Going to water cooling
soullesshunter
2016/11/15 19:17:34 (permalink)
I have the mods rig in my profile, I'm looking to do cooling for my CPU and later down the road do graphics. Was curious if my parts are that I even  have able to do cooling. I look at the water cooling for noobs.  was hoping to get little more reassuring to get an understanding of if it's right or even if I'm able to do cooling.
21 Replies Related Threads
    • Ribbons : 68
    Re: Going to water cooling 2016/11/15 19:30:28 (permalink)
     From your Rig are you planning on using the same Case?
    soullesshunter
    Re: Going to water cooling 2016/11/16 05:49:38 (permalink)
    I'd like to use the same case, but if i need to switch i'll be more then welcome to.
    wmmills
    • Ribbons : 18
    Re: Going to water cooling 2016/11/16 06:48:26 (permalink)
    Watercooling is great if you want to keep a 24/7 high overclock and you bench a lot, runs crazy game settings and/or multi-monitors etc.... but if not and your just going to run it modestly with games at stock settings or slightly above, air cooling is just fine. Unless you live near the equator where temps for your ambients would be really hot 24/7, then yeah it would help there too. Water cooling is fun and all until you have a problem and have to dismantle half of it to fix something or rma parts etc.... Also, depending on how you design your loop, it can get pretty expensive to put something effective together, that's why so many people have moved to the all in one coolers, which fall in between air cooling and full fledged water cooling.
    MOBO: EVGA P67 FTW, CPU: I5 2500K, RAM: Gskill PI 1600 CAS 6, SSD: Samsung 830 128gb, HDD: WD Caviar Black 750gb, PSU: CoolerMaster V-1000, CPU HSF: EVGA ScC HSF~ P/P 88CFM Yate Loons, G-CARD:EVGA GTX780, CASE: LIAN-LI PC-V2010B, OS: Windows 7 Ultimate 64bit, MON: AOC i2367F, HdSet: steelseries Siberia
    NEVER CONFUSE EDUCATION WITH INTELLIGENCE!
    soullesshunter
    Re: Going to water cooling 2016/11/16 09:15:03 (permalink)
    in my situation, my CPU and graphics run pretty hotly when I'm not home. I"m a folding machine and it would help with cooling gets pretty hot in my room. the all in one cooling for water is that like a specific motherboard/ case or just a system you can install?
    wmmills
    • Ribbons : 18
    Re: Going to water cooling 2016/11/17 07:14:38 (permalink)
    soullesshunter
    Oh yeah, for you folding guys water would def be a great thing. The all in ones are like this for a cpu, : http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&IsNodeId=1&N=100008008 50001459 600036012 8000&Manufactory=1459    heres the listing for the gpu's :http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=all+in+one+coolers+gpu&N=-1&isNodeId=1      There are other aftermarket gpu all in one coolers like that but youll have to search them out and do some research on what you want. Evga has a all in one but whether it would fit your card or not I cant say for sure.  Other than that, youll have to build out a full fledged water loop and youll probably need a bigger case if you want to do that, which is what BCav was probably eluding to. :)
    Edit: fixed link.
    post edited by wmmills - 2016/11/17 11:42:55
    soullesshunter
    Re: Going to water cooling 2016/11/17 09:16:55 (permalink)
    btw both links to CPU cooling. so bigger the case would allow the room I need for the graphics and CPU cooling? probably help with wire managing as well.
    soullesshunter
    Re: Going to water cooling 2016/11/17 13:05:57 (permalink)
    wmmills
    soullesshunter
    Edit: fixed link.
    what case size would you recommend?
    wmmills
    • Ribbons : 18
    Re: Going to water cooling 2016/11/19 08:24:35 (permalink)
    soullesshunter
    wmmills
    soullesshunter
    Edit: fixed link.
    I think the real question is what are you looking to spend? Either collectively or separately on cooling plus a case? I wouldn't water cool in something smaller than a full tower myself, but depending on what your going to do and how you want it to look in the end a large mid case can work too.
    soullesshunter
    Re: Going to water cooling 2016/11/19 09:27:32 (permalink)
    This probably is a 2-3 month process not really about money but I'll set a 500-800 budget. I wanting to get my feet wet before I start diving in. wanted to gather all the parts put it on paper really and get a few suggests. I'll be posting updates on all the part and stuff to get a feel if I leave anything out.
    so here's where I'm at for the moment
    https://www.amazon.com/MasterLiquid-Cooler-Technology-MasterFan-Radiator/dp/B01E5XNP5Y/ref=sr_1_2?s=pc&ie=UTF8&qid=1479576357&sr=1-2&keywords=cooler+master&refinements=p_n_condition-type%3A2224371011
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811119160&ignorebbr=1
    as of right not still looking for stuff for my gpu, and the pump for the loop as well.
    soullesshunter
    loveha
    • Ribbons : 53
    Re: Going to water cooling 2016/11/20 22:45:24 (permalink)
    soullesshunter
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814127947
    https://www.amazon.com/gp/product/B01GXOX3SW/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1
    having hard time finding gpu blocks for these.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811133244&ignorebbr=1
    http://www.newegg.com/Product/Product.aspx?Item=N82E16835106402&ignorebbr=1
    this what i have for my setup any feed back be nice.
    Don't think I have seen blocks for those yet. If anybody would have them it would either be EK, Watercool, Aquagrafx, Koolance, or Bitspower. Only blocks made that are not reference so far that I am aware of are EVGA FTW blocks from EK, with Watercool making some currently to be released in 3-4 weeks. You would be best served by calling or emailing each company to see if they have any plans to offer MSI blocks for that model.
    Case: Corsair 900D
    GPU: EVGA GTX 1070 FTW DT SLI
    PSU: EVGA 1000w G2
    soullesshunter
    Re: Going to water cooling 2016/11/21 05:45:59 (permalink)
    https://www.ekwb.com/configurator/step1_complist
    this is what i found but not to sure if it will fit. want to make sure its 100% don't want to have delay anytime making it.
    loveha
    • Ribbons : 53
    Re: Going to water cooling 2016/11/21 18:20:08 (permalink)
    If the configurer says it fits, it fits. Went through it my self and it came up with two styles of blocks for the MSI Gaming X cards. EK is the largest water block maker. So to see they have a block is not surprising. This being EVGA forums, you don't really hear about the other blocks out there for other brands.
    post edited by loveha - 2016/11/21 18:29:43
    Case: Corsair 900D
    PSU: EVGA 1000w G2
    howdy2u2
    Re: Going to water cooling 2016/11/21 18:25:10 (permalink)
    loveha
    Link to product it self. The link you provided just takes us to the block finder page.
    It won't save the product chosen.....I just tried it myself
    loveha
    • Ribbons : 53
    Re: Going to water cooling 2016/11/21 18:27:35 (permalink)
    howdy2u2
    loveha
    Yea, just edited my post after going through the configurator.
    Case: Corsair 900D
    PSU: EVGA 1000w G2
    howdy2u2
    Re: Going to water cooling 2016/11/21 18:40:49 (permalink)
    loveha
    howdy2u2
    loveha
    soullesshunter
    Re: Going to water cooling 2016/11/21 18:46:02 (permalink)
    this what i got
    howdy2u2
    Re: Going to water cooling 2016/11/21 19:44:35 (permalink)
    soullesshunter
    this what i got
    Looks like the same thing I came up with, now you decide between "full cover or Universal". Which I always choose full cover, otherwise you have to add passive cooling on the RAM and Mosfet.
    soullesshunter
    Re: Going to water cooling 2016/11/23 20:29:30 (permalink)
    Going full cover cost little more  but worth it, only thing is back plate but im worry about couldn't i use my original one or is it a must to get there's?
    howdy2u2
    Re: Going to water cooling 2016/11/23 21:13:11 (permalink)
    soullesshunter
    With a MSI GPU I do not know if the original back plate will fit. Could try Google and see what might be out there, if anyone else has had success in keeping the original back plate. I do know on some EVGA GPUs people have managed to make them fit but have had to come up with "some" screws of proper length, diameter and thread pitch to reinstall it to the block. I, IMO think EK's back plates are ugly and quite expensive but have paid the price since I know they will work with the blocks I have purchased.
    soullesshunter
    Re: Going to water cooling 2016/11/24 10:53:42 (permalink)
    i guess i have too kinda sad that the gpu alone cost more then the rest of the parts but i guess one of those have to deal with for mean time. i'll settle for the black back plate.
