I am worried: Max temps on my GTX 750 SC hitting 77C!
himmatsj
Tuesday, August 19, 2014 1:31 PM (permalink)
Hi guys,
I bought my GTX 750 SC almost about exactly half a year ago. When I stress tested it initially to check out things like temps, fan and performance, everything looked fine. When I worked it to 100%, the absolute maximum it could reach was 67C, and then would stagnate there. To even reach this temp, I had to keep the benchmark running for nearly 15 mins doing multiple loops. Mind you, I tested using multiple benchmarks (including the EVGA one) and they all hit a max of 67fps under maximum load and memory usage.
I was then told that around 67C is ok. Under regular load "heavy" gaming load, it wouldn't go above 60-62C. Also, I have a fully stock Dell PC with stock cooling and I live in a hot and humid country called Malaysia.
However, fast forward six months, I am getting worried. My temps now hit 77C, especially when I play demanding games. Even with semi demanding games, I can hit 70C. I was playing Watch Dogs, and it took my GPU to 77C within 10 min. I'm playing at medium settings, and since the framerate is always just below 60, I can assume my GPU is being worked almost to the max (usually with Vsync the GPU workload can be cut down if your average FPS is above 60).
So I would like to ask, how come in 6 months my temps have risen a full 10C under load? 67C was reached under MAX load, while the 77C with Watch Dogs must be close to that but I doubt it is using 100% of my memory.
I must make it clear that while I do game fairly often, over 80% of the time I play smaller indie games that do not push my GPU. And if I do even play AAA games, they are older ones and I have Vsync enabled in all cases. And anyways, usually I play 2D platformers, so I doubt that wear and tear, or strain, is the cause of this.
Can anybody help me? What is the temperature that should tell me: STOP? Assuming that the temps get too hot, what will happen? Will the PC burn, or only the GPU? Will other components be affected? Any possible solutions?
Thank you!
post edited by himmatsj - Tuesday, August 19, 2014 1:34 PM
7 Replies Related Threads
    EVGATech_JaesonW
    EVGA Tech Support
    Re: I am worried: Max temps on my GTX 750 SC hitting 77C! Tuesday, August 19, 2014 1:54 PM (permalink)
    77c is still very reasonable for a GTX 750. It's maximum temperature is 95c, and you generally are safe at anything below 90c. I myself on my 760s have pushed up to 86c uring benchmarks, and before I moved when I didn't have air conditioning I could peak out at 92-93c. The system will shut off when the card gets too hot to protect itself, so there's very little chance of any permanent damage from temperatures unless you run it in the 90's for long periods of time.
    It's entirely possible that the change in temperatures are due to the difference in the ambient temperatures, and possibly dust buildup on the card itself. If you haven't in a while, try taking the card out and blowing out any dust with compressed air. this alone can sometimes drop your temps 10-15c.
    EVGA Customer Service Manager
    Have a moment? Please rate our service
    houkom
    Re: I am worried: Max temps on my GTX 750 SC hitting 77C! Tuesday, August 19, 2014 6:58 PM (permalink)
    EVGATech_JaesonW
    This. Honestly.... last summer when my AC unit broke... i was gaming with an external room fan blowing into my case just because I was hitting 94C. I hadnt realized this until roughly 6-8 hrs of gaming. They hit max pretty quick and yet to this day, they are still rock solid even after HOURS of being at the upper limit of their thermal design. Don't worry about 77C :)
    13900k | 64GB Trident Z5 6400mhz | MSI Z790 CARBON WIFI | MSI RTX 4090 SUPRIM X |  2TB Sabrent Rocket | 1TB Samsung 970 Evo Plus NVMe | Corsair AX1200
    EVGATech_JaesonW
    EVGA Tech Support
    Re: I am worried: Max temps on my GTX 750 SC hitting 77C! Tuesday, August 19, 2014 8:39 PM (permalink)
    I hit 95c and didn't realize it for about an hour on my 760s. The primary card was at 95 and the secondary was at 88. Turns out after updating Precision X I somehow turned off auto fan control so I was playing for a bit before I noticed the temps. Almost had a heart attack until I figured out what I had done. They're still kicking without a hiccup too.
    astacy12
    Re: I am worried: Max temps on my GTX 750 SC hitting 77C! Wednesday, August 20, 2014 0:18 PM (permalink)
    77 is child's play for these GPU's... If you are worried about it, set a fan profile to allow a more aggressive fan curve which will lower the temps. Besides, temps in the Summer are always going to be higher than in the Winter (which is why you were getting a max of 67 degrees 6 months ago during winter months). I had two different fan curves before I put my pc under water, one for Winter and one for Summer. The Winter one is less aggressive to help dampen the sound.
    himmatsj
    Re: I am worried: Max temps on my GTX 750 SC hitting 77C! Wednesday, August 20, 2014 1:39 PM (permalink)
    Ok guys, thanks for the replies.
    @Jason, I actually have not cleaned up the dust. Must I? This is my first GPU and I never ever dusted the innards of my previous PCs before. It's only six months old btw. But yeah, now I think about it, this may be a factor. The area where my PC is...the wires always get dusty after a few months. No difference in ambient temps as I live in Malaysia - same climate all year long. Plus I was playing at night, when it is the coldest (still above 30C, heh).
    Anyways, just wanna let you know that my idle temps seem to remain the same. Previously, at the start, it used to be 39C at night and 40C in the afternoon, sometimes even 41C. Now, it is the same case. 39C at night and 40C in the afternoon. Is idle temps at the same ambient temperature a good indicator as to whether or not there is a lot of dust buildup in the GPU?
    I was only worried that this might escalate exponentially, that before I know it things would become so bad it would reach 90C and then blow up. So aside from dust, can there be any other physical reasons? (Disregarding ambient temps since they are constant for me)
    @Astacy, There is no summer and winter where I live. Just day and night, rain and sunshine. :)
    • Ribbons : 86
    Re: I am worried: Max temps on my GTX 750 SC hitting 77C! Wednesday, August 20, 2014 1:49 PM (permalink)
    Depending upon the region in which you live, a monthly cleanup of your rig should be done. Get rid of all the dust buildup in your rig. If you live in very dry areas with very little dust or sand then once every two-three months should suffice.
    Dust impedes airflow and can affect the temps of everything inside your PC.
    _Nite_
    • Ribbons : 46
    Re: I am worried: Max temps on my GTX 750 SC hitting 77C! Wednesday, August 20, 2014 8:20 PM (permalink)
    77c is way too high for a 750, I have a 750 Ti SC in my other system and its only 62c @ 1306 boost clock (out of the box settings)
    its amazing how cool these maxwell cards run.
    post edited by _Nite_ - Wednesday, August 20, 2014 8:23 PM
    Gaming Rig: AMD Ryzen 7 2700x @ 4.25Ghz - Asrock B450 Pro 4 - 16GB Crucial Ballistix DDR4 3000 - 240GB SSD (OS), 1TB ADATA SU800 SSD and 2TB ADATA SX8200 Pro M2 NVME (Games) - 8GB RTX 3070 XC3 Ultra - Sound Blaster Audigy 5 RX - EVGA Supernova 750w G2 - Antec 302 - 24" Asus VG248QE
