AnsweredHelp with hooking up 1070 SLI to a EVGA BQ 750W Hybrid Modular 80+ PSU
CptKaboom
2016/10/25 23:50:03 (permalink)
Hi!
Just recieved my new build and I might have been a bit sloppy in my research...
I have two 1070`s which requires 2 x 8-pin Pci-e each.
Will this even be possible with the PSU i ordered? (see above)
It got pretty late last night before I came to all the cable routing so I might have overlooked something obvious here but all tips/thoughts will be much appreciated!
/Andreas
  • Ribbons : 122
Re: Help with hooking up 1070 SLI to a EVGA BQ 750W Hybrid Modular 80+ PSU 2016/10/25 23:56:55 (permalink) ☼ Best Answerby CptKaboom 2016/10/25 23:59:42
CptKaboom
Nope.
CptKaboom
Re: Help with hooking up 1070 SLI to a EVGA BQ 750W Hybrid Modular 80+ PSU 2016/10/26 00:00:48 (permalink)
Not even with some crazy adaptors??
Damn it...
Thanks for the quick reply!
  • Ribbons : 122
Re: Help with hooking up 1070 SLI to a EVGA BQ 750W Hybrid Modular 80+ PSU 2016/10/26 00:14:30 (permalink)
CptKaboom
Damn it...
Yeah, you could get it working if you bought a dual sata to 8-pin adapter.
CptKaboom
Re: Help with hooking up 1070 SLI to a EVGA BQ 750W Hybrid Modular 80+ PSU 2016/10/26 00:16:08 (permalink)
CptKaboom
Damn it...
Yeah, you could get it working if you bought some sata to 8-pin adapters.
I´ll probably just return it and get a GQ instead. Better to do it properly! :)
Thanks for your help!
  • Ribbons : 122
Re: Help with hooking up 1070 SLI to a EVGA BQ 750W Hybrid Modular 80+ PSU 2016/10/26 00:18:04 (permalink)
CptKaboom
CptKaboom
Damn it...
No problem.
