acdcfan1283
Hey guys. Im currently a first time user of overclocking, and while I have to say my setup is pretty stable, I do experience occasionally and very randomly a blue screen. My setup in terms of hardware and settings in bios are as follows: EVGA x58 3-way SLI Mobo Intel I7 920 Corsair dominator 3x2 gb ram 8-8-8-24 Corsair liquid cooled cpu cooler EVGA gtx 285 2 gb EVGA 9600 GT ded. physx card 2 60 gb ssd set in raid 0 & 1 tb hd 1000w corsair psu My clock settings are as follows: Dummy OC-Disabled Extra cooling-disabled Mem features: Freq-1067 (2:8) Targ:1306 mhz 8-8-8-24 Voltage w.o v-droop cpu-1.26875 cpu VTT- +100 mV CPU pll vcore-audo Dimm-1.650 dimm dq vref-+0mb CPU clock ratio-20x cpu host frequency-163 Target cpu freq-3430mhx (163x21) Target memory-1306 mhz If anyone can give me some support I'd greatly appreciate it, thanks!
Fiius
- Ribbons : 25
Re:Help! Not sure why my system's crashing (Bluescreen) (and how to determine the problem)
2010/09/21 15:36:20
Blue screen codes? In all NT Kernel Windows versions, BSoD codes can be found in the Event Viewer. Right-click My Computer > Manage > Event Viewer > This is where things differ | In WinXP its under System | In Vista and Win7 its under Windows Logs > System It should say STOP ERROR or something similar and have a white exclamation in a red circle with a priority of critical. Please post the entire contents of the event. ~Fus
"Abyss v2" | Gigabyte GA-Z77MX-D3H | Core i5 3570k w/ XSPC Raystorm Waterblock | Corsair AX-650 | | 32GB (4x8GB) G.Skill RipJaws X PC3-1600 10-10-10-30 (BXL) | | EVGA GTX 670 w/ Heatkiller LT 13105 + Backplate | Crucial M4 240GB SSD | 2x HGST 4TB | | Fractal Design Arc Mini | 2x PULL AP-15s on Swiftech MCR240 | D5 w/ Koolance COV-PMP450A Top | | Win7 x64 | 2x Dell UltraSharp 2408WFPb | Dell UltraSharp 2407 WFPb |
owcraftsman
- Ribbons : 57
2010/09/21 17:00:37
Is your memory rated to run at 1300 or above? have you tried bumping vcore or CPU VTT That usually fixes BSOD caused by unstable bios settings IE: stop 0x00000101 or 0x00000124 also check your bios to see if you are close to the below settings CPU PLL 1.8v IOH 1.225 IOH/ICH 1.6 ICH 1.15
Phanteks Eclipse P400: | MSI Z170A G7 | 6700k 4.7x 1.345v H110iGTX | G.Skill F4-3000C15D-16GVR |2x EVGA 980 TI SC ACX in SLI | Samsung 950 Pro M.2 OS | WD2003FZEX Data | Corsair RM750i Phanteks Enthoo Luxe: MSI Z87-G45 Gaming v1.9 bios | 4770k 43x1.24v XSPC Raystorm | G.Skill TridentX2133C9 2x8-16GB | MSI R9-290x Kyrographics Hawaii w/Active Backplate | 2x 250gb 840 EVO Raid-0 OS | WD20003FZEX (data) | Corsair HX850 Phanteks Enthoo Primo: | MSI Z97 Gaming 7 | 4790k 48x 1.254v EK-EVO | G.Skill TridentX2400C9 2x8-16GB | 2x Sapphire R9-290x ref (hynix) CF EK block Backplate & serial bridge | 2x 840 Pro Raid-0 OS | WD20003FZEX (data) | EVGA SuperNova 1000 G2
acdcfan1283
2010/09/22 18:42:35
Ok, so I think i found a general set of "errors" in there. this is what comes up: Performance power management features on processor 1 in group 0 are disabled due to a firmware problem. Check with the computer manufacturer for updated firmware. the only thing that varies in them is the # in "processor 1" (varies from 0-7 I believe.) What's the cause of this? Thanks
acdcfan1283
2010/09/22 18:44:00
- <Event xmlns=" http://schemas.microsoft....n/2004/08/events/event"> - <System> <Provider Name=" Microsoft-Windows-Kernel-Power" Guid=" {331C3B3A-2005-44C2-AC5E-77220C37D6B4}" /> <EventID>41</EventID> <Version>2</Version> <Level>1</Level> <Task>63</Task> <Opcode>0</Opcode> <Keywords>0x8000000000000002</Keywords> <TimeCreated SystemTime=" 2010-09-11T03:05:46.953125000Z" /> <EventRecordID>34154</EventRecordID> <Correlation /> <Execution ProcessID=" 4" ThreadID=" 8" /> <Channel>System</Channel> <Computer>Supacomputa</Computer> <Security UserID=" S-1-5-18" /> </System> - <EventData> <Data Name=" BugcheckCode">30</Data> <Data Name=" BugcheckParameter1">0xffffffffc0000005</Data> <Data Name=" BugcheckParameter2">0x0</Data> <Data Name=" BugcheckParameter3">0x0</Data> <Data Name=" BugcheckParameter4">0x0</Data> <Data Name=" SleepInProgress">false</Data> <Data Name=" PowerButtonTimestamp">0</Data> </EventData> </Event>
acdcfan1283
2010/09/22 18:45:01
owcraftsman Is your memory rated to run at 1300 or above? have you tried bumping vcore or CPU VTT That usually fixes BSOD caused by unstable bios settings IE: stop 0x00000101 or 0x00000124 also check your bios to see if you are close to the below settings CPU PLL 1.8v IOH 1.225 IOH/ICH 1.6 ICH 1.15 the memory is rated to 1600 mhz, so that shouldnt be the issue. Ill check those settings as well and post back shortly
acdcfan1283
2010/09/22 18:49:13
here were my settings: IOH-Auto @ 1.100 IOH/ICH-Auto @ 1.500 ICH-Auto @ 1.050
owcraftsman
- Ribbons : 57
2010/09/22 19:04:26
Try 1.26875 vcore +125 VTT 1.8 PLL CPU PLL 1.8v IOH 1.225 IOH/ICH 1.6 ICH 1.15 while we wait and see what Fiius has to say
donwayne
2010/09/22 21:08:57
I was actually going to ask the same exact question. I am going to post a new thread specific to mine cause I am not entirely sure what some of those numbers are haha...
NZXT Gamma Classic series Black Steel EVGA GTX 460 768MB MSI 870-G45 AM3 G-Skill Ripjaw Series 4gb DDR3-1600 Mhz AMD Phenom II X-6 1055t @ 3.6 Thermaltake 850-w TR2 RX - Black Widow 40GB Intel SSD 320GB WD 7200 RPM HDD
Fiius
- Ribbons : 25
2010/09/23 09:26:07
Alright - BSoD code is 0x30 which is SET_OF_INVALID_CONTEXT. Lets take a look at the BSoD Parameters; Parameter 1 - New Stack Pointer location - 0xffffffffc0000005 - Hex address of 18,446,744,072,635,809,797 (18 exabytes, the limit of 64bit memory addressing) Parameter 2 - Old Stack Pointer location - 0x0 - I'm not sure what would be a good value here, since I'm not a programmer, but given that this is the start of memory addresses and the 1st parameter is the end of the memory addresses, its not good. Parameter 3 - Trap Frame Address - 0x0 - If I understand this correctly. when a processor gets an interrupt, it sticks the current instructions into a trap frame and works on the interrupt. When its done with the interrupt, it reads the trap frame and starts where it left off at. Parameter 4 - Reserved (0x0) - 0x0 - Expected value. Another important key is up top of that BSoD entry - <Provider Name="Microsoft-Windows-Kernel-Power" Guid="{331C3B3A-2005-44C2-AC5E-77220C37D6B4}" /> <EventID>41</EventID>
It means that whatever is just before the BSoD entry (~5 or so entry range) could be a contributing factor to why the computer BSoD'd. Given the hex ranges and the BSoD code itself, you are looking at a driver or bit-flipping in RAM. Perhaps try loosening the timings on your RAM or lowering the speed down 100MHz. This, coupled with the slight voltage increase, should rule out or point out if its a RAM problem. If you are still having problems after adjusting the RAM, we start on drivers next. As for your general errors regarding performance power management features - it may be showing up if you disabled C1E SpeedStep or whatever Intel calls their power-saving settings in BIOS nowadays. To make it go away, change your Power Profile from Balanced to Performance. ~Fus
acdcfan1283
2010/09/26 11:19:21
Ok guys, Im going to give all of your suggestions a shot and see what happens. If it happens again, I'll come back. Is there a recommended program I can use to test it to make sure that it wont crash? Thanks
acdcfan1283
2010/10/07 12:57:21
Update: to sort of start off fresh, I set my entire bios configs back to default, so my system is no longer overclocked. Problem is...my system keeps crashing! It'll say something about win32.sys (or sks I didn't catch it fast enough) and it'll blue screen and restart. What could it be?
Fiius
- Ribbons : 25
2010/10/07 16:00:03
Well, lets fix the restart problem first. Reboot your computer and after BIOS loads, start tapping the F8 key. You will see a list of options, starting with "Safe Mode"... there should be an option towards the half-way or bottom that says something like "Disable Automatic Restart". When the BSOD happens again, write down all of the information listed or use the Event Viewer like above and copy/paste so we can take a look. ~Fus
acdcfan1283
2010/10/13 15:25:53
Ok, finally got it to show me the screen! Here's the read out, word for word: A problem has been detected and Windows has been shut down to prevent damage to your computer. If this is the first time you've seen this stop error screen, restart your computer. If this screen appears again, follow these steps: Disable or uninstall any anti-virous, disk defragmentation or backup utilities. Check your hard drive configuration, and check for any updated drives. Run chkdsk /F to check for hard drive corruption, and then restart your computer. Technical information: *** STOP: 0x00000024 (0x00000000001904FB, 0xFFFFF8800E861848, 0XFFFFF8800E8610B0, 0XFFFFF88001424A30) *** ntfs.sys-ADdress FFFFF88001424A30 base at FFFFF880014160000, DateStamp 4a5bc14f did a crash dump blah blah blah What gives?I know my "F:" drive is a daemon tools drive, but i cant figure out what the problem is
2010/10/13 21:06:22
Hmm I used to get 0x24 codes when I started overclocking and it stumped me too. I looked it up and it's usually a hard drive problem. Open up command prompt as an administrator (start button>cmd>right click>run as admin) and then type "chkdsk" in. After that completes try "sfc/scannow". Neither My hard drive nor my operating system showed corruption with these utilities but for some reason it stopped the blue screen. You may also want to back down your PCI-E if you have it overclocked (above 100).
Intel Core i7 3930k@4.5GHz|Asus Rampage IV Formula|Corsair HX1050|2xEVGA GTX 670 FTW|G.Skill 4x4GB Ripjaws X|Cooler Master HAF 932|Corsair H100|Windows 7 64 Bit|WD Caviar Black 750GB|Intel 520 120GB|BenQ XL2420T|Logitech G9x|CM Trigger Check out my Beginner's Troubleshooting Guide here if you are stuck and don't know where to begin! Use my Affiliate Code 81QCIG3SZU when you register a new product you bought!
acdcfan1283
2010/10/19 05:34:09
So I tried this...Im still getting error codes. At this point Im ready to just do a clean wipe/install on my computer. Any other suggestions?
owcraftsman
- Ribbons : 57
2010/10/19 07:11:12
A quick way to rule out your OS, it's drivers and hardware all at the same time is to run an alternate OS. There are many live disk you can boot to out there primarily used by tech's to trouble shoot system with problems such as yours. I use the UBCD once you get it burned to disc and boot to it run a CPU stress test and then a memory stress test even a hard drive test. If the system runs fine then you have ruled out hardware if it bsod's well then we have a failing component and you will need to, by process of elimination, find out which piece of hardware it is. I hope this helps and GOOD LUCK!
pbonica
2010/10/19 17:31:23
Here is a thought ...... Something to noodle on.... If your speedstep is disabled and the power manamgment kicks wouldn't it also have to manipulate ram speeds as well . If you had overclocked to the limits of your ram , and power managment tries to kick down cpu and ram might it cause the same Blue screen issues. Given some of the stop screen and BSOD errors pointed out. It may be contributing. Maybe some one here knows a little bit more on how power managment changes CPU power and wether it manipulates ram speeds and timmings. Also I have set my system to max perfomrmance and I can not stop the event log errors however I am not overclocked. Phil
acdcfan1283
2010/10/21 08:48:04
owcraftsman A quick way to rule out your OS, it's drivers and hardware all at the same time is to run an alternate OS. There are many live disk you can boot to out there primarily used by tech's to trouble shoot system with problems such as yours. I use the UBCD once you get it burned to disc and boot to it run a CPU stress test and then a memory stress test even a hard drive test. If the system runs fine then you have ruled out hardware if it bsod's well then we have a failing component and you will need to, by process of elimination, find out which piece of hardware it is. I hope this helps and GOOD LUCK! Im going to give this a try. Will let you know what I come up with. Thanks!
owcraftsman
- Ribbons : 57
2010/10/22 21:11:38
