LockedGoing from 2-way to 3-way SLI on Z77 FTW
Aurelius73
2013/09/05 19:16:06 (permalink)
Finally making the jump from 2-way to 3-way SLI. I currently have two cards in slots 2 and 4. Which slot should I put the 3rd card? Also, I have 1 PCI-e power connector connected to the board itself. Do I need to connect another for the third card?
Thanks for all of your input in advance :)
Corsair Obsidian Series 650D Mid-Tower ATX Case
EVGA Z77 FTW Motherboard
Intel i7 3770K CPU
Corsair H60 CPU Cooler
Corsair Vengeance DDR3 1866 (4x4GB)
MSI GTX570 PE Twin Frozr III GPU's (3-way SLI)
OCZ Vertex 3 Max IOP 120GB SSD
OCZ Vertex 4 128GB SSD
Samsung 840 240GB SSD
Hitachi 1.5TB SATAIII HD (2x)
Creative Soundblaster Z Sound Card
LG Blu-ray Writer
Corsair 1050watt PSU
Windows 7 Ultimate 64-bit/Windows 8.1 Pro 64-bit - Dual Boot
Toshiba 39" 120Hz HDTV
9 Replies Related Threads
    Z.PricyWolf
    Re:Going from 2-way to 3-way SLI on Z77 FTW 2013/09/08 03:20:13 (permalink)
    Guru3D
    http://www.guru3d.com/art..._z77_ftw_review,3.html
    When we zoom into the rear right of the IO panel a little we spot a 6-pin power connector.
    The board actually has two of these so bring more powah to the graphics solution at hand,
    EVGA has added dual 6 PIN PCI-E power connectors.
    Use a single 6 Pin PCI-E power connector for multi-card stability,
    or a second for extreme overclocking.
    PCI-Express Slot
    ・2WAY-SLI  x8/x16 or x8/x8
    ・2WAY-SLI  x16/x16 ( Slot2 & Slot4
    ・3WAY-SLI  x8/x16/x16
    ・4WAY-SLI  x8/x16/x8/x8
    CPU's Memory Bandwidth
    ・Core i7 Ivy Bridge - 25.6GB/s ( DDR3-1600 ×2
    ・Core i7 2700K - 21.3GB/s ( DDR3-1333 ×2
    post edited by ZonePricyWolf - 2013/09/08 03:39:00
    122-CK-NF68-AR   /   122-CK-NF68-A1   /   132-CK-NF78-A1   /   132-YW-E178-A1   /   132-YW-E179-A1  /   151-IB-E699-KR
    128-A8-N303-TX   /   512-P3-N973-TR*2   /   012-P3-1570-AR*2   /   012-P3-1572-AR   /   03G-P4-3788-KR
    Vlada011
    • Ribbons : 11
    Re:Going from 2-way to 3-way SLI on Z77 FTW 2013/09/08 05:15:59 (permalink)
    I got chance to make 3way SLI too with EVGA GTX580.
    Some guy offer me for 230e two used EVGA GTX580 and mine that would be 3 way SLI but it's to risky for me to buy used cards and I wait 780 series.
    Mine was new and fabric sealed and because of that I buy.
    I mean that would be lot of power for only little more performance than 780 and one card and second for physix is better optimization than 3 cards for gaming.
    http://www.evga.com
    http://www.intel.com
    http://www.nvidia.com
    https://watercool.de
    http://www.lian-li.com
    peacock9213
    Re:Going from 2-way to 3-way SLI on Z77 FTW 2013/09/08 09:58:34 (permalink)
    I have 3 580s in sli on my z77 ftw and use slots 1 2 & 4 and i just use the 6 pin power connector thats at the bottom left of the board.
    Hope this helps
    Core I5 3570K @ 4.7GHZ
    8GB Patriot Viper @ 2133Mhz
    3 X EVGA GTX 580's
    Corsair H100I CPU Cooer
    Corsair AX1200I PSU
    Aurelius73
    Re:Going from 2-way to 3-way SLI on Z77 FTW 2013/10/07 16:54:50 (permalink)
    First of all, thank you goes out to those who gave feedback on the optimal configuration for 3-way SLI. I wanted to go the route peacock9213 suggested but unfortunately, I had to use slots 1 3 & 6 as the cooling solution on the MSI Twin Frozr III cards I have require more space between them than the reference cooler design. With that being said, I know I might be suffering a very small performance hit but I think I will survive.
    In order to accomplish the 1 3 & 6 slot configuration, it was a HUGE challenge to find an SLI bridge that would do the trick. If you are lucky enough to find a 140mm SLI flex bridge, you can use it to connect the cards in slots 1 and 6 and use two smaller flex bridges to make the other connections.
    This method works fine but doesn't have the greatest appearance.
    The bridge I was REALLY lucky to find was the ASRock 3-way SLI-2S2S bridge:
    It has the appropriate length to reach all the cards and a clean look.
    So far, I have had no issues with the configuration and everything runs smooth.
    Just wanted to share this as I know there have been folks who ran into this problem before me and hope it might help anyone who is facing this issue in the future.
    post edited by Aurelius73 - 2013/10/07 17:58:16
    Intel i7 3770K CPU
    LG Blu-ray Writer
    • Ribbons : 282
    Re:Going from 2-way to 3-way SLI on Z77 FTW 2013/10/07 17:19:29 (permalink)
    You only need one of the PCIe 6 pin plugged in.
    Aurelius73
    Re:Going from 2-way to 3-way SLI on Z77 FTW 2013/10/07 17:24:34 (permalink)
    Thanks for the info. I have  the 6-pin plugged into the bottom connector on the motherboard.
    Intel i7 3770K CPU
    LG Blu-ray Writer
    MhzManiac
    • Ribbons : 8
    Re: Going from 2-way to 3-way SLI on Z77 FTW 2014/06/17 20:02:15 (permalink)
    If you already have the SLI connector, you will see the spacing will only allow you to use certain slots. All video cards need their own power or there might be a problem powering up the system. It may power up even without external power to the card, but once you game it may crash.
    That is me in the picture, anyone else ever pet a live Lion?
    EVGA Z390 FTW (Bios 1.08)  i9-9900KF 8 core, 32G Corsair Vengeance LPX Dual Chl 3000 XMP-1 ,
    Intel SSD6 M.2 2TB, Samsung 840 PRO 1TB / 512G SSD,   Gigabyte RTX 2080 Super , Win 11 Pro 64, EVGA Supernova 1300 watts, NZXT Phantom 820, Strix Raid DLX 7.1 surround, Corsair H100 Liquid , Dell S2417DG /S2409W / Acer XB241H Predator / Samsung C24F390 Curve/ Oculus Rift S VR
    Re: Going from 2-way to 3-way SLI on Z77 FTW 2014/06/17 20:20:42 (permalink)
    MhzManiac
    This thread is from October, 2013.
    • Ribbons : 115
    Re: Going from 2-way to 3-way SLI on Z77 FTW 2014/06/17 21:10:00 (permalink)
    Come on MHZ.
                My Affiliate Code: 8WEQVXMCJL
     &nbsp
