AnsweredHow to control evga 1070 sc's led?
xiayong0121
2016/11/02 13:05:27 (permalink)
I bought 1070 sc few days ago,and I can not control 1070sc'led with EVGA Precision XOC(V6.0.8)(also in 6.0.7),the "led"is greyed out.(please see picture below)
how to control the led?
pcmaster00
  • Ribbons : 49
Re: How to control evga 1070 sc's led? 2016/11/02 13:13:32 (permalink)
The GTX 1070 FTW cards are the only ones with controlable LEDs.  The regular ACX 3.0 and SC cards do not have that control.  You'll see on the last item of the features page of the tab of the GTX 1070 FTW, the description of:
Adjustable RGB LED
An adjustable RGB LED that can be controlled in EVGA PrecisionX OC
This is not on the Features page of the GTX 1070 SC.
post edited by pcmaster00 - 2016/11/02 13:21:25
EVGA!!! TAKE CARE OF MY MATES!!!!   Heatware
Antec Twelve Hundred, Corsair HX1000, GigaByte GA-Z77X-UP5 TH, Intel i7 3770k, 2x EVGA GTX770 2770-KR,
16GB Corsair Vengance CMZ16GX3M2A1600C9, SSD: 1x OCZ Vertex 3 120GB, 2x 2TB Seagate Barracuda LP,
All HDDs in trayless bays, 6x LG 24x DVD-RW drives, 3x Acer 22" V223W monitors
  • Ribbons : 122
Re: How to control evga 1070 sc's led? 2016/11/02 15:56:44 (permalink) ☼ Best Answerby xiayong0121 2016/11/03 01:36:11
You can't change the color on the 1070 sc. You should only be able to turn led on/off. Have you tried reinstalling the latest version of precision xoc? If reinstalling the latest version of precision xoc doesn't help get the led tab working again you can use the led visualizer from nvidia to turn the led on/off... http://international.download.nvidia.com/GFE/LEDViz/1.0.0.0/LEDVisualizer_v1.0.0.0.exe
xiayong0121
Re: How to control evga 1070 sc's led? 2016/11/03 01:40:04 (permalink)
yes,I have already tryed the lastest XOC and also know the led cannot be chaneged.
thanks for help .
bob16314
  • Ribbons : 204
Re: How to control evga 1070 sc's led? 2016/11/03 06:32:59 (permalink)
Welcome to the forums..LED Visualizer is included in most recent NVIDIA Driver packages up to about 373.06 and in GeForce Experience..The NvLedVisualizer.exe is tucked away in (for example) the C:\NVIDIA\DisplayDriver\373.06\Win10_64\International\LEDVisualizer folder..You can try it from there and see if/how it works for you..If it works it works, if it don't it don't.
You can snag the LED Visualizer from an older driver package since it's not included in new driver packages.
If your card supports any LED Visualizer functions, even with limited functionality, you should be good to go for what it offers..If not, it don't.
You can check in your current driver package (typically saved in C:\NVIDIA) unless it's been deleted somehow and see if it's there and if not or try the stand-alone one linked to above by Sajin or snag it out of another driver package and then you can delete the driver package if you want to..After you extract a driver package you can copy the LEDVisualizer folder from the driver package to wherever you want and make an NvLedVisualizer.exe shortcut to wherever want and see how all that works out..Precision XOC is still a work in progress, it seems..Just sayin'.
* Cooler Master NV-334 * ASUS P8Z77-V LE PLUS * Intel i7-2600K @ 5.0GHz * Corsair H80 * Seasonic M12II 750W * 4x4GB 2133MHz Patriot Viper Xtreme * EVGA GTX 760 SC * 2 x WD 500GB Caviar Black RAID 0 * Toshiba DT01ACA 500GB * Dual-boot Win7 Home Premium 64-bit/Win10 Home 64-bit *
"If it ain't broke, fix it untill it is"
Scarlet-Tech
  • Ribbons : 31
Re: How to control evga 1070 sc's led? 2016/11/03 07:11:10 (permalink)
Led visualizer is already in the drivers isn't it? C:/nvidia/*latest driver number or a previous driver" then led visualizer?
  • Ribbons : 122
Re: How to control evga 1070 sc's led? 2016/11/03 11:58:09 (permalink)
Scarlet-Tech
Nope.
Scarlet-Tech
  • Ribbons : 31
Re: How to control evga 1070 sc's led? 2016/11/03 12:05:34 (permalink)
Scarlet-Tech
Nope.
Why did they remove that? Why is Nvidia taking everything useful that they have out of the users hands?
I still have the same one linked that has been on my desktop for over a year. I still use it for the sli bridge occasionally.. Nvidia won't take that away lol.
  • Ribbons : 122
Re: How to control evga 1070 sc's led? 2016/11/03 12:10:19 (permalink)
Scarlet-Tech
Scarlet-Tech
Nope.
Looks like it's suppose to be added back at some point. Looks like you'll also need to install GFE to get it... https://www.reddit.com/r/...geforce_experience_30/
Scarlet-Tech
  • Ribbons : 31
Re: How to control evga 1070 sc's led? 2016/11/03 12:11:14 (permalink)
Ha, they won't trick me into that! I'm keeping the old one that works perfect!
bob16314
  • Ribbons : 204
Re: How to control evga 1070 sc's led? 2016/11/04 02:50:12 (permalink)
Scarlet-Tech
Yes..Try it if you want to and see if it works for you..Seems that LEDVisualizer can be run from within the driver package download (after extraction to C:\NVIDIA\*) or as a stand-alone application from the LEDVisualizer folder in driver version 363.06 and NVIDIA driver packages older than v363.06 in other packages in relatively recent history..The program opens for me, but error "Supported NVIDIA card not Found" occurs, of course..The driver or Visualizer installation should not be necessary, just run the NvLedVisualizer.exe from the driver package..Newer drivers require GeForce Experience 3.0 and a login from other BS for that feature to run LEDVisualizer..Any feedback on that?..Just going from what I've 'heard' from others here and there?
