Gamer4lifesssssss
Hello, so one while i was playing a game my gf came over and so i just left the game running she left about 6 hours later i came back my keyboard stopped glowing my stopped glowing my was black the light on the bottom of the monitor was flashing i tried moving the mouse and stuff nothing happened so i called asus about my they asked if i upgraded to windows 10 i said yes and the bias settings for that motherboard were set for originally so i sent it off and they replaced the bias settings the battery and so i got the motherboard back i put it in start up my computer same thing happens no response from the usbs.... I tried a vgr cable for my monitor didn't work, i tried different sticks of ram didn't work, i tried removing my didn't work, tried different power supply's didn't work... Anyone have any ideas what could be wrong?
or motherboard what please let me know.
KenMcC
- Ribbons : 21
Re: HELP ME! Computer help asap
2016/06/27 17:16:43
KenMcC Z170 Classy K; i7-6700 CPU, Corsair CMK16GX4M2A2400C14 Seasonic SSR-360GP 360W; Samsung 950 Pro M.2 256 GB Samsung 850 Evo 500 GB SATA Samsung 850 Evo 256 GB SATA Samsung SSD 840 Series 250 GB SATA Samsung 860 EVO 1 TB SATA Windows 10 x64 Prof.
Gamer4lifesssssss
2016/06/27 19:15:51
tried two different power supplys the one i tried is bran new only been used once so its not the power supplys
DAVE2HOT4U
2016/06/27 23:17:28
It might help if you listed All the Hardware of your computer ! I cant Guess or anyone else what your problem is without Knowing Specifics.
Gamer4lifesssssss
2016/06/27 23:31:18
DAVE2HOT4U It might help if you listed All the Hardware of your computer ! I cant Guess or anyone else what your problem is without Knowing Specifics.
GPU:Evga Gtx 750 ti 2 gb SC Ram: 16 gb Processor: Amd Quad Core Processor 4200 Motherboard:Asus m5a78l-M LX PLUS Pci express 2.0 Power Supply: 1000 watts 4 rail Evga Hard Drive: 1 Tb Windows 10 Fans: 6 fans Processor cooler: 120 mm dont know the rest all i know is its bigger than a gorillas palm. Monitor:Samsung 1920x 1080, 1080p Keyboard: Razer Deathstalker Mouse: I buypower Special Edition Nighthawk need anymore info reply please
Andzx
2016/06/28 07:27:54
So to recap: 1) You left you system running for 6hrs unattended under a gaming load. Upon return your monitor was off with its power light flashing. 2) You RMA'd the Motherboard received it and after reinstalling still you cannot get your system to post? My questions are, when you try to boot the system does it beep? Does it power the fans? Have you tried different psu cables?
9900k Aorus z390 Trident Z Royal 3600mhz C16 EVGA 3080 XC3 Gaming EVGA 750W G3 PSU Heatware
transdogmifier
- Ribbons : 17
2016/06/28 07:44:11
personally, I'd remove the video card and see if it posts..
Gamer4lifesssssss
2016/06/28 10:10:50
Andzx So to recap: 1) You left you system running for 6hrs unattended under a gaming load. Upon return your monitor was off with its power light flashing. 2) You RMA'd the Motherboard received it and after reinstalling still you cannot get your system to post? My questions are, when you try to boot the system does it beep? Does it power the fans? Have you tried different psu cables?
system does not beep at all transdogmifier personally, I'd remove the video card and see if it posts..
and i tried to remove the graphics card and use the stock motherboard card and still done nothing
2016/06/28 11:54:14
Only thing left is the cpu.
Gamer4lifesssssss
2016/06/28 18:01:22
Sajin Only thing left is the cpu.
cpu? what do u mean cpu? you mean the motherboard? or processor? thats the only options i have left
2016/06/28 18:07:19
Gamer4lifesssssss
Processor.
Gamer4lifesssssss
2016/06/28 18:24:56
Gamer4lifesssssss
Processor.
you honestly think its the processor?
Andzx
2016/06/29 05:54:16
Sometimes it can be the easiest answer, did you turn off the psu power switch?
Gamer4lifesssssss
2016/06/29 20:16:48
Andzx Sometimes it can be the easiest answer, did you turn off the psu power switch?
wheres that located?
Andzx
2016/06/29 20:24:16
Gamer4lifesssssss
2016/07/01 17:49:16
Andzx Should be a switch near where you plug in the 3 prong power cable
-.-, if the switch is off my computer wont turn on if its on my computer turns on
Gamer4lifesssssss
2016/07/11 09:10:30
bump i need to know what to do
2016/07/11 09:39:03
Gamer4lifesssssss bump i need to know what to do
Welcome to the forums Gamer4lifesssssss OK, Lets see what we can find. Please remember that we are volunteers on the form, some issues are best resolved at a local PC repair shop. User manual http://dlcdnet.asus.com/pub/ASUS/mb/SocketAM3+/M5A78L-M_LX_PLUS/E8026_M5A78L-M_LX_Series.pdf Page 1-5 Onboard LED ----what do you see 1- 18, item 1 - clear RTC RAM -- (CMOS) ------ clear the CMOS (resets to factory stock) Will PC boot, do you see any thing on screen or do fans come on ? CPU fan come on ? CHECK that All jumpers on your MB are set to factory default position
post edited by Cool GTX - 2016/07/11 09:43:07
Gamer4lifesssssss
2016/07/11 09:41:21
OK Lets see what we can find. Please remember that we are volunteers on the form, some issues are best resolved at a local PC repair shop. User manual
all the fans come on even without reseting it everything inside glows but no ive reset the cmos and still dont do anything
2016/07/11 09:45:46
With power unplugged - off can still give voltage to MB and cause damage (like when moving GPU - (video card) or RAM) Page 1-22 ATX power & EATXPWR - confirm they are fully seated page 1-24 speaker --- is one connected ? Re-seat the RAM
post edited by Cool GTX - 2016/07/11 10:28:09
2016/07/11 09:48:43
If your monitor has more than one input, check that the correct input is selected OR make sure to select Auto detect on the monitor When you reinstalled the CPU (processor) --- Did you apply new TIM ? (thermal interface material) Is your monitor connected to the MB -- (video out) or the GPU, now ?
post edited by Cool GTX - 2016/07/11 10:07:07
Gamer4lifesssssss
2016/07/11 14:02:06
Cool GTX If your monitor has more than one input, check that the correct input is selected OR make sure to select Auto detect on the monitor When you reinstalled the CPU (processor) --- Did you apply new TIM ? (thermal interface material) Is your monitor connected to the MB -- (video out) or the GPU, now ?
ive tried all of these different cables different ram psu's all of that still nothing i shipped off the motherboard again im wondering if its the cpu
2016/07/11 14:50:04
Gamer4lifesssssss
Gamer4lifesssssss
Processor.
Yep.
Gamer4lifesssssss
2016/07/11 19:56:37
Gamer4lifesssssss
Gamer4lifesssssss
Processor.
Yep.
well i checked my processor warranty it ran out...I Have no money to get another one..
Gamer4lifesssssss
2016/07/20 09:19:06
Gamer4lifesssssss
Gamer4lifesssssss
Processor.
Yep.
I got my new processor now im waiting for asus to send back my motherboard
2016/07/21 23:07:20
Thanks for the update. Hope it comes back to life for you soon.
