Helpful ReplyHardware Monitor Help
lerb50
2016/11/13 09:00:53 (permalink)
How do I turn off the graphs I don't want to see?  I currently use Afterburner because The monitor when detached from precision is huge.
EVGA 1300 G2
EVGA X99 Classified
Onboard Creative Recon 3d sound
64 gb HyperX Fury DDR4 2133
5930K @ 4.0
2 EVGA Hydro Copper TITAN X SLI (Maxwell)
1Plextor PX-G128M6e (OS)
1 WD Black 2TB +1 WD blue 1 TB
ACER X34 Predator(main) Acer V246HL (aux)
Corsair Air 540 case
Logitech 5.1 speakers
64 Bit Windows 10  Pro.
Razor  Black Widow Ultimate Keyboard
Razor Ouroboros Mouse
bob16314
  • Ribbons : 203
Re: Hardware Monitor Help 2016/11/13 10:06:30 (permalink) ☄ Helpfulby lerb50 2016/11/14 12:46:19
In EVGA Precision, open it's Hardware Monitor..Right-click within the Hardware Monitor..Click Properties which will bring up the OSD/Monitor Settings..Select the GPU Statistic from the dropdown you don't want to see in the Hardware Monitor..Click the 'Show in monitor' button so that it's not lit up..That removes the desired statistic from the Hardware Monitor..Clicking to light up a statistic makes it show in Hardware Monitor..When you remove a statistic from Hardware Monitor, it's no longer available as an on-screen display item.
* Cooler Master NV-334 * ASUS P8Z77-V LE PLUS * Intel i7-2600K @ 5.0GHz * Corsair H80 * Seasonic M12II 750W * 4x4GB 2133MHz Patriot Viper Xtreme * EVGA GTX 760 SC * 2 x WD 500GB Caviar Black RAID 0 * Toshiba DT01ACA 500GB * Dual-boot Win7 Home Premium 64-bit/Win10 Home 64-bit *
"If it ain't broke, fix it untill it is"
