Re: Help with gtx 750 not showing up in device manager.
2016/05/04 13:58:13
If you can't disable the onboard outright, make sure to set the primary display adapter to either PCIe or PEG, depending on what the board has and make sure you are connecting your display directly to your GTX 750. Could be that the board is trying to enable both outputs which it likely wouldn't be able to support, thus the resource issue.
If the only way you can get a display is via the onboard then it likely isn't going to work and you'll want to verify if the card is indeed working in another system. Testing in another slot isn't going to be an option on that board either. Most LGA 775 boards will need to have the GPU in first PCIe slot.
