Re: Individually Sleeved Cables for EVGA G2/P2 Power Supplies
2015/02/06 21:11:49
soybean would these work with the evga 220-gs-0850-v1 850 psu or should i keep looking around?
No, EVGA G2/P2/T2 series.
Narshredder?
2015/02/12 14:41:04
Anywhere to find green sleeved cables?
2015/02/18 08:59:10
THIS IS REALLY NOT FAIR, EUROPE CAN'T GET BLACK AND RED CABLES MORE THAN MONTH. I hope EVGA Main Office will fix shortage with cables in these two colors in Europe. Can someone maybe know some other shop for black and red cables. But only EVGA Sleeve Set.
2015/02/27 16:29:35
Today and white sleeve set are sold in EVGA Europe, only blue are available. I hope now EVGA will send new shipment. If we wait to Europe sold and blue to get again...
FR3D1
2015/03/13 03:06:25
I have notice that they're 2 type of material so sleeving. One is the plastic like material that comes with the stock cable and the other is the fabric like sleeve. Just wondering which material are these sleeve?
2015/03/13 10:20:50
You mean on EVGA Individual Sleeves two different types or some other cables. If you think on other cables that's normal, many different types are available, some of them are similar to plastic as you say and other is paracord or some kind of sleeves similar to paracord. EVGA Europe long time didn't get black cables, USA shop probably have big supplies and Europe nothing. I wait them to become available and every day almost I check on site...  They promised availability of sleeve cables, not one series.
post edited by Vlada011 - 2015/03/13 10:23:10
FR3D1
2015/03/13 23:21:16
Vlada011 You mean on EVGA Individual Sleeves two different types or some other cables. If you think on other cables that's normal, many different types are available, some of them are similar to plastic as you say and other is paracord or some kind of sleeves similar to paracord. EVGA Europe long time didn't get black cables, USA shop probably have big supplies and Europe nothing. I wait them to become available and every day almost I check on site... They promised availability of sleeve cables, not one series.
I mean in general I notice there are two types. The plastic one is the one that you can push it together to make it fatter and normally used to sleeve multi cables in a bunch and the fabric one I normally see as a Individually Sleeved Cables just wasn't sure which does EVGA makes and what they're called.
2015/03/16 15:56:52
I'm not sure how these new cables looks like but cables on NEX1500 are something between plastic and fabric. They are compact with wire, you can't move them over wire, you can't notice wire in sleeve. MDPC-X is example more plastic feeling. I can't wait to Europe get them. Only black and red are not available, most wanted colors.
2015/03/17 09:37:02
I have a set of blue cables. Love them! See my MODS RIGS
Mother Board: EVGA X99 ClassifiedCPU: Intel I7 5930K Haswell @ 4.2 GHzCooling: EKWB EK-XLC Predator 360 (incl. QDC)GPU: Nvidia TITAN X Pascal with EK-FC Acetal+Nickel Pre-FillRAM: 32GB Corsair Dominator Platinum 3200 MHz PSU: EVGA SuperNOVA 1000 G2 80 Plus GoldSSD: Samsung 850 PRO 512 and 840 PRO 256OS: Windows 10 Pro / 64 bitCase: Corsair Obsidian Series 750D Full-Tower
2015/03/17 10:46:55
CptSpig I have a set of blue cables. Love them! See my MODS RIGS
Your choice is really weird. I mean compared with your components, I expected black. I hope I will not have 60 years when Europe get black set. I searched and other shops but only EVGA sell them in Europe.
sahafiec
- Ribbons : 6
2015/03/18 00:00:15
are you looking to buy one for yourself Vlada011? they have currently the white ones in stock, a good choice if you ask me especially if you don't want to wait. http://eu.evga.com/produc...%20Supplies&uc=EUR
post edited by sahafiec - 2015/03/18 00:03:20
i5 6600k | z170 m8g | h100i v2 | gtx1070 FTW | 2x8gb 2666mhz | 250gb m.2 & 2tb | 650W P2 | Enthoo Pro M Acrylic | pb258q
2015/03/18 06:43:16
Yes cables are for me, but must be black.
2015/03/18 09:40:20
Vlada011
I used to have blue lights and ram. That's why I have blue cables.I did not want to spend another $90.00 on black cables.
walsh430s
2015/03/18 15:18:51
I haven't seen anyone address the capacitor question. This is a very valid question. Dirty power reduces the life of electronics. And these components are not cheap. I personally asked customer support this question and here is the answer I was given. Comment: I have an EVGA 1300 G2. I have 2 questions. 1st, the head snapped off one of the mounting screws. If I am unable to grab what is left with pliers, will my warranty be voided if I open the case so safely extract the broken screw? 2nd, I would like to make a custom set of sleeved cables. The OEM cables have what looks like it could be a capacitor installed under the heat shrink. This is not something that would look all that great on individually sleeved wires. I know EVGA offers sleeved cable that don''t appear to have a capacitor inline. So... Can I safely make cables without a capacitor installed inline? I would have thought it was there for a reason. And I really don''t want to replace a perfectly good PSU just to make a set of cables. Thank you for your time, Brian. The screw stuck would not void the warranty but opening the power supply would and is highly not recommended.
You are able to make your own sleeved cables if you would like. The cable set you offer is a better gauge wire which does not require the capacity like on the stock cables.
Thank you, EVGA Support This is copy and posted from the email. I'm having a hard time buying into this answer. Anyone else? I would LOVE an engineer from EVGA to comment on this. I read a review on JonnyGURU about a non EVGA PSU that also used capacitors in the harness. This PSU did very well when tested in the "as shipped" form. The reviewer swapped out the harness for ones without the capacitors and the results were a 29mV ripple!
nickheller
2015/03/24 21:05:35
So, should I get these or the ones from cable mod for around the same price? I saw a comparison between the two and it said the cable mod set bent a little easier.
My Computer: i7 4790K Noctua NH-U14s Gigabyte Z97X-UD5H-BK 16 GB Kingston HyperX Ram EVGA Super Clocked 980 ACX 2.0 EVGA 750G2 Samsung 840 EVO 250GB Western Digital Caviar Black 2TB Fractal Design Define R5
2015/03/24 21:34:44
I would choose EVGA. I can buy Cable Mod but I don't want. I wait EVGA and that's my intention to bent harder I like more flexible as EVGA. Because of that for me they are better than others or manual sleeve cables. Now I think more and more for option to buy from USA because it's not fair, they sell only 2 months in total black sleeve in Europe.
2015/03/24 22:12:11
If you have a EVGA power supply than get EVGA cables. You can't go wrong.
2015/03/24 22:19:46
CptSpig If you have a EVGA power supply than get EVGA cables. You can't go wrong.
+1. Logic answer if option is on table.
2015/03/24 22:33:26
nickheller
2015/03/25 06:38:01
How hard was it to route the cables? I am mainly getting them for looks but would still like to have them routed as tight as my stock ones.
2015/03/25 07:02:39
It's super easy. Go and look at my build on MODS RIGS.
HitMaNSpArKY20
2015/04/07 21:19:52
Do you guys just have a cable set for VGA Cables? I have red ones that I dont like at all... And since I have a black and White build. Do you guys provide a Custom White sleeved VGA cable set?
2015/04/08 00:14:44
HitMaNSpArKY20 Do you guys just have a cable set for VGA Cables? I have red ones that I dont like at all... And since I have a black and White build. Do you guys provide a Custom White sleeved VGA cable set?
Yes, you need to buy Additional Power Supply Cable Set, made for 1600W models with more VGA connectors for more graphic cards. Cost 30$ and you get ... - 2 x 6+2pin PCI-E VGA Cables
- 1 x 6+2pin + 6pin PCI-E VGA Cables
- 1 x 3 Molex Cable
All colors are available http://www.evga.com/Produ...aspx?pn=100-CW-1600-B9
Moadebe
2015/04/09 19:18:38
Hey yall. I am just wondering what the length of these cables are. Like I am currently building a comp and having to buy parts here and there over the next 2 months. I am using a Thor-v2 W case (full ATX case) and the motherboard is a asus sabertooth z97 mark s (limited edition).
The motherboard has a 8 pin power connection that will end up at the very top of the case and the power supply is of course mounted on the bottom. The case dim are 22.84" x 9.14" x 20.08" and of course cable management will lower the cable a bit as well.
Jfeil
2015/04/14 13:49:46
I can't seem to find any official information from EVGA on the wiring gauge used in these cable sets. There's a post by VSG on LinusTechTips where he states that he THINKS most of the wires are 16-AWG with a few 18-AWG sprinkled in, like on the daisy-chained PCI-E connectors and on the non crucial leads on the 24-pin connector. I'd really like to hear about this from someone at EVGA. I've got myself a brand new 1600 P2 that I'm wanting sleeved cables for and if the EVGA set is as described by VSG, I'll gladly buy them. If not, I guess I'll pick up a set from CableMod.
"I don't want any yes-men around me. I want everybody to tell me the truth even if it costs them their job." -Samuel Goldwyn
2015/04/14 14:11:36
They are 16awg through out and signal wires are 18awg. The signal I am referring to is the green wire to tell the psu that the motherboard is working. There are a few other small 18awg wires, but not many. The sleeved kits are actually really nice.
If you would like to use an affiliate code to register a product, feel free use this one: >Click Here< This is not my affiliate code! This is a random users code. This code will change often, and you will never be told who it belongs to! If you would like the possibility of your code being listed above, it must be in your signature block. I will not take requests to use a specific code.
Jfeil
2015/04/14 14:21:30
Scarlet-Tech They are 16awg through out and signal wires are 18awg. The signal I am referring to is the green wire to tell the psu that the motherboard is working. There are a few other small 18awg wires, but not many. The sleeved kits are actually really nice.
That's great to hear, I think I'll go ahead and pull the trigger then. Thanks for the input, Scarlet-Tech!
2015/04/14 14:30:15
Jfeil
Vsg deserves more credit. We get some amazing reviews out of him :-)
2015/04/15 04:52:46
I think this has been asked before but here it goes. I just bought an EVGA 850 G *not G2*, I am wondering if the cable kits marked as G2 etc will be a direct replacement? Thanks for your time!
- Ribbons : 52
2015/04/15 05:17:37
v1ral I think this has been asked before but here it goes. I just bought an EVGA 850 G *not G2*, I am wondering if the cable kits marked as G2 etc will be a direct replacement? Thanks for your time!
Please contact EVGA tech support
(Pazmeister: rjohnson.....YOU ARE A LEGEND, problem solved, i am sendning my missus round to you now so she may have your babies!!) , R.I.P Jeffreyham, R.I.P Corsair_Mike, R.I.P Wrinvert, i7 5820K, Corsair H100, Corsair Vengeance LPX 32GB (CMK32GX4M4A2666C16R), EVGA GTX 1080FTW ACX, Corsair AX1200, EVGA X99 Micro2, Samsung Sm961 m.2, One Corsair SSD, Crossover 4K,
