Help with GTX 550 Ti power supply connection pls
Mommy1395
2012/09/17 19:32:58 (permalink)
Help please, just bought new GTX 550Ti card and an HP Pavilion to put it and can not figure out how to connect power supply cord from graphics card to cpu.  Can anyone give me an idea where I find the empty slots to plus this in??  Sorry but am really stupid when it comes to this stuff sometimes.  thank you for any help :>)
19 Replies Related Threads
    Mole3
    Re:Help with GTX 550 Ti power supply connection pls 2012/09/17 19:48:29 (permalink)
    The card should have included some type of adapter for that... Do you know what kind of power supply? You need to make sure it has sufficient wattage, but more importantly, enough +12v amperage. Minimum recommended for the 550 Ti is 400w. But like I said, amperage on the +12v is very important too.
    MSI Z77A-G45 | Core i5 3570K | 8GB Patriot G2 DDR3 | Crucial M4 256GB SSD | EVGA GeForce GTX 670 SC+ 4GB | Cooler Master GX-750W PSU | Windows 10 Pro 64-bit
    Mommy1395
    Re:Help with GTX 550 Ti power supply connection pls 2012/09/17 19:56:54 (permalink)
    I bought an HP Pavilion p6-2114 PC where do I find what you need to know?
    maniacvvv
    • Ribbons : 165
    Re:Help with GTX 550 Ti power supply connection pls 2012/09/17 20:08:23 (permalink)
    maniacvvv
    • Ribbons : 165
    Re:Help with GTX 550 Ti power supply connection pls 2012/09/17 20:10:32 (permalink)
    Warning
    The HP Pavilion p6-2114 above unit has only a 300w powersupply.
    IMPORTANT:
    -->I would NOT attempt to run a GTX 550Ti with only a 300w OEM unit that has no 12v specs.
    post edited by maniacvvv - 2012/09/17 20:17:51
    Mommy1395
    Re:Help with GTX 550 Ti power supply connection pls 2012/09/17 20:26:34 (permalink)
    That is not the exact one but yes same power specs, the guy at Best Buy told us what to buy and even showed my son a image of where and how to put it in, just not how to plug the power supply cord in.  Did he not give us the right stuff??
    maniacvvv
    • Ribbons : 165
    Re:Help with GTX 550 Ti power supply connection pls 2012/09/17 20:38:55 (permalink)
    Mommy1395
    It is critical you give us the -exact- model number of your computer
    *If it really is a 1155 socket MB with a 300w PSU...
    Then you will need to BUY and install a better powersupply, to be able to run a 550Ti.
    Mommy1395
    Re:Help with GTX 550 Ti power supply connection pls 2012/09/17 20:47:20 (permalink)
    ok, this should be the link to our computer, a p6-2114 not the p6-2114d
    hope I did this right :>)
    maniacvvv
    • Ribbons : 165
    maniacvvv
    • Ribbons : 165
    Re:Help with GTX 550 Ti power supply connection pls 2012/09/17 20:55:45 (permalink)
    That still only has a 300w powersupply....
    A dual core Intel I3 2110
    Since that CPU is only a 65w draw, a 300w PSU "might" work for a 550Ti... but thats a big "might".
    It could just as likely have problems or cause the PSU to fail, in either case requiring a new powersupply.
    Since you are the "parent" buying this stuff, may I ask what is this computer to be used for?
    post edited by maniacvvv - 2012/09/17 20:59:34
    Mommy1395
    Re:Help with GTX 550 Ti power supply connection pls 2012/09/17 21:02:22 (permalink)
    Yes that is the one we bought, and I got it so son could play WOW and Guild Wars 2 ( he says on low settings??).  His laptop started for some reason giving hissies with IE, so we went looking to hp website and found what we were looking for with a p6-2200z series, but the rep at Best Buy told us that this one was better and on sale. so we went with what the guy told us , he said that he had some sort of degree in this stuff so we took his word
    maniacvvv
    • Ribbons : 165
    Re:Help with GTX 550 Ti power supply connection pls 2012/09/17 21:20:11 (permalink)
    Well....
    To hook up the videocard, use the power Adapter that came in the box with the card
    Each end (2) needs to be connected to a unused 4pin molex connector off the power supply. If you do not have 2 of these that are available, you will need to go to Radio Shack and get a Molex splitter.
    Be aware that if your son has videocard problems and/or the computer wont start, you will need to replace the powersupply with something like this http://www.newegg.com/Product/Product.aspx?Item=N82E16817371045 at a cost of between 30-$50
    I cannot say that the videocard is going to work, using only a 300w PSU. So just keep that in mind
    post edited by maniacvvv - 2012/09/17 21:31:38
    Mommy1395
    Re:Help with GTX 550 Ti power supply connection pls 2012/09/17 21:30:00 (permalink)
    the problem I am running into is I cant find any connectors to plug it into, where do I find them??the only plug that is inside the case and not connected to anything does not match the white ends on the plug that came with the graphics card.  Sorry I am being such a pita, but I have no clue what I am supposed to be doing here.  Thank you so much for all your help in this <3
    bob16314
    • Ribbons : 761
    Re:Help with GTX 550 Ti power supply connection pls 2012/09/17 21:32:01 (permalink)
    As stated above, the 550 Ti needs a 6-pin PCIe power connector plugged into it..There may/may not be one coming  from the power supply..If there is, just plug it into the 550 Ti..If there is not, you need to use the dual 4-pin molex to single 6-pin PCIe adapter that should have came with the 550 Ti (providing the power supply has 2 available 4-pin molex connectors that you can plug them into) or go buy one..If your power supply does not have the 6-pin PCIe connector or the 2 available 4-pin molex connectors, then you need to buy a power supply that does..A 500 watt should work fine and they're not that expensive.
    maniacvvv
    • Ribbons : 165
    Re:Help with GTX 550 Ti power supply connection pls 2012/09/17 21:37:35 (permalink)
    No problem, you came to the right place for help
    So you cannot find any of the 4pin molex connectors that are "free" to use?
    This is normal with low wattage OEM powersupplies, because of the low wattage there are only often only one or sometimes two of them...
    Look around carefully, to you see anything thats using the same kind of 4pin connector? Your just looking for the connector type.
    If you really cant find any of the 4pin molex connections, then you will NEED to replace the powersupply
    post edited by maniacvvv - 2012/09/17 21:41:15
    FattysGoneWild
    Re:Help with GTX 550 Ti power supply connection pls 2012/09/17 21:54:57 (permalink)
    For a start. Bad move going to Best Buy. They usually know nothing and prey on the non technical folks just to get that sale. I work and have owned many HP's systems. The current systems power supply wise do not offer molex connectors for power. They also stick in crappy ones unless you get the 460w or 600w versions. Those are on higher end models and good quality. You will need to replace the power supply. I suggest going with this one. http://www.newegg.com/Pro...x?Item=N82E16817139026 It is a good quality unit and perfect for that system.
    P.S.
    I have a brand new 600w power supply that HP sent me under warranty. I do not need it. Something else was wrong with my system at the time. I am sure we could work a deal out. I also have pics of it. PM if interested.
    post edited by FattysGoneWild - 2012/09/17 22:01:04
    HP Omen 880-160se custom ordered
    OS: Windows 10 64 bit
    MOBO: HP Tampa2
    CPU: Intel i7 8700k @4.8GHz
    RAM: 32GB DDR4 2400
    GPU: PNY XLR8 RTX 3080
    PSU: Delta 750w 80 Plus Platinum
    NVMe M.2 SSD: Samsung 512GB MZVLW512HMJP
    SSD: 250GB Samsung 860 EVO
    HDD: 2TB Seagate Barracuda ST2000DM001
    Sound: Logitech Z623 THX 2.1 Speakers
    Monitor: Dell S2716DG 2560x1440 @144Hz G-Sync calibrated with ColorMunki Display
    Keyboard: HP Omen 1100
    Mouse: HP Omen 600
    Mommy1395
    Re:Help with GTX 550 Ti power supply connection pls 2012/09/17 22:01:26 (permalink)
    Thank you so much for all your help, but I think we are gonna take this thing back to best buy in the am and tell them to either hook it up and not blow up the power supply or give a  new power supply that will work with this card that he told me would fit "No Problem".  Thank you so much for taking the time to try and help this stupid old lady (giggle), You all have a nice night
    FattysGoneWild
    Re:Help with GTX 550 Ti power supply connection pls 2012/09/17 22:06:24 (permalink)
    That might be best to take it back. Just a warning. Their prices are much higher and they are going to hit you with a install fee. That is not cheap either.
    MOBO: HP Tampa2
    RAM: 32GB DDR4 2400
    Mouse: HP Omen 600
    Mommy1395
    Re:Help with GTX 550 Ti power supply connection pls 2012/09/17 22:06:34 (permalink)
    Thank you so much, I am going to Best Buy in the am to see if they are going to do anything to straighten this mess out,  if they dont I will PM you tomorrow and see what we can work out if you still have it.  Thank you so much for the advice and the offer, I will let you know sometime tomorrow how we made out.
    Mole3
    Re:Help with GTX 550 Ti power supply connection pls 2012/09/18 19:18:05 (permalink)
    Glad you figured it out this far.
    In my experience, the sales people at Best Buy tend to not know much about PC stuff. I remember a long time ago, I was at Best Buy, and I was overhearing one of the sales people talking to this man looking for a TV Tuner card, and a graphics card. Back then, they had ATI and 3Dfx Voodoo cards that had TV tuners built in... Instead of showing the man those (on the rack right behind her), the sales girl sold him separately a TV Tuner card and a graphics card. The man could've saved a LOT of money just going with one of the 3dfx or ATI cards. I don't know if she didn't know about the 3dfx and ATI cards, or if she was just maximizing her commission. Either way, it reflected poorly on Best Buy IMO.
    If you've got a Fry's or Microcenter around where you live, I highly recommend shopping there instead. Not only are they more knowledged in PC hardware, but their prices are MUCH better than Best Buy, and they won't screw you over like used car salesmen.
    post edited by Mole3 - 2012/09/19 07:09:27
