How to get rid of red led light from SoundBlaster Z----Liquid E-Tape $6
movieman
2014/07/19 08:15:37 (permalink)
I hate the fact that my SoundBlaster-Z has the red light that you cannot control. It is ok when I want to light my rig up with Red, but not any other colors.
Bend the lights back a little.
 Apply Liquid Tape
 5 coats of Liquid Tape..one more should do it
6 coats of Liquid Tape. No more light!! :) very happy
DONE
post edited by movieman - 2014/07/19 08:23:21
NZXT B550   AMD 5950X
EVGA 3080Ti Hydrocopper
WD Black 2TB NVME
Corsair 64GB (4 x 16GB)
Alienware AW3418DW 34" UW
Corsair HX 850          Corsair 5000X(white)
Windows 10               HEATWARE
5 Replies Related Threads
    • Ribbons : 115
    Re: How to get rid of red led light from SoundBlaster Z----Liquid E-Tape $6 2014/07/19 23:08:18 (permalink)
    That tutorial should be of help to others. Thanks.
                My Affiliate Code: 8WEQVXMCJL
     &nbsp
    xanderf
    • Ribbons : 36
    Re: How to get rid of red led light from SoundBlaster Z----Liquid E-Tape $6 2014/08/01 22:55:33 (permalink)
    I gotta say, that looks like a REALLY trivial LED to unsolder and replace.
    Have you thought about going down that path?  Swapping it out with a white/yellow/etc LED?
    schmorblatz
    Re: How to get rid of red led light from SoundBlaster Z----Liquid E-Tape $6 2014/08/02 16:37:07 (permalink)
    An other trick to shut down a LED : if wires are accessible, just short circuit them. This is the case here. A thin copper wire without insulation, wrapped around the pins. No risk, as the LED is fed through a polarization resistor that limits the current. Current will just grow by a few milliamps. (resistor is generally external, and rarely built in ; but it exists. Naturally, never short circuit a led with built in resistor !!!)
    why make it simple when it can be complicated ????
    rig 1 : Asus P9X79-E WS / i7 4930k / 3-way SLI EVGA 780ti / Quadro K2000 / watercooled / 3D Vision Surround / 3 x Samsung 2233RZ + HP ZR22W
    rig 2 : Asus P9X79 WS / i7 4930k / 2-way SLI 770 / aircooled / 3D Vision / Samsung 2233RZ + Samsung 2232BW + HP ZR22W
    rig 3, 4 5, etc. : uninteresting !
    movieman
    Re: How to get rid of red led light from SoundBlaster Z----Liquid E-Tape $6 2014/08/06 22:40:05 (permalink)
    schmorblatz
    I am not an electrician yet... :). This seemed to be the easiest way to me. Next time I will try your way.
    NZXT B550   AMD 5950X
    WD Black 2TB NVME
    Windows 10               HEATWARE
    Randolla
    Re: How to get rid of red led light from SoundBlaster Z----Liquid E-Tape $6 2014/08/07 14:38:05 (permalink)
    Does the liquid tape come in other colors?  Maybe it can be used to change the color to green or blue.
    Intel 5930K@ 4.3 Ghz
    ASUS Rampage 5 Extreme Motherboard
    EVGA GeForce 1080Ti SC
    Case Labs Merlin Full Tower case
    NZXT Kraken X61 Liquid CPU cooler
    32 Gbs G.Skill Ripjaws 4 DDR4 2666
    EVGA  Supernova P1200 PSU
    Acer Predator X34 Monitor
    Samsung 512 Gb XP941 M2 SSD
    HT Omega eClaro Soundcard[
