ohio. EVGA Associate Code: 2QME1VF65K9ZY8B
2021/07/03 11:52:05
Hoggle
2021/07/03 12:03:51
Governator It appears that the blue set is out of stock, any ETA on restock? update, found them on Amazon: https://www.amazon.com/EV..._dp&th=1&psc=1 EVGA Store
Since it’s from the EVGA store it should work perfectly. For anyone else looking online for them make sure it’s an EVGA original part as third party off brand might not be made with the same quality in the wires themselves or could be incorrect wired. It’s always best to make sure your PSU won’t run into any surprises that could result in loss of hardware.
Governator
2021/07/03 12:05:53
Hoggle
absolutely, good advice ordered this set which will go into the Corsair 5000D Airflow I originally tasked for my new Alder Lake build later this year but will instead give it to my daughter to transfer her existing Z490 Dark rig into from a Corsair C70 Midtower, these cables will help immensely with routing. For myself I will be going with the Corsair 7000D Airflow (on pre-order from Newegg).
post edited by Governator - 2021/07/03 12:16:31
Jyoussi
2021/07/07 08:16:15
those look cool and give it a less cheap feel to the cables
Torez082079
2021/07/12 09:23:00
I recently had a EVGA 1000w gold power supply blow a capacitor as a direct result bricked my 600.00 motherboard EVGA replaced my power supply but told me they would not compensate me for my motherboard even though they admitted there power supply caused the damage I will never buy an EVGA product again nor will my company!
SlimTrainEE
2021/07/31 12:46:44
Need more orange and more cow bell.
Pacheenee
2021/08/06 22:04:22
i need these. i hate my fishnet sleeves, at least for my gpu
kusanhagi
2021/08/14 23:52:32
Every time I see white in stock email by the time I try to buy they are sold out. So sad.
