vegnar
Hi guys , so I decided I'm going to buy a Hybrid Kit to cool my 980 Ti . I'm hoping anyone here can tell me how long are the hose and how thick is the Radiator+fan. Reason I ask because I have a Define R4 with the ND-14 Noctua Cooler so it might be limited to mounting it in front but looking at pictures the cable on the Hybrid Kit doesn't seem long. Thanks!
DirtySouthWookie
Re: Hybrid Kit owners , help please.
2015/07/26 20:20:52
I'm hearing the tubes are 14 inches long from the side of the card to the rads. Other sources say 16.
Erik
2015/07/26 23:52:19
Tubes are 400 mm/15.75 inches, the radiator's full specs are 152.5 mm/ 6 inches X 121 mm/ 4.76 inches X 27.5 mm/1.08 inches Fan will add an additional 25 mm/ 0.98 inches Total thickness for rad and fan will be 47.5 mm/ 1.89 inches
1Scotty1
2015/07/27 02:04:01
You decided to buy it? Good luck finding a store that actually has it in stock... :(
vegnar
2015/07/27 20:45:45
1Scotty1 You decided to buy it? Good luck finding a store that actually has it in stock... :(
Unfortunately I'm going the Ebay route if in 3 weeks I can't buy it from here or BHphoto, I have 3 weeks to return my G1 to Bhphoto so I'm going to play the waiting game but yes wished EVGA would ramp up production on these although that might mean the ebay scalpers will just have more stock for them to prevent us from buying them.
vegnar
2015/07/27 20:48:45
EVGATech_Erik Tubes are 400 mm/15.75 inches, the radiator's full specs are 152.5 mm/ 6 inches X 121 mm/ 4.76 inches X 27.5 mm/1.08 inches Fan will add an additional 25 mm/ 0.98 inches Total thickness for rad and fan will be 47.5 mm/ 1.89 inches
Thanks, this might prove difficult to mount up front .... I'm going to have to get rid of my Noctua ND-14 to be able to mount the hybrid on the rear, darn it doesn't come simple for me...
1Scotty1
2015/07/27 20:49:08
vegnar
Ebay? Wow, how much will that cost you?
vegnar
2015/07/27 21:27:35
1Scotty1
vegnar
The kits are selling for $210-$220, I'm wondering if I buy from EVGA $110+tax+ shipping = $130-$140?. So if I get desperate and get one for $210 then it's a $80 premium, trust me I want to buy from EVGA but they never have enough to sell before the ebayers grab them.
DirtySouthWookie
2015/07/28 00:26:58
If you're going to pay 220 per aio don't you think its prudent just to do a full custom loop. It's not hard and will yeild better results.
vegnar
2015/07/28 09:30:59
DirtySouthWookie If you're going to pay 220 per aio don't you think its prudent just to do a full custom loop. It's not hard and will yeild better results.
To be honest I would not know where to begin if I was going to do a full custom loop, I searched for "full custom loop kit" without much clarification. It would be cool but never looked into it, I kind of remember hearing is very expensive $500+ something I wasn't planning to do. In any case I'm not buying mutliple cards just hoping to get 1 Hybrid, I'm hoping I just get the cooler as I already have a reference Ti or if they have the card+kit then I would just sell my ti.
DirtySouthWookie
2015/07/30 17:53:37
Funny they came in stock after I ordered a $800 open loop lol. Been up for over 30 mins. I actually bought 2 then cancelled and kept my EKWB order. http://www.evga.com/Products/Product.aspx?pn=400-HY-0996-B1 I feel bad for the saps that paid 300 plus shipping through eBay..
post edited by DirtySouthWookie - 2015/07/30 17:57:04
un4givn85
2015/07/30 19:17:16
Kinda wish I had reference cards so I could use this.
Zuhl3156
- Ribbons : 34
2015/07/30 19:54:00
It looks like EVGA has them in stock now. I would stay far away from eBay.
Steve101kd7
2015/07/30 19:54:45
wow this is awesome it stayed in stock for a couple of hours last couple times it lasted a min tops
Zuhl3156
- Ribbons : 34
2015/07/31 04:11:21
- Ribbons : 115
2015/08/11 21:12:06
Zuhl3156 Still in stock.
Out of stock now.
