Having some issues with power switching.
lino4
2011/08/02 09:42:57 (permalink)
I have a GTX 570 and it doesn't downclock when idle anymore. I thought this was due to adding a second monitor, but when I disable my extra monitor the issue is still there. My power settings in the nvidia control panel are set to adaptive, and as I mentioned earlier, it was working when I got the card.
Other specs for my system include:
AMD Phenom II 1100XT
8GB DDR 3 RAM
ASUS M4A88T-V Evo/USB3
Geforce GTX 570
Corsair 650W
2 HDDs, one 640GB and the other 500GB
I have the latest Nvidia driver as well, maybe I should try  one of the betas?
EDIT: Actually it does downclock without the second monitor. So it doesn't downclock with dual monitors. Are there any known fixes or workarounds for this?
4 Replies Related Threads
    James_L
    • Ribbons : 45
    Re:Having some issues with power switching. 2011/08/02 09:47:11 (permalink)
    lino4
    8GB DDR 3 RAM
    Geforce GTX 570
    Corsair 650W
    When running multiple monitors the cards need to stay at the high rate due to a limitation with the monitor values the cards detect for refresh, etc. All cards do this with multiple monitors. They haven't figured out a safe way to allow the memory to downclock so they just settled on having the card run full to resolve the issues.
    [edit]
    Here is that information as to why: (Kindly posted by Schulmaster here)
    PowerPlay saves power via engine voltage, engine clock, and memory clock switching. Memory clock switching is timed to be done within an  VBLANK so that a flash isn't seen on the screen when the memory speed is changed. This can be done on a single display, but not with multiple displays because they can (and in 99% of the cases, will be) running different timings and virtually impossible to hit a VBLANK on both at the same time on all the panels connected (and when we say "timings" it’s not as simple as just the refresh rate of the panel, but the exact timings that the panel's receivers are running). So, to keep away from the end user seeing flashing all the time, the MCLK is kept at the high MCLK rate at all times.
    With regard to power savings under multiple monitors, we have to trade-off between usability and power. Because we can't control what combinations of panels are connected to a desktop system we have to choose usability. Other power saving features are still active (such as clock gating, etc.) so you are still saving more power than peak activities. Note, that in a DisplayPort environment we have more control over the timing and hence this issue could go away if all the panels connected were DP."
    [/edit]
    post edited by scaryone - 2011/08/02 09:57:00
    lino4
    Re:Having some issues with power switching. 2011/08/02 10:54:23 (permalink)
    Thanks for the info. So if I wanted to do an efficient dual monitor setup, I should probably use the integrated graphics for the second screen, right? I was mostly concerned about the heat issues, since I'm living in warmer place right now.
    James_L
    • Ribbons : 45
    Re:Having some issues with power switching. 2011/08/02 11:03:39 (permalink)
    That might do for the interim as it wouldn't be using the discrete card (i.e. your EVGA card) to handle the processing for the additional monitor. You'd still have additional power draw on the motherboard but nothing that would cause enough additional heat that you would be worrying about it. Depending on the games you run it may not look at well or render quickly with the secondary monitor on the on-board card but it should suffice depending on what it is.
    G__ROW
    Re:Having some issues with power switching. 2011/08/02 11:38:11 (permalink)
    You could use NVIDIA Inspector to force the card to down-clock when it is idle.  http://downloads.guru3d.c....94-download-2612.html
    I've been using it ever since I got my first 580.  You just have to remember to add applications to the performance list so it will up-clock when you need it to.
