HELP!!!!! PROBLEM WITH CLASSIFIED, BIOS E77, & AN INTEL i7 950
Alucard666
  • Ribbons : 12
2010/11/02 06:54:30 (permalink)
The purpose of this thread is to make sure everything is right. XD
I updated to the new E77 bios and figured to get some feedback.
http://img180.imageshack.us/i/img0293up.jpg/
http://img229.imageshack.us/i/img0297q.jpg/
http://img838.imageshack.us/i/img0300l.jpg/
http://img838.imageshack.us/i/img0301w.jpg/
http://img837.imageshack.us/i/img0303z.jpg/
http://img227.imageshack.us/i/img0305u.jpg/
http://img225.imageshack.us/i/img0307j.jpg/
http://img828.imageshack.us/i/img0311b.jpg/
http://img834.imageshack.us/i/img0313i.jpg/
http://img716.imageshack.us/i/img0315jx.jpg/
Better than a bios template huh?
The pics were taken with my phone so sorry if they're unclear.
post edited by Alucard666 - 2010/11/02 07:49:15
i7 2600k @ 4.2 Ghz || H70 || Maximus 4 Extreme || eVGA GTX 680 {2-Way SLi} || 16GB Vengeance || F120GB x2 [RAID 0] || 1 4TB WD Green  || Creative Sound Blaster Z || AX1200 PSU || HAF 932 || Samsung 46" 1080p 240hz 3D LED || z5500 + G930 || K800 + Performance MX ||
15 Replies Related Threads
    Lvcoyote
    • Ribbons : 8
    Re:How my system looking? 2010/11/02 07:01:16 (permalink)
    Not better than a template because we have no component list.....LOL.  Why so high on CPU PLL vCORE voltage??
    ASUS Maximus VI Impact, i7-4770K, G.Skill TridentX 2X8Gb DDR3-2400, EVGA GTX 750 Ti, EVGA Hadron Hydro w/EVGA Hadron Hydro Water Cooling Kit, Samsung 840 EVO 500 Gb SSD, WD Caviar 500 Gb HDD, Panasonic UJ8C5 Slot Load DVD Burner, Windows 8.1 Pro X64/Linux Mint 16 X64
    HEATWARE
    Alucard666
    • Ribbons : 12
    Re:How my system looking? 2010/11/02 07:15:16 (permalink)
    I thought that was an acceptable amount.... Guess not?
    EDIT: I readjusted some things....
    System Specs
    Mother Board ( EVGA X58 Classified E-759 )
    Drivers ( Latest )
    Bios ( e77 )
    CPU ( i7 950 D0 )
    CPU Cooler (Corsiar H50)
    Memory ( Corsair Dominator 1600 [8-8-8-24-74-1T] )
    PSU ( Silverstone DA1000w)
    GPU ( GTX 470 + GT430 PhysX )
    Drivers ( 261.00 )
    Operating System ( Windows 7 X64 Ultimate )
    Frequency Control
    CPU Clock Ratio ( 24 )
    CPU Host Frequency (Mhz) ( 169 )
    MCH Strap ( Auto )
    CPU Uncore Frequency (Mhz) ( Auto )
    CPU Clock Skew ( 0 ps )
    Spread Spectrum ( Disabled )
    PCIE Frequency (Mhz) ( 100 )
    Memory Feature
    Memory Speed ( Standard )
    Memory Control Setting ( Enabled )
    Memory Frequency ( 2:10 1333 )
    Channel Interleave Setting ( 6 Way )
    Rank Interleave Setting ( 4 Way )
    Memory Low Gap ( Auto )
    tCL Setting ( 8 )
    tRCD Setting ( 8 )
    tRP Setting ( 8 )
    tRAS Setting ( 24 )
    tRFC Setting ( 74 )
    Command Rate ( 1T )
    Voltage Control
    EVGA VDroop Control ( Without VDroop )
    CPU VCore ( 1.2375)
    CPU VTT Voltage ( +25)
    CPU PLL VCore ( 1.2750 )
    IOH PLL VCore ( 1.2750
    DIMM Voltage ( 1.67 )
    DIMM DQ Vref ( +0mV )
    QPI PLL VCore ( 1.125 )
    IOH VCore ( 1.125 )
    IOH/ICH I/O Voltage ( 1.525 )
    BR04 ( NF200) Voltage ( 1.2 ) (only on E-759)
    VTT PWM Frequency ( 250 KHZ )
    CPU PWM Frequency ( 800 KHZ )
    CPU Impedance ( Auto )
    QPI Signal Compensation ( Auto )
    ICH VCore ( 1.125 )
    PWM Frequency ( Not Used on Classified )
    CPU Feature
    Intel SpeedStep ( Disabled )
    Turbo Mode Function ( Enabled )
    CxE Function ( Disabled )
    Execute Disable Bit ( Disabled )
    Virtualization Technology ( Enabled )
    Intel HT Technology ( Enabled )
    Active Processor Cores ( All )
    QPI Control Settings ( Enabled )
    QPI Link Fast Mode ( Enabled )
    QPI Frequency Selection ( 4.800 GT/s )
    OC Recorvery ( Disabled )
    PnP/PCI  &  PCI Express
    Maximum Payload Size ( 512
    So, now then.... what do you all think?
    post edited by Alucard666 - 2010/11/02 07:38:21
    Alucard666
    • Ribbons : 12
    Re:How my system looking? 2010/11/02 07:29:47 (permalink)
    I also noticed that since I upgraded to the e77 bios my cpu is fluctuating in clock speed.... and I don't believe I have speed step  on...so I dk why its doing that....
    http://img203.imageshack.us/i/88217594.png/
    http://img64.imageshack.us/img64/1742/96588513.png
    http://img836.imageshack.us/f/45535882.png/
    Windows also isn't seeing it right either.... in bios 74 thses issues weren't present...
     For one reason or the other my multiplier is droping from 24 to 12.
    post edited by Alucard666 - 2010/11/02 07:45:29
    KMoore4318
    Pistoj Doulos Unum Pluribus
    • Ribbons : 233
    Re:How my system looking? 2010/11/02 08:34:20 (permalink)
    Check your temps , double check and make sure speed step is disabled, you may want to clear BIOS, and re enter all settings, a drop to a 12 multaplier can happen as a result of down clocking, either to save power when not needed, ( Speed Step) or to protect chip when temps are in the 100 range. ( TJmax ) ; If you still have the issue, you may want to flash back to 74,
    Also the Pics you provided shows speed step enabled, while your template shows it disabled.
    post edited by KMoore4318 - 2010/11/02 11:00:52
    Alucard666
    • Ribbons : 12
    Re:How my system looking? 2010/11/02 09:25:10 (permalink)
    Temps are solid I think I'm just gonna flash back to 74. As sad as that is.... I waited for a new bios for ever and now that its out it does me no good.
    Thanks for the input. I'll try this when I get home.
    Alucard666
    • Ribbons : 12
    Re:How my system looking? 2010/11/02 11:42:04 (permalink)
    I must have totally skipped over the speed step setting 3x.... (Bios/template fill out/your mention of it) Wow.... I feel like such a fool for missing it. I should probably turn it off huh? XD
    I feel like a real noob. I'll turn it off when I get home and all should be well then. XD
    z3r0t0l0rence
    • Ribbons : 20
    Re:How my system looking? 2010/11/02 11:49:41 (permalink)
    I noticed that you DIMM voltage is set to 1.67.  Thats way too high and not recommend.  1.65 or lower is what you want to shoot for.
    My current DIMM setting are 6-7-6-24 1T 1.62v.  Thats more what you should be looking for.
    Good luck!
    Z3r0
    i7 930 OC 4.21
    EVGA E758
    GSkill 12GB
    Evga GTX 780 SC
    2x Kingston 240 Raid 0
    2x Seagate 4TB
    Alucard666
    • Ribbons : 12
    Re:How my system looking? 2010/11/02 11:54:17 (permalink)
    z3r0t0l0rence
    Good luck!
    Z3r0
    I'm aware of the 1.65 recommended zone, however I found that 1.67 gives me more stability.
    dmoheban
    Re:How my system looking? 2010/11/02 12:18:15 (permalink)
    Your one brave camper for trying the new bios out before us other wimps go for it.. I'm not sure I want to upgrade as never been so stable as on bios 59. Will be following your thread to see how it goes...
    EVGA CLASSIFIED 759  - Intel 920 D0 CPU
    Corsair Dominators 3x2gb C7 1600mhz
    XFX 6970 Trifire - XFi Titanium
    Heatkiller 3.0 - XPSC RX360 Rad - MCP655
    Alucard666
    • Ribbons : 12
    Re:How my system looking? 2010/11/02 12:22:59 (permalink)
    dmoheban
    LOL.
    Thanks.
    Also for the record I've been running my dominators @ 1.67 minimum going as high as 1.72v for a little over a year and a half now. 1.65 just doesn't hold up well if I push my oc over 3.6ghz.
    z3r0t0l0rence
    • Ribbons : 20
    Re:How my system looking? 2010/11/02 12:25:58 (permalink)
    Its very odd that you have to crank up the voltage sooo high to get it stable.  I've personally never seen another member here with all the threads that I've read to have to go above 1.65.  But If your able to get it to work for you then more power to ya.
    i7 930 OC 4.21
    EVGA E758
    GSkill 12GB
    Evga GTX 780 SC
    2x Seagate 4TB
    Alucard666
    • Ribbons : 12
    Re:How my system looking? 2010/11/02 12:32:29 (permalink)
    z3r0t0l0rence
    I agree.
    it's a bit weird but its w.e. I don't mind it a whole lot. So long as it works....Right?
    KMoore4318
    • Ribbons : 233
    Re:How my system looking? 2010/11/02 12:57:29 (permalink)
    On a side note: after you disable speed step, if you get any messages referancing 41 Kernal error, or contact system Manf, a BIOS feature has been disabled ... in any of your LOGs, Disregard , It's just Microsofts way of telling you that you have turned off speed step. ( they are such goobers )
    emersj
    Re:How my system looking? 2010/11/02 14:23:35 (permalink)
    Drivers ( Latest )
    Bios ( e77 )
    CPU ( i7 950 D0 )
    Drivers ( 261.00 )
    Frequency Control
    MCH Strap ( Auto )  DRAM Ratio
    CPU Uncore Frequency (Mhz) ( Auto ) 20X double your Ram Ratio
    Memory Feature
    tCL Setting ( 8 )
    tRCD Setting ( 8 )
    tRP Setting ( 8 )
    tRAS Setting ( 24 )
    tRFC Setting ( 74 )
    Command Rate ( 1T )
    Voltage Control
    CPU VCore ( 1.2375)  1.35v
    CPU VTT Voltage ( +25)  250mV
    CPU PLL VCore ( 1.2750 ) Auto
    IOH PLL VCore ( 1.2750 )  Auto
    DIMM Voltage ( 1.67 )  1.65v
    IOH VCore ( 1.125 )
    CPU Impedance ( Auto )  Less
    QPI Signal Compensation ( Auto )  Less
    ICH VCore ( 1.125 )
    CPU Feature
    Maximum Payload Size ( 512 )  128
    Core i7 920 D0 @ 4.2Ghz
    Corsair H70
    CM HAF 932 10-120mm Red LED fans
    EVGA E760 Classified
    Mushkin Redline 12Gb 1600mhz 6-8-6-18
    Corsair HX1000 PSU
    EVGA GTX470
    EVGA GTX275 1792MB
    2-60GB Mushkin Callisto Deluxe in RAID0 (550/510 read/write)
    3 - 1TB WD Black
    2 - 500GB WD Black
    Alucard666
    • Ribbons : 12
    Re:How my system looking? 2010/11/02 16:40:48 (permalink)
    Thanks for the help gents. All is right with the world once more.
