kidaus
hello i have a graphics card EVGA GTX 480 015-P3-1480-AR buy in Indonesia My problem gtx 480 idle temp 68-71C is too hot in the auto fan,default clock now after a year of use, I've replaced the TIM on the gtx 480 using Noctua but the result remained the same most down 2-3c at the first purchase only 50-55C temperature at idle I use corsair obsidian 800D case any solution for my problem..
post edited by kidaus - 2012/03/13 15:20:48
random_matt
Re:Help My EVGA GTX 480 Temperature Very Hot
2012/03/13 15:44:01
That is hotter than usual, mine idles at 37c and load is about 77c-78c.
Corsair 5000D Airflow | EVGA 1000 G6 | EVGA X570 FTW | Ryzen 5800X | EVGA 360 CLC | Corsair 4000MHz 32GB| Corsair MP600 2TB | EVGA 3080 Ti FTW Hybrid | Alienware AW2721D | Windows 11
phamtantai
2012/03/13 16:38:55
U could take the card out and blow some air in it to clean off any dust. Do you have good wiring? look around your case to see if anything wiring or "thing" that could block the air flow.
wdflyer
- Ribbons : 24
2012/03/13 16:44:22
How good is your airflow in that case?, any cables in the way? If you are in a dusty environment, you should definitely make sure there no dust accumulating in your card. How long ago did you replace your TIM?, is it possible that it may be on incorrectly and need to be re-applied?
Gizmo: Asus MVF - i7-3770k - Corsair H100 - 32GB G.Skill 2133MHz - Radeon 7970 Two Kingston HyperX 120GB SSDs in R0 - Two 1TB WD Black in R0 - AX1200 - Thermaltake A71
Kids Rig: EVGA X58 Classified3 - i7 950 - Corsair H100 - 12GB G.Skill 1866MHz - Radeon 7970 - 240GB RevoDrivex2 1TB WD Black - Seasonic 1000w Platinum - CM HAF 912
techsoldier
2012/03/13 18:47:14
Followed by the suggestions above I'd think about adjusting the fan profile so that the fans cool a little more instead of using the "auto" setting.
_MatthewH
2012/03/13 18:55:26
What temps do you get under load?
kidaus
2012/03/14 02:36:28
random_matt That is hotter than usual, mine idles at 37c and load is about 77c-78c. oh that's very good first buy my gtx 480 only 50-55C temp at idle auto fan My room did not use the Air Conditioner wdflyer How good is your airflow in that case?, any cables in the way? If you are in a dusty environment, you should definitely make sure there no dust accumulating in your card. How long ago did you replace your TIM?, is it possible that it may be on incorrectly and need to be re-applied? airflow in my case very well on the corsair 800D Cable management is also good there is no dust on my GTX480 cleaned every 2 months by opening the top cover gtx 480 I replaced the TIM a month ago and until now the results are still same EVGA_MatthewH What temps do you get under load? benchmark fumark or msi kombuster at full load temperature can be up to 95-99c 90% fan very hot and noisy
random_matt
2012/03/14 16:04:01
Max allowed is 105c, however, the idle temps are not very comforting.
Drred989
2012/03/15 19:58:11
Do you have a fan blowing air towards your gtx 480? if you dont ,then you could place one, helps quite abit on temps
tinmann
2012/03/19 00:52:23
Looks like your default fan speed is set at 44%. Set it to 75-80% and see if that makes a difference. And how many fans do you have in the case? I have a Corsair 800D and SLI GTX 480's and right now I'm idling @ 41 and 49 degrees Celsius with 2 monitors @ 78% fan speed. How close are the 2 cards spaced apart?
Corsair 540 Air/ Silver Asus Rampage V Extreme X99 Intel Core i7 5820K G.Skill Ripjaws 4 Series DDR4-3000 16Gbs Corsair Hydro Series H110i GT Seasonic Platinum-1200w PSU MSI GTX 980 Ti Gamer 6G SLI Crucial BX100 500Gb SSD Corsair Vengeance 2100 7.1 Headset Logitech G502 Proteus Core Dell U3415W 34" Curved 3440x1440 Monitor
hoserx
2012/03/19 04:52:24
the 800d isnt necessarily the best case for air-cooling gpus. you'll want to add a fan or two in front of the card, pushing air backwards towards the exhaust.
Asus Rampage IV Formula x79/ Core i7 3820 /16gb G Skill ddr3-2133mhz / 2x EVGA GTX 680 / Intel X-25m 80gb G2 + 120gb G2 / Corsair Force GT 120gb /WD Caviar black 1TB /WD Caviar green 500gb /Sound Blaster X-fi titanium fatal1ty / Corsair AX1200 /NZXT Switch 810 (white)/Corsair H100/ HP ZR30W
kidaus
2012/03/20 19:29:41
random_matt
Drred989 really is not very comforting for me too Do you have a fan blowing air towards your gtx 480? if you dont ,then you could place one, helps quite abit on temps
have never tried but placing it rather difficult tinmann Looks like your default fan speed is set at 44%. Set it to 75-80% and see if that makes a difference. And how many fans do you have in the case? I have a Corsair 800D and SLI GTX 480's and right now I'm idling @ 41 and 49 degrees Celsius with 2 monitors @ 78% fan speed. How close are the 2 cards spaced apart? I set auto fan and that was enough so that not too noisy I used 3x120mm fan on top, below 1 x 140mm,in addition to 1x140mm 1x140mm 1x120mm for for cooling the hard drive hoserx the 800d isnt necessarily the best case for air-cooling gpus. you'll want to add a fan or two in front of the card, pushing air backwards towards the exhaust. have never tried well 800D is the best air flow case I plan to RMA to EVGA distributor in my country but the distributor said it must be taken to vga EVGA taiwan but that I worry about whether the stock gtx 480 still exist EVGA distributor in my country say that the gtx 480 has no stock / EOL
tinmann
2012/03/20 21:14:34
How cool is the room temperature? If the room temp is over say 23 degrees Celsius then you going to have a hard time keeping the card in the 40's and 50's. I keep my room temperature 72-74 degrees Fahrenheit and my card idles in the 40's That's why I'm going to a custom loop.
hoserx
2012/03/21 02:51:53
the 800d is far from the best air-flow case..........Sorry. It's a fantastic monolith that works great for liquid cooling but the airflow is not among the top.
