H8QGi+F 4P have Problem may need help.
TheWolf
  • Ribbons : 9
2013/12/04 20:01:11 (permalink)
Got my new "to me" CPU's in today, break down to place the new CPU's
after doing so its not getting any video on screen, cpu fans turn up, video card
fan does not. Tested with 260GTX and a 240GT same no fan movement.
I need to dig up the link for the manual as I don't remember off the top of my head
if I moved a jumper to disable the onboard or if it was done within bios.
Seems I remember there was a jumper. Mostly thinking out loud here, it sometimes helps
get me thinking clearer when posting and sometimes brings things I might not think of to light.
Does this sound like maybe a dead CPU with this problem I'm seeing?
I have 14 day return if it come down to that.
Thanks for looking in and any comments or thoughts are welcome.
15 Replies Related Threads
    TheWolf
    • Ribbons : 9
    Re: H8QGi+F 4P have Problem may need help. 2013/12/04 20:28:12 (permalink)
    Say I want to test each CPU one at a time "or should it be done in pairs" what is the recommended socket/s to use on this board for testing?
    TheWolf
    • Ribbons : 9
    Re: H8QGi+F 4P have Problem may need help. 2013/12/04 21:01:26 (permalink)
    I found some info here I can use, thanks for looking, I'll get this one way or the other.
    Just wish me luck.
    bowlinra
    Re: H8QGi+F 4P have Problem may need help. 2013/12/04 21:34:43 (permalink)
    Here what I would do. Check the simple stuff.
    Do you have additional 6-pin PCI-E power cable running to the video card? You'll need that.
    If failed - Remove all cables (SATA, USB) Just need to see BIOS
    If failed - I'd pull the GPU and see if the default video 15-pin is work.
    If failed - I'd pull any new components (assuming the system was running prior).
    If failed - I'd remove everything a start from the begin.
    Start with Good know cpu in Socket 1 and 1 Dimm in blue 1 slot and boot to bios. Verify bios see part correctly.
    Next add next cpu to socket2, NO additional memory and boot to bios. Verify bios see part correctly.
    Repeat until bios see all the cpus correctly.
    Add half the system memory and run Memtest86+ test, if passes add remainder and rerun test.
    SMP: 4x AMD 61xx@3.0Ghz - 4x AMD 6176SE@2.71Ghz - 4x AMD 6172@2.41Ghz  - 2x AMD 62xx@3.3Ghz
    My Setup:  Home Rack Garage Build  |  How to fold Big Points - AMD 4P / Quad Socket Design and Build Guide  |  Find some deals EVGA's AMD 4P Deals
    "Unless someone like you cares a whole awful lot, nothing is going to get better. It's not."  Dr. Seuss, The Lorax
    bowlinra
    Re: H8QGi+F 4P have Problem may need help. 2013/12/04 21:39:58 (permalink)
    Also JPG1 is the VGA Enable/Disable jumper. Is on the corner closest to CPU1.
    TheWolf
    • Ribbons : 9
    Re: H8QGi+F 4P have Problem may need help. 2013/12/04 23:02:31 (permalink)
    Thanks for your post. Found the problem CPU was bad, all four of the ones I just got are DOA.
    Put my old CPU back in boot right up, tested each new CPU 4 times green light on the MB
    never comes on, put old chip back green light as soon as power is applied can see & enter bios.
    Strange is no beeps of any kind with the new CPU's, normal boot beep with old. Even once I put
    old chip in and got 5 beeps with 1 long at end, re-seat CPU fix that right up.
    All test were ran in CPU1 socket with 1 stick of memory.
    So I'd say they are dead. What does other think same or something else I should try?
    bill1024
    • Ribbons : 12
    Re: H8QGi+F 4P have Problem may need help. 2013/12/04 23:20:45 (permalink)
    Did you try to reset bios with the new chip?
    Pull the plug and short the pins for 30 seconds and see if that works.
    All 4 dead seems unlikely, but not impossible ,
    bowlinra
    Re: H8QGi+F 4P have Problem may need help. 2013/12/04 23:28:29 (permalink)
    What cpus are you using and what are you moving too? If you moving from MC to IL, you'll need to clear the CMOS most likely. If you have ES chips, then it will depend, but most everything work with the SM H8QGi series. Are all 4 cpus the same?
    TheWolf
    • Ribbons : 9
    Re: H8QGi+F 4P have Problem may need help. 2013/12/05 03:18:46 (permalink)
    Moving was from 6124 8C to the equivalent of 6166, ES chips 12C.
    I did all the normal stuff like reseting the bios, cleared at each test, one stick of memory and so on.
    Even took it a step futher by putting in one 6124 and 2nd one 6166, single 6124 worked, add 6166
    stop getting the green light on the board and nothing on screen, fans spun up was all that happened.
    I have over 12 hours testing in now that's enough they go back tomarrow once I set up the RMA.
    I have put the rig back as it was and back to the 262 refclock stable folding once again.
    Just think the wife wanted to wrap them and put them under the tree for my xmas.
    Good thing I didn't let that happen or I'd be lost out completely.
    Edit: sorry yes all 4 have the same numbers on them.
    Thanks for your input guys!
    post edited by TheWolf - 2013/12/05 03:24:29
    • Ribbons : 68
    Re: H8QGi+F 4P have Problem may need help. 2013/12/05 06:27:05 (permalink)
    Where did you get your New CPUs?
    Glad you did find this sooner rather than later as you have said.
    I am thankful that on BOTH my 2P & 4P Rigs went well.
    I am not that good on AMD Rigs and that is why I did not Overclock them or boost up the vCore.
    Best of luck on your RMA
    TheWolf
    • Ribbons : 9
    Re: H8QGi+F 4P have Problem may need help. 2013/12/05 14:11:46 (permalink)
    Used "new to me" FleaBay.
    Thanks!
    Still no reply from the seller.
    Was quick to answer when I was buying making a offer.
    TheWolf
    • Ribbons : 9
    Re: H8QGi+F 4P have Problem may need help. 2013/12/05 15:04:17 (permalink)
    Looks to be a very good seller so far, I got a reply and he has offered to send me a return shipping label.
    Hope things goes smooth so I can soon start looking for something else for my xmas gift.
    post edited by TheWolf - 2013/12/05 15:05:18
    bill1024
    • Ribbons : 12
    Re: H8QGi+F 4P have Problem may need help. 2013/12/05 20:12:52 (permalink)
    notfordman
    • Ribbons : 14
    Re: H8QGi+F 4P have Problem may need help. 2013/12/06 10:43:03 (permalink)
    I had been having exact same issue as you WOLF, same exact board with spicy chips. Turns out ONE cpu was bad. It killed any hope of booting in BIOS. Luckily I had Bowlinra and tear with tech assistance. The single memory stick goes in the furthest socket from CPU1 when testing.
    When the bad chip was in board fans would spin, but it would kill the power good LED near the 24 pin, would kill all keyboard and mouse power and it would sit on black screen[and sata as well]. The cmos clear is strange on my board, instead of moving a jumper, you touch a pair of solder "pads". There is no jumper, there is a jumper very close to it, but it's for something else. Once I removed the bad chip everthing was back to "normal".
    Something I learned in my process is you can put more than one CPU in ,with only one memory stick in P1-1A. But you should test each individually. That is very foreign to me, because I thought each CPU would need a ram stick per CPU.
    TheWolf
    • Ribbons : 9
    Re: H8QGi+F 4P have Problem may need help. 2013/12/07 02:51:03 (permalink)
    Thanks for your input notfordman. I tested each CPU one at a time and each at least 6 or 7 times
    in the CPU1 socket not to count I placed one of my old chips in CPU1 then went threw each again
    this time I tried each twice still nothing. It would boot with the old chip in CPU1 but the other chips
    would kill that boot once placed in any other scoket as I tried every open socket then moved on to
    placing a second old chip "now 2 of my original chip boot" place the new in the 3rd scoket it no longer
    responds place another old chip now 3 old it boots and shows 3, place new chip in last scoket no boot
    same as before no power light work on the board. I tried all 4 chips at least twice in scoket 2 ,3 , and
    4 with 1, 2, 3 of the old ones. Each chips was tested 12 or more times in different origination.
    So I say bad bad bad bad and not bbbad to the bone either, bad. lol Really was supprised all were dead.
    clo007
    • Ribbons : 11
    Re: H8QGi+F 4P have Problem may need help. 2013/12/08 12:15:08 (permalink)
    Honestly, unless you are buying some spiceys from someone here or [H] that are known to work, I would stay away from them. Also, technically spiceys are still property of AMD.
