Simba123
- Ribbons : 14
Re:Help me to pick the right parts to upgrade to a new rig.
2011/10/06 18:29:53
XrayMan Simba123 ok, so narrowing down your spec list (2600k & 3gb 580) MB: Evga P67 FTW m/b $ 280 or $ 250 (240 after mir) Graphics: Evga 3gb 580 classified $600 RAM: Gskill Ripjaws 2x4mb $52 or $104 for 16mb (Which you don't need for gaming) I picked these cause the coloring goes with the motherboard, and they are a good set of ram. CPU: i72600k $315 at newegg or $280 at microcenter (pickup only) PSU: Corsair AX1200 professional $280 DVD: Asus cd/dvd burner $21 <edit> CPU cooler: [link=../products/moreInfo.asp?pn=M020-00-000234&family=Peripherals&sw=22]Evga cooler [/link]$55 or better CM Hyper 212+ $27 You are at $1500 minimum and $1655 max before case and delivery. Start buttering up the missus for an $100-250 bucks!  I'll drive to Microcenter, and save a little money. Also, I have some Evga bucks to help pay for the video card/ motherboard. What do you think about this Ram?:> http://www.newegg.com/Product/Product.aspx?Item=N82E16820231431 waste of money. you'll never notice any difference in gaming, or anything else for that matter; apart from benching. Cases are as expensive as you want them to be. by limiting yourself to a top-mounted PSU, you eliminate 90% of the available cases. You can get a decent one for $130 odd, or you can spend a grand.
boredgunner
Over 9000!
- Ribbons : 78
2011/10/06 18:31:36
Actually simba, most cheap/basic cases still have top mounted PSUs. Especially the ones with the low profile expansion slots. Clearly those won't be enough for him though. You can still get an Ultra case for $20. Lian-Li was always pricey.
2011/10/06 18:57:43
maniacvvv
kram36
This gets you the GTX 590 you've always wanted, but slightly over your budget at $1,667.62 after EVGA $15 MIR. Just keep your Sony drive if you're not having issues with it.
EVGA 03G-P3-1596-AR GeForce GTX 590 (Fermi) Classified
http://www.newegg.com/Pro...x?Item=N82E16814130693
EVGA P67 SLI 130-SB-E675-KR LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Pro...x?Item=N82E16813188073
Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost)
http://www.newegg.com/Pro...x?Item=N82E16819115072
CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600
http://www.newegg.com/Pro...x?Item=N82E16820233144
CORSAIR Professional Series Gold AX1200 (CMPSU-1200AX) 1200W
http://www.newegg.com/Pro...x?Item=N82E16817139014
COOLER MASTER HAF X RC-942-KKN1
http://www.newegg.com/Pro...x?Item=N82E16811119225
I am going to go with Kram36's build, but with a few changes...
First off, lose the 590 (I'll explain later) thats + $750 I would add in http://www.newegg.com/Product/Product.aspx?Item=N82E16823239015 for $100 Thats $650 left for a videocard Then DO NOT BUY a Videocard, keep your 560 and either let your wife use the card she has now -or- you can PM me and I'll send you a good one for her at no charge Use the $1500 she will allow (in cash) and save your EVGA bucks to put on top of the $650... This means your up with the new system and a 560... with $650 and your EVGA bucks Then -wait- till after Christmas and see what price drops Kepler will bring for either one of topend Kep -or- dual 580's at a big savings over todays prices
@Maniacvvv, First of all, I don't need a new keyboard just yet. Not sure where that came from! LOL! Also, I want this 560 upgraded. Not saying its a bad card, but I just want a better one. Either the 580 or 590. I'm still up in the air on that, because the heat issues keep coming to mind when I think of 590. I will most likely sli later on.
My Affiliate Code: 8WEQVXMCJL
2011/10/06 19:03:57
Drerex
IMHO, I would wait and get a X79 board.
I would need more info on that board. I'm sure I could wait if I need to, just need to be some justification for waiting. What are the differences between the P67 and the X79¿ Things like that! Would I be happy and content with the P67¿
2011/10/06 19:13:11
Drerex
X79=that remains to be seen. pricing forecast would be around 1K for cpu/mobo/mem alone
2011/10/06 19:17:57
geek32
Drerex
I would need more info on that board. I'm sure I could wait if I need to, just need to be some justification for waiting. What are the differences between the P67 and the X79? Things like that! Would I be happy and content with the P67?
That's expensive. I'm surely not looking to give an arm and a leg for that.
Simba123
- Ribbons : 14
2011/10/06 19:30:42
boredgunner Actually simba, most cheap/basic cases still have top mounted PSUs. Especially the ones with the low profile expansion slots. Clearly those won't be enough for him though. You can still get an Ultra case for $20. Lian-Li was always pricey. well you could, but you wouldn't be able to fit an EATX board into it, let alone a decent cooler, or have any form of cable management slots etc. I have no idea how much that PSU weighs(and the corsair site doesn't tell you), but if it's under 6 kilos I'd be surprised. There's no way I'd want that on the top of a full tower. You'd just have to bump it and the thing would fall over, unless you get a case with those fold out legs that stabilize it. Personally I think the bottom is the best place for a PSU. stick a filter on it, have it suck cool air from under the case so it doesn't screw your airflow and take air away from the graphics card/s plus the weight on the bottom keeps the unit stable. Only time I would recommend it is if the case is going to be stuck on a shag pile carpet or the client has some very furry animals. You can get magnetic filters that are easy to remove/clean/replace now as well (I have a kit for my rig and it's great) Each to there own though, it's his choice.
2011/10/06 19:40:50
Simba123
boredgunner
If I decide to get the i7 2600K at Microcenter, when I go there, I'll look at the cases in person, and get a feel of what the 2 different styles of PSU placements the cases have. Probably would be easier.
RainStryke
- Ribbons : 40
2011/10/06 19:51:50
I would highly suggest getting the GTX 580 classified for your video card. Also, I know you want a 1200w PSU, but there is no way your system with a i7 2600K set-up will even need more than about 450w with a single card set-up. Source: http://www.guru3d.com/article/evga-geforce-gtx-580-classified-review/6 They are still using that i7 975 @ 1.35v (A lot more power than a i7 2600K requires) That GTX 580 classified would have you covered on ANY game @ 1080p. With that, you could use the Kingwin LZP-550 (That can even run 2 GTX 560Ti's in SLI without a problem.) You probably won't want to go this route, but figured i'd toss that out there.
Intel i7 4790K - Corsair H90 - MSI Z87 MPOWER MAX AC - MSI GTX 980 (81.7% ASIC) - 16GB G.Skill 2400MHz - Seasonic X-1250 - Crucial MX100 512GB - Corsair Carbide 500R EVGA Affiliate Code: S27QNQME0X
2011/10/06 20:24:25
RainStryke
I was just reading about that card after reading your post. The specs on that card are awesome. The only con with that card is that there is no HDMI connection on the card. I don't understand why that was left out.
Simba123
- Ribbons : 14
2011/10/07 01:32:08
XrayMan RainStryke I would highly suggest getting the GTX 580 classified for your video card. I was just reading about that card after reading your post. The specs on that card are awesome. The only con with that card is that there is no HDMI connection on the card. I don't understand why that was left out. that's the card I included in the system I posted- well the 3gb version. pretty sure it comes with a DVI-HDMI converter, if not, just buy one for 10 bucks at microcenter. Cases are an individual thing, if you do go purchase the AX1200, remember it is a bit longer than a standard PSU, which may make life difficult mounting it in a top position - something to keep in mind.
2011/10/07 04:36:00
the 2600k is on sale at newegg 15.00 off for Columbus day sale
boredgunner
Over 9000!
- Ribbons : 78
2011/10/07 09:40:09
Simba123 boredgunner Actually simba, most cheap/basic cases still have top mounted PSUs. Especially the ones with the low profile expansion slots. Clearly those won't be enough for him though. You can still get an Ultra case for $20. Lian-Li was always pricey. well you could, but you wouldn't be able to fit an EATX board into it, let alone a decent cooler, or have any form of cable management slots etc. I have no idea how much that PSU weighs(and the corsair site doesn't tell you), but if it's under 6 kilos I'd be surprised. There's no way I'd want that on the top of a full tower. You'd just have to bump it and the thing would fall over, unless you get a case with those fold out legs that stabilize it. Personally I think the bottom is the best place for a PSU. stick a filter on it, have it suck cool air from under the case so it doesn't screw your airflow and take air away from the graphics card/s plus the weight on the bottom keeps the unit stable. Only time I would recommend it is if the case is going to be stuck on a shag pile carpet or the client has some very furry animals. You can get magnetic filters that are easy to remove/clean/replace now as well (I have a kit for my rig and it's great) Each to there own though, it's his choice. The bolded part is false. I have a top mounted PSU in my CM ATCS 840, which is roughly the same size as the PC-A70F/PC-A71F. I have a Megahalems with a 25mm shroud and 120mm x 38mm fan on it, and I'd be able to fit push/pull if I didn't have a tall GPU VRM cooler. No cable management holes are blocked. Look at my mods rigs for cable management. No wires sticking out really, everything is routed. I'd be able to fit an E-ATX board easily, since it's just wider than ATX. My case also comes with a metal bar that goes under the PSU (in the top mount) for added support. I would assume that the Lian-Lis come with something like this. You're right about the PSU having better airflow on the bottom, if the case's feet are not too short and there is a vent on the bottom. However, for air cooling, top mounted PSU wins in my book so that we can have extra bottom intake fans, blowing air straight to our GPU(s). I make sure that I buy a PSU that can handle some heat.
post edited by boredgunner - 2011/10/07 10:33:49
lehpron
Regular Guy
- Ribbons : 186
2011/10/07 16:19:35
geek32 X79=that remains to be seen. pricing forecast would be around 1K for cpu/mobo/mem alone That's expensive. I'm surely not looking to give an arm and a leg for that. The cost of the i7-2600K + Z68 FTW + 2x4GB will be very close to i7-3820 + X79 + 4x4GB. The CPU performance might be similar because both are quads with HT and might even overclock to the same levels, the advantage is the 40 lanes of PCIe, 10MB L3 cache, quad-channel DDR3 and 6-core upgrade options*. We know the i7-2600K has the unlocked multi to 57x, and while the 3820 is locked to a maximum of 36x, it has a "CPU ratio" multiplier option of 1.0 (default), 1.25 and 1.66. Enabled, your equivalent multiplier rises to 36x, 45x or 60x. * There was a thread somewhere where someone was able to peer into the microcode of their BIOS and reveal future support for an unknown LGA1155 6-core option that eventually would come to mainstream; but that could be at least Ivy Bridge circa April 2012. Intel will try to milk 6-cores in LGA2011 first.
2011/10/07 21:35:42
Just wanted to thank everyone for your great comments, and insight, in building a new rig. There is just one last thing that I need more help on, and that's the Ram. I know I want the maximum 16gb to go in a Motherboard. I want very good Ram, not just mediocre Ram. I want the, how do I say this? I want Ram that is high quality, and very fast. Like the Corsair Dominators were in their day. I hope you guys know what I'm trying to say!
Simba123
- Ribbons : 14
2011/10/08 16:08:43
With a 2600k, the most stable and easiest to set up is 1866 Mhz ram. Anything over that is a PITA, not too mention runs the risk of damaging the IMC, which is only rated to 1333. As for brand, pick you choice,as long as you don't buy ultra cheap rubbish, it all rolls out of the same factory. Corsair and Gskills seem to be the most popular brands. Gskill Ripjaws 1866Mhz at 1.5v Cas9 on special for $65 for 2x4gb
farthestkris
- Location: Crunching Location .......... Location Not Found
- Ribbons : 12
2011/10/08 16:18:40
XrayMan STEVEBABCOCK2002 Evga 580 - 3gig ( because a 1.5 gig minimum has been fast approaching on video cards lately, even on single monitors ) I think your the only one so far who thinks that the 3gb card would be better with only one monitor. ;) Considering BF3 has makes my 580 1.5's vram max out. im with steve on this...
boredgunner
Over 9000!
- Ribbons : 78
2011/10/08 16:44:41
If BF3 is on your list of games to play, get the 3GB card. With my GTX 480 I see my VRAM usage at just under 1500MB most of the time.
2011/10/08 17:40:21
2011/10/08 20:37:30
Ok, I have bought the following so far:> CPU: i7 2600k @ Microcenter $279 Memory: Corsair Vengeance DDR3 16GB 1600MHz Corsair VENGEAN CMZ16GX3M4A1600C9 (4x4) @Frys $89.99 minus $10 rebate = $79.99 When I was at Microcenter to get the 2600k, the guy said if I'm getting the P67, that I'm going to need the case that's bigger, since that Motherboard is bigger. He showed me the Half X, and the 800D. I noticed the prices were pretty high on those cases, and told him I would have to think about it. So I didn't get a case yet. As for the Video card. I haven't decided yet if I want to buy another 560ti for sli, get a 580 SC, or get a 580 3gb. I'm leaning more towards the 580 3gb if I can afford it.
2011/10/09 00:38:43
2011/10/09 00:48:46
Second if you can afford it.
2011/10/09 00:59:34
Simba123
- Ribbons : 14
2011/10/09 02:38:53
HAF x is better I've read some amazing things about the 800D. pretty pricey though.
boredgunner
Over 9000!
- Ribbons : 78
2011/10/09 09:02:38
800D has virtually no airflow, and despite the size, you'd need to de-rivet the bottom HDD cage and make ventilation in order to use a second radiator internally (larger than 120mm/140mm) in conjunction with a top 360mm radiator. The Obsidian series seem completely worthless to me. They're pricey and still made of sheet metal (save the aluminum faceplate) with plastic tool free locks, plus it lacks the things I mentioned above.
2011/10/09 13:21:45
boredgunner
Thanks for the info. Can save some money by not buying that 800D. I will get the COOLER MASTER HAF X RC-942-KKN1. I'll be looking for a sale on it. Also, I'm waiting for a sale on the Corsair 1200AX. I'll be getting that PSU, most likely.
boredgunner
Over 9000!
- Ribbons : 78
2011/10/09 13:28:22
Uh oh, I forgot to answer your other question. Comparing the HAF 932 and HAF-X, the X adds two hot swap bays, dust filters (behind 5.25" drive bay covers, behind front fan vent, on side fan vent, and on the top), 200mm side fan instead of 230mm (although blade length and performance is identical), a side duct for the 200mm fan, USB 3.0 support, a VGA support bracket, GPU air duct (HAF 932 Advanced has this), and a little box to hide PSU cables. It might also be worth asking if they get the Storm Trooper in stock.
2011/10/09 14:01:28
boredgunner
I'll look into the Storm Trooper also. As another option. Thanks again! :)
2011/10/09 15:26:45
Blizzie
SR2 is not worth it for a gaming rig for your purposes.
X58 is outdated and surpassed by Sandy Bridge. P55 was a good choice before, but for your budget it has no place.
It's sad that my X58 is outdated!
2011/10/09 16:32:54
boredgunner
I checked it out, but it's too tall. Plus there's no hard drive indicator light. I want that feature. So 2 minuses. Otherwise it looks pretty good.
