Re:Home made Danger Den MC-TDX replacement Copper top
2011/07/14 02:41:41
is there by any chance that you can make a full cover wb for gtx480?
Intel 3930k @ Stock | XSPC Rasa RS360 WaterCooling | Evga x79 Classified | Mushkin 2x4gb 1600mhz 1.35v | EVGA 690GTX | CoolerMaster HAF-X | 2xMushkin Chronos 128gb Raid0 | HDD 2 TB | Antec HCP 1200w | 27" Samsung P2770FH | 24" BenQ G2420HDB | 32"LCD FullHD | W7 x64
nateman_doo
- Ribbons : 52
2011/07/14 15:46:06
I most certainly can. I just don't have the card.
2011/07/15 07:33:37
do you have your OWN cutter for these things? :O..
farthestkris
- Location: Crunching Location .......... Location Not Found
- Ribbons : 12
2011/07/15 07:41:47
^ yes he does.... i gots a Question. When can i get a Nickel CPU block?
nateman_doo
- Ribbons : 52
2011/07/15 07:45:50
IstBarP do you have your OWN cutter for these things? :O.. Yup. The machine in the video(s) is a hand made CNC milling machine that I built with mostly hand tools (except a drill press & bandsaw) in my basement.
nateman_doo
- Ribbons : 52
2011/07/15 07:47:11
farthestkris i gots a Question. When can i get a Nickel CPU block? Clarify, from anywhere or me? I don't nickel plate (yet)
2011/07/15 08:40:34
nateman_doo IstBarP do you have your OWN cutter for these things? :O.. Yup. The machine in the video(s) is a hand made CNC milling machine that I built with mostly hand tools (except a drill press & bandsaw) in my basement. sounds pretty amazing!!!
nateman_doo
- Ribbons : 52
2011/07/18 18:07:14
Hey, aj, you ever order your screws?? I finally finished construction of both of your blocks. Just prettying them up now.
2011/07/18 18:13:23
Yeah I ordered them a few days ago.
Gratuitous
2011/07/18 18:30:23
i have extra screws as well, they come in lots of 25. if anyone else needs some. only need 8 per set of blocks so i have extra.
“I built a castle in the swamp and it sunk. I built a second castle and it sunk too. I built a third castle and it burned down and then sunk. But the fourth castle, Ahhhh! That one stood.” —Monty Python and the Holy Grail
2011/07/18 18:34:14
Yeah I wish they would just come in the number you need, but then again I have a large set of them.
Gratuitous
2011/07/18 18:39:18
so, you know aj, you are required to post pics of the new blocks once you get them  as will I of course in my thread.
2011/07/18 18:46:37
You know I will be posting them. My excitement to get this is pretty high right now knowing that they are getting prettied up.
Gratuitous
2011/07/18 18:58:08
yah, lol. I designed the things and it looks like your getting them befor me  thats good though. I have pleanty of kinks to work out of my rig before i get everything mounted up properly. I need about 20 more lbs of copper machined before i will be finished
Gratuitous
2011/07/18 19:06:48
oh, btw. there is a spring (i will see if i can find the part number. it is a common one that comes with some of the stock coolers as well.) that will mount under the top to give a positive stop for tightening. you dont have to use a spring at all though if you are carefull not to over/under tighten. also if you use a spring, put a small plastic washer between it and the motherboard.
2011/07/18 19:40:24
Yeah I know what you are talking about...I am going to see what is in the kit that came with the Danger Den blocks. Part number would be nice.
Gratuitous
2011/07/20 03:20:47
yah, now that you mention it, i think it is the springs that come with the block that i used. I think you will need the little white washer that comes with the dd kit as well. the springs might not go all the way bottomed out. be carefull when cranking it down. a tip i use is mount it with modest pressure, then fire up the machine run some folding, or burn in, and do an eighth turn in cross pattern and watch the temps. you will see three or 4 degrees diferance depending on tightness on which corners. of course your tim and the flatness of the cpu come into play as well.
2011/07/20 04:09:44
Yeah the koolance CPU blocks have a similar spring mechanism that would act the same way.
2011/07/21 03:50:03
Looking good, can't wait to see the air cooled waterblock.
nateman_doo
- Ribbons : 52
2011/07/21 04:04:30
 Ta-da. btw, the screws came in lots of 10 from McMaster. Did you get black ones or something? That would prolly match better since the SR2 block has black screws. I was hoping someone would have gotten chrome screws to match nozzles but not a single person opted for them. *shrug*
2011/07/21 05:11:51
nateman_doo
- Ribbons : 52
2011/07/21 05:50:08
yea? I ordered the exact screw that G put down on the plans... OH CR@P... I got the 6-32 ones then?! I forgot we changed it to M3?! argh! What was the screw part # from McMaster? The original spec was 1.125" which I can go under being 25mm, or over being 30mm. I like getting longer screws, and just grind off what gets in the way. Here is what I found: Standard Thread— Black M3—Pitch: 0.5 mm 30 100 91290A130 $8.76 Type 316 Stainless Steel—DIN 912-A4 M3—Pitch: 0.5 mm 30 25 92290A126 $9.69
nateman_doo
- Ribbons : 52
2011/07/21 05:57:17
btw, I counterbored the heads for the .140 6-32 head. The measured depths of each counterbored are around .150 (about a hundredth of an inch here & there) The M3 screw head is 3mm (0.1181") That means the screws will be sunk down 0.04" below the surface.
EVGATech_DaveB
EVGA Tech Support
- Ribbons : 43
2011/07/21 06:23:40
Nateman, very nice work man! As always.
nateman_doo
- Ribbons : 52
2011/07/21 06:36:49
2011/07/21 07:42:18
Standard Thread— Black M3—Pitch: 0.5 mm 30 100 91290A130 $8.76 I got the stainless steel ones that were talked about before the change. I think though that the black will look better as you said with the overall theme as I am going with black matte finish compression fittings, although I am going to see what it looks like with some of the Koolance fittings. They are now ordered and shipped. Should have them by Friday.
post edited by ajohnes2 - 2011/07/21 07:48:46
atfrico
- Ribbons : 22
2011/07/21 08:00:59
Very nice block Nate. Clean, elegant and slick looking  I have a question, do you think it would make a difference on temps if the outside surface of the block is lapped to 2,000 or 5,000 grit?
Those who abuse power, are nothing but scumbags!  The challenge of power is how to use it and not abuse it. When you abuse it, it reverses on you and it hurts you.The abuse of power that seems to create the most unhappiness is when a person uses personal power to get ahead without regards to the welfare of others, people are obsessed with it. You can take a nice person and turn them into a slob, into an insane being, craving power, destroying anything that stands in their way.
nateman_doo
- Ribbons : 52
2011/07/21 08:10:53
I don't think it will matter in the least. It would look SEXY AS HELL to have a mirror finish on all that copper though.
atfrico
- Ribbons : 22
2011/07/21 08:20:52
nateman_doo
Oh yeah...  Do I smell a 10% discount for the idea...
2011/07/21 08:22:54
nateman_doo
Maybe that is coming in my next build   .
