lostdrumr
Re: Individually Sleeved Cables for EVGA G2/P2 Power Supplies
2015/04/15 08:55:17
just a heads up, i've had these cables close to one year now and many of them are fraying at the connectors. Over the last couple of weeks, every time I fired up a game my system would hard lock. Took one GPU out and it was ok for a few days until Sunday it started hard locking on a single card. I replaced everything possible ( even tried a 1000p2, 1200p2 and 850g2) in the system and the last option was trying different cables. Replaced the cables with the standard cables that came with the 850g2 and the system is now running perfectly stable even with both cards installed. Could be isolated, but I would take this into consideration before spending $90 on these cables.
Jfeil
2015/04/15 10:14:13
lostdrumr just a heads up, i've had these cables close to one year now and many of them are fraying at the connectors. Over the last couple of weeks, every time I fired up a game my system would hard lock. Took one GPU out and it was ok for a few days until Sunday it started hard locking on a single card. I replaced everything possible ( even tried a 1000p2, 1200p2 and 850g2) in the system and the last option was trying different cables. Replaced the cables with the standard cables that came with the 850g2 and the system is now running perfectly stable even with both cards installed. Could be isolated, but I would take this into consideration before spending $90 on these cables. CRAP!!! Too late, I just pulled the trigger on them last night! I'm hoping maybe yours is an isolated case or perhaps they've changed their production methods in the year since you've had them. Oh well, $90 isn't really very much money to spend on individually sleeved cables, if they end up being a problem I'll just buy the set from CableMod, I already know their quality is very good.
"I don't want any yes-men around me. I want everybody to tell me the truth even if it costs them their job." -Samuel Goldwyn
2015/04/15 11:18:38
I've had mine for a year and no issues as of yet. I did have one cable sleeve pull off, but didn't effect anything.
You should push the wires into the connector and verify they are all seated properly. It only takes one that isn't full seated to cause a hardlock.
Also, how did they fray? Where you constantly removing parts and replacing them? Normally they just sit there after being plugged in, not moving, and can't fray is why I ask.
If you would like to use an affiliate code to register a product, feel free use this one: >Click Here< This is not my affiliate code! This is a random users code. This code will change often, and you will never be told who it belongs to! If you would like the possibility of your code being listed above, it must be in your signature block. I will not take requests to use a specific code.
lostdrumr
2015/04/17 09:08:06
Everything appeared and felt to be seated properly. I will admit, they've been used in 3 different cases which probably contributed to the fraying. My concern about that is because i've never had that issue with any other cables that were in and out of several different cases. I also noticed on some other sleeved cables there is a small rubber boot at the end of each wire, and i would like to see that added to these in the future, if possible.
Jfeil
2015/04/17 09:42:03
lostdrumr I also noticed on some other sleeved cables there is a small rubber boot at the end of each wire, and i would like to see that added to these in the future, if possible. That small rubber boot is heat shrink tubing, not having them is actually a major selling point for these cables. Rather than use heat shrink to keep the sleeves in place, they crimp the sleeve directly into the end of the contact pin. It's really a matter of preference I guess, but the trend has gone toward having no visible heat shrink.
2015/04/17 10:10:42
Yes srink look bad really... That's why people love these cables more than CORSAIR, because no srink.
2015/04/17 23:25:06
v1ral I think this has been asked before but here it goes. I just bought an EVGA 850 G *not G2*, I am wondering if the cable kits marked as G2 etc will be a direct replacement? Thanks for your time!
Please contact EVGA tech support
whom exactly should I contact? Are the pin outs exactly the same?
2015/04/18 12:08:02
If you have 850 GS you can compare connectors with G2 models. For me they look same, some of them, I didn't pay attention on all. You need to compare one by one and to ask EVGA about that.
DewFuss
2015/04/18 13:20:31
I've read all 98 posts to this thread. Can someone PLEASE answer the many times asked question as to the length of these cables? Are they the same length as the stock cables or hopefully longer? Beautifully sleeved cables are a waste if I still need to use extensions. I know for a fact that I'll need longer cables to reach from the top of my case to the basement compartment. Are there extensions available that will fit between the PSU and either these or the stock cables so I can use these cables?
post edited by DewFuss - 2015/04/18 13:26:10
What do you mean "Caffeine isn't a vitamin!"?
2015/04/18 13:24:57
v1ral
Support@evga.com You can also go to the top of the page and click "support" and then contact support. DewFuss I've read all 98 posts to this thread. Can someone PLEASE answer the many times asked question as to the length of these cables? Are they the same length as the stock cables or hopefully longer? Beautifully sleeved cables are a waste if I still need to use extensions. I know for a fact that I'll need longer cables to reach from the top of my case to the basement compartment. Are there extensions available that will fit between the PSU and either these or the stock cables so I can use these cables to ?
I will see if I can find a tape ensure at Walmart and measure them when I get home. I have stock and these kits, so I will lay them side by side for exact measurements.. To answer your question if they will reach the top of your case, it would depend on your case and the full length required to reach the top as well as pass through the port to wrap around. I can not see signatures, so I am not sure about the length you would need overall.
post edited by Scarlet-Tech - 2015/04/18 13:27:51
DewFuss
2015/04/18 13:40:27
Scarlet-Tech I will see if I can find a tape ensure at Walmart and measure them when I get home. I have stock and these kits, so I will lay them side by side for exact measurements..
Thanks Scarlet-Tech... It's much appreciated. My case is 36in tall . The PSUs will be in the "attic" compartment and some of the pumps/fans will be in the "basement". The case front to back is also 30in deep so many stock cables won't be long enough to reach front mounted Optical drives and fans & fan controllers as well. Hence my desire for longer extensions especially for Molex and SATA power.
2015/04/18 16:48:07
Alrighty, I will pictures asap. 24 pin is 25" long end to end. 8 pin cpu is 31" end to end total. 8 pin vga is 31" end to end total. Sata cables are 23" from the psu to the first sata power connector. There is 5.5" between each connector. 31" total end to end. The molex is 23.25" from psu to first connector, 5.5" between connectors, and 31" total to the end connector. The stock cables are exactly the same lengths as the individually sleeved set.
post edited by Scarlet-Tech - 2015/04/18 16:50:35
DewFuss
2015/04/18 16:52:02
Scarlet-Tech Alrighty, I will pictures asap.
YOU ROCK! Thanks for checking Scarlet-Tech. hmmm Now to figure out what to do about extensions. Anyone have suggestions?
post edited by DewFuss - 2015/04/18 16:54:08
t3h0th3r
2015/04/20 03:37:13
Any word on availability of the additional cable set for 1600W editions 100-CK-1600-B9 in europe? also imo those should be proviced free of charge for those that require it when you have to shell out 80EUR for a set...
2015/04/20 16:52:22
DewFuss YOU ROCK! Thanks for checking Scarlet-Tech.  hmmm Now to figure out what to do about extensions. Anyone have suggestions?
I have not used extensions, so I am honestly not sure. t3h0th3r Any word on availability of the additional cable set for 1600W editions 100-CK-1600-B9 in europe? also imo those should be proviced free of charge for those that require it when you have to shell out 80EUR for a set...
It wouldn't be easy to be provided free for those that require it. They have provided enough for 2 way Sli, which is the "normal" for more than 1 card. There is 3 sets of PCI when you count the 6+2+6 which covers the rest of the above average setups that have 3 way SLI. Of you have the money for quad, the extra kit isn't going to hurt your wallet. As far as availability, have you tried authorized retailers? I can usually find them on Newegg or Amazon when EVGA is sold out.
t3h0th3r
2015/04/21 10:37:19
my complaint is, that i buy a set that "Supports all EVGA SuperNOVA G2 and P2 power supplies", naively thinking it will be supporting "all EVGA SuperNOVA G2 and P2 power supplies" only to find out that it's actually not for for all, namely too few pci cables (even when actually taking into account those 6+2/6) for anyone actually wanting to use more than 6 cables on the 1600W versions (which has connectors for 9 cables). with the power a 1600W PSU provides, you'll be powering 3-4 GPUs. that's 6 to 8 PCIe connectors/cables or 9-12 in the case of high end classifieds(3 connectors per card). so maybe revise that to "Supports all* EVGA SuperNOVA G2 and P2 power supplies *) Users wanting to utilize more than 6 cables (i.e. owners of 1600W models) need to get the Additional Power Supply Cable Set 100-CK-1600-B9" or a similar warning. it looks in europe i'll just have to resort getting a second of the full sets.
post edited by t3h0th3r - 2015/04/21 10:39:54
2015/04/21 11:21:26
The power supply and the kit shows exactly what come in it, and if you don't read that, then you are asking for issues. It is the responsibility of the end user to research, as the material is made public to the end user. This isn't hidden. This is a direct copy and paste
Standard kit for 1600p2: CONNECTOR QUANTITY 24 PIN ATX 1x EPS (CPU) 2x 8pin (4+4) PCIE 9x 8pin (6+2), 5x 6pin SATA 16x FOUR-PIN PERIPHERAL 6x FLOPPY 2x
Individually sleeved kit: Includes the following cables: 1 x 24-pin ATX Cable 2 x 4+4pin EPS12V CPU Cable 4 x 6+2pin PCI-E VGA Cables 2 x 6+2pin + 6pin PCI-E VGA Cables 4 x 3 SATA Cables 1 x 3 Molex Cable 1 x 2 Molex Cable + 1 Floppy Connector
As for stock, they sell out fast. They always have.
2015/04/21 15:38:59
1600W models come later and if someone need all cables, more VGA, Additional Set is available for 30$ http://www.evga.com/Products/Product.aspx?pn=100-CK-1600-B9 That's in case that someone have 4xGTX980 K|NGP|N Classified or similar graphics. What to do someone with 750/850 G2 with 9x VGA cables and 120$ kit.
Pgcmoore
- Ribbons : 14
2015/06/20 20:28:36
anybody tried using these with the new 1050 GS?
220-GS-1050-V1Its not on the list but they look like they would work.
"This program has performed an illegal operation and will be shut down"  My Affiliate Code is 05G-UGD-GZVU
Crimson AL
2015/06/23 19:09:09
So these do not work on the T2 models?
Pgcmoore
- Ribbons : 14
2015/06/23 19:11:57
Crimson AL So these do not work on the T2 models?
Yes, they work on T2
Crimson AL
2015/06/23 20:30:41
Thanks...just went by the thread language. I already have these cables and was looking to maybe use the coupon that came with buying the 980ti's to get another psu.
Pgcmoore
- Ribbons : 14
2015/06/23 20:50:51
Crimson AL Thanks...just went by the thread language. I already have these cables and was looking to maybe use the coupon that came with buying the 980ti's to get another psu.
I think theres a $40 rebate until the 30th on the T2 also yep.. EGA-23214 https://evga.4myrebate.com/Claim/FindaRebate
post edited by Pgcmoore - 2015/06/23 20:54:02
Crimson AL
2015/06/23 21:52:23
Aklorian
2015/08/01 14:43:19
Pgcmoore anybody tried using these with the new 1050 GS?
Any chance you've found an answer to this? Long story short I had a customer of mine get one for free (it was likely forgotten in there) with a case they reviewed but it had no cables. There's not a spec of dust in the thing - it looks like its never been run. I bought it for $50... but now I need cables. Any ideas where I can get some?
Pgcmoore
- Ribbons : 14
2015/08/01 14:46:28
yeah, I dont think they will work from what I have "not heard", I went a different direction on the psu. hold on and I will find a link for some I was looking at.
Aklorian
2015/08/01 14:57:41
Amazing! Thank you very much. I found a posting on another forum stating that CableMods make a set but upon searching I can only find support for the G2 series.
Pgcmoore
- Ribbons : 14
2015/08/01 14:58:42
Pgcmoore
- Ribbons : 14
2015/08/01 14:59:03
LOL, yep talk about being on the same page!
post edited by Pgcmoore - 2015/08/01 15:01:08
Pgcmoore
- Ribbons : 14
2015/08/01 15:05:43
I found an old Ultra 1200 I had laying around and decided to mod some and do my own sleeving trust me, you dont want to go there! LOL
post edited by Pgcmoore - 2015/08/03 13:28:16
