I'm not a gamer by any means, but I do like seeing info about my PC using rainmeter with the HWINFO plugin. I had a MSI 650 Ti card and I was able to see the fan RPM speed and percent all the time. Now that I have the EVGA GTX 960 SC (02G-P4-2962-KR), HWINFO doesn't show the fan until it has kicked on by straining it and pushing up to 60C. Anyone have a fix for this that doesn't require running software in the background to force a different fan curve?
I used to care about my card/temp when I was converting videos, it used cuda cores, but I have been using handbrake for quite some time now as I get better results. When I was ripping using other software that used the video card, I'd monitor the temp and whatnot. Now I just like knowing how hard it's running. I really only play online games and probably didn't need to upgrade the card, but on occasion, the games were getting glitchy. Probably due more to flash than the card... regardless, I got the new card.
I understand that it doesn't turn on until the GPU gets up to 60C, but thought it odd that it doesn't even show up to HWINFO until it turns on. Figured it would show 0 or something.
System: Win10 Home 64 biti7-670016G Ramintel 530 240G SSD primaryGTX 960 02G-P4-2962-KR 2GB SC
