I'm thinking about water cooling. (first time)
manny8127
2016/10/18 00:52:16 (permalink)
So I'm still rocking the i7 920 that has served me well since 09. I've had it overclocked to 4.0GHZ with a third party after market cooler (Xigmatek Dark knight). I've just purchased a GTX 1070 and I'm hoping to extend the life of my CPU just a bit longer by switching over to water cooling. Hoping to hit 4.2GHZ. What water cooling kit do you guys recommend? I see the Corsair H60 is 49.99 after mail in rebate at newegg.
Intel Core i7 6700k @ 4.0 GHZ
Evga z170 FTW
Corsair Vengeance LPX 16GB DDr4 3200
Evga Gtx 1070 FE
6 Replies Related Threads
    vincinator44
    Re: I'm thinking about water cooling. (first time) 2016/10/18 05:28:45 (permalink)
    All the vendors AIO coolers perform about the same. Just make sure the one you select is rated for 150W for an OC'ed 920..
    tucker147
    • Ribbons : 13
    Re: I'm thinking about water cooling. (first time) 2016/10/18 08:35:06 (permalink)
    You can probably do 4.2 with the xigmatek, just keep the load temps below 85c and the voltage below 1.45V and it'll be fine.
    If your set on an AIO all I can suggest is to get a one with a 240mm rad at the minimum. An H60 or similar will perform about the same as your current cooler.
    The Banshee: Xeon X5670 @ Stock, CPU + GPU Custom loop w/ 360mm & 240mm rads, EVGA X58 Classified 4-Way SLI, Geforce GTX 780 Ti SLI @ 1200MHz 1.162V, EVGA 1300 G2, WD Blue 1TB (main storage), Corsair Force LS 120GB (OS Drive), Fractal Design Arc XL, Samsung HCH9 24GB (6x4GB) @ 1333MHz CL9 1.5v
    Other rigs: The Wraith & Under The DICE
    WackyWRZ
    Re: I'm thinking about water cooling. (first time) 2016/10/18 09:36:19 (permalink)
    A Noctua NH-D15 will outperform a H80/H110 - so AIOs aren't necessarily that much better. http://www.relaxedtech.com/reviews/noctua/nh-d15/8  If you really want to get into water I'd suggest looking into one of the Swiftech AIOs.  I started out with an H220x and it performed very well.  Plus it's expandable so if sometime down the line you want to add to it you can.
    If that is out of your price range - look into this for about the same prices as the H60 (after MIR): http://www.newegg.com/Product/Product.aspx?Item=N82E16835494019
    post edited by WackyWRZ - 2016/10/18 09:45:08
    CASE: Phanteks Enthoo ProM Acrylic | MOBO: ASUS Z97 Sabertooth Mark 2 | CPU: i7-4790K @ 4.4GHz | RAM: Avexir Blitz DDR3 16GB 2133-CL9 | SSD: Samsung 850 PRO 512GB | PSU: EVGA SuperNOVA 750G2 | GPU: EVGA GTX980ti Classified | MON: 2x -Dell S2716DG 1440p/144Hz G-Sync | COOLING - Custom Loop: G-Changer 360 V.2 --- DC12-260 Pump ---  UC-2LT CPU block --- EK-FC780 GTX Classy GPU block
    bg8780
    Re: I'm thinking about water cooling. (first time) 2016/10/18 10:42:01 (permalink)
    I am running an i7 970 at 4.2ghz / 1.32v. I have it under an EK Predator 240 and temps never exceed 70C. I was hitting 80C with my old Megahalem. The Swiftech AIO's are great too but I found EK's AIO to be cleaner and less flashy looking. Also, with the recent price drop I can't find a reason not to go with the EK kits. 4.2ghz should be breeze with a 920 under water. Your current cooler should be able to handle 4.2ghz as well. A Corsair H60 will likely perform worse than your current cooler. Maybe a bit better if you use some strong fans in push/pull but that will be noisy.
    I am currently running a 1080 Hybrid. LONG LIVE X58!!!
    post edited by bg8780 - 2016/10/18 10:46:58
    NordicJedi
    EVGA Tech Support
    • Ribbons : 76
    Re: I'm thinking about water cooling. (first time) 2016/10/18 17:36:10 (permalink)
    Moving to the Overclocking, Cooling, and Benchmarking section.
    6012mhz on L/N2
    5321mhz on L/N2
    5091mhz on air
    The Lightsaber
    The Emperor Reborn
    rsabatino
    Re: I'm thinking about water cooling. (first time) 2016/10/18 19:55:55 (permalink)
    i just bought a master liquid pro from cooler master for my sandy bridge 2600k and 10 to 20 degrees off of my temps. in the heat of summer. i was using an evga superclocked cpu cooler that i won like 5 years ago or so. it was collecting dust that would not come off so i replaced with that http://www.newegg.com/Product/Product.aspx?Item=N82E16835103209&cm_re=coolermaster-_-35-103-209-_-Product  with both coolers i was able to over clock 4.5ghz and i still use the sandybridge and z68 sli.
    my affiliate code is : DPSRRUOCHM
     Summary
      Operating System
       Windows 10 Pro 64-bit
      CPU
       Intel Core i7 6700K @ 4.00GHz 26 °C
       Skylake 14nm Technology
      RAM
       16.0GB Dual-Channel Unknown @ 1066MHz (15-15-15-36)
      Motherboard
       EVGA INTERNATIONAL CO.LTD 140-SS-E177 (U3E1) 27 °C
      Graphics
       ASUS VE278 (1920x1080@60Hz)
       4095MB NVIDIA GeForce GTX 1080 (EVGA) 40 °C
       4095MB NVIDIA GeForce GTX 1080 (EVGA) 34 °C
       ForceWare version: 375.70
       SLI Enabled
      Storage
       931GB Western Digital WDC WD1000DHTZ-04N21V0 (SATA) 30 °C
       1863GB Western Digital WDC WD20EZRX-00D8PB0 (SATA) 29 °C
      Optical Drives
       ASUS BC-12B1ST b
      Audio
     &n[/p
