HELP PC WON'T TURN ON! Need assistance identifying the problem.
mmatani
2016/10/11 15:37:50 (permalink)
When I try powering on the pc the fans turn 1/4 and the case lights come on but shuts down almost immediately.
2 Replies Related Threads
    HarryD
    Re: HELP PC WON'T TURN ON! Need assistance identifying the problem. 2016/10/11 15:51:40 (permalink)
    Have you checked all the power connections on the motherboard? If you did, do you have another power supply to test with?
    EVGA X99 Classified
    Intel i7-5960X
    64GB Corsair Dominator 2400MHz DDR4
    3 EVGA GTX980's
    Samsung 850 Pro 1TB SSD
    2 Western Digital Black 2TB HDD's
    Corsair AX1200i
    Corsair Obsidian 900D
    EVGATech_ChrisB
    Administrator
    Re: HELP PC WON'T TURN ON! Need assistance identifying the problem. 2016/10/11 16:02:48 (permalink)
    Dear mmatani,
    Welcome to the forums!
    Unfortunately this is usually a sign that the PSU is sensing a power issue and killing power to the machine.   I would disconnect all power connectors other than the motherboard and see if it stops occurring.
    If the issue continued then I would disconnect all fans. and see if the lights stay on.
    I would then move to devices including memory or taking the motherboard outside of the case to ensure that there isn't a mounting post out of place and checking the CPU socket for a over-tightened cooler or bent pins.
    mmatani
    post edited by EVGATech_ChrisB - 2016/10/11 16:19:01
