Helpful ReplyHot!Get It Colder II
Page: << < ..5152535455.. > >> Showing page 55 of 381
nateman_doo
  • Ribbons : 52
Re:Get It Colder......2 2010/01/04 05:41:30 (permalink)
Rudster816
  • Ribbons : 18
Re:Get It Colder......2 2010/01/04 05:50:23 (permalink)
Reason the Fluke's are so expensive is because there calibrated. As far as im concerned though you dont need a thermometer probe thats all that accurate. 1-3 degrees C doesnt really matter.
Here is one for $110 that I like. Has a stand so you can read it at a lower angle without holding it up. Dual probes FTW too. When I go DICE ill be measure temps with my dads AMP clamp\DMM that has a temp probe.
http://www.amazon.com/Ext...=1262612685&sr=8-5
Its hard to find them with the range you want (for LN2 in most cases).
Cheaper yet doesnt give a temp range
http://www.amazon.com/The...1262612685&sr=8-11
There are also multi meters that support a temp probe.
http://www.amazon.com/Ext...1262612781&sr=8-23
[22:00:32] NordicJedi: the only way i can read this chatroom is if i imagine you're all dead
xxrabid93
  • Ribbons : 8
Re:Get It Colder......2 2010/01/04 06:13:43 (permalink)
This is the one i have that i will use for my DICE tests: http://www.grainger.com/Grainger/items/4FKP6?Pid=search
Takes 2 K-type probes (and comes with them), and measures down to -200*C accurately.
SocioPC
Re:Get It Colder......2 2010/01/04 06:46:49 (permalink)
The one above looks nice, has two probes.
I use a Mannix dt307 it's simple and about $70 bucks has great temp range and very accurate.
http://www.ambientweather.com/mamidt307.html
nateman_doo
  • Ribbons : 52
Re:Get It Colder......2 2010/01/04 06:59:15 (permalink)
for $99.00 we have a winner.  and with TWO probes!  thanks rabid.  Only a few miles from my job also
Rudster816
  • Ribbons : 18
Re:Get It Colder......2 2010/01/04 07:31:09 (permalink)
Hey Nate, buy me one too
ShockTheMonky
  • Ribbons : 45
Re:Get It Colder......2 2010/01/04 08:00:07 (permalink)
If you want a wide range of meters the here you go.
http://www.extech.com/instruments/categories.asp?catid=62
3oh6
  • Ribbons : 7
Re:Get It Colder......2 2010/01/04 09:45:30 (permalink)
i'll vouch you Extech, i love the pair of TM200's i have. battery life is really good with these units and they are more than enough for benching purposes. my only beef is i can't figure out a way to disable the automatic shut off after 5 minutes or whatever the safety sleep is...but it really doesn't affect me much when benching.
:: OC Reports :: living life 32M digits of Pi at a time...
voklskier4452
  • Ribbons : 8
Re:Get It Colder......2 2010/01/04 10:27:52 (permalink)
nice setup you got there 3oh6
I loved the i5 6 series review you put up on XS, it was quite entertaining to read, though a little sad considering i just picked up a i5 650
Asrock Z77E-ITX | Intel i5 3570K @ 4.5ghz | 8gb Gskill Ripjaws X 1600mhz | Corsair H80i
Asus GTX 670 DCU II | Sandisk Extreme 120gb | Silverstone ST45SF-G | Silverstone SG-05
nateman_doo
  • Ribbons : 52
Re:Get It Colder......2 2010/01/04 11:48:15 (permalink)
I think I want to build a phase change.  I wonder how much parts I can salvage from a 5000 BTU AC?  I am thinking just saw off the evap and replace it with a block, but somehow I think there will be considerably more involved with it...
Rudster816
  • Ribbons : 18
Re:Get It Colder......2 2010/01/04 13:52:11 (permalink)
You could salvage a lot out of a 5000 BTU for a Phase unit. You would just need a compressor, the evaporator to put on the CPU and some hosing and be able to recharge it. Maybe some other smaller things, but IM pretty sure the Compressor\Condenser are all you need for a basic unit.
There is a 90% chance im dead wrong though
3oh6
  • Ribbons : 7
Re:Get It Colder......2 2010/01/04 15:34:08 (permalink)
voklskier4452
thanks, just remember that half of disappointment comes from high expectations...now that expectations have been lowered, disappointment should go down too
seriously though, you have to keep the source of the content in perspective. i wrote it for the high-end benchmarking crowd with that and only that crowd in mind. the idea of good/bad is fluid and my perspective on hardware is much much different from most. if it can't achieve a top ten result in HWBot, it is bad in my books. obviously that isn't going to be the case for everyone.
hopefully you enjoy the setup, it may be a blast just to overclock even without amazing results. be sure to post up some results here or in the P55 section when you get up and running.
Q56_Monster
Re:Get It Colder......2 2010/01/04 20:54:04 (permalink)
I was fumbling around with some killer gpu clocks, but not cold enough, so reverted back to the 'ol standbys.  Good thing, cause I need to go to bed....have to wait until the adrenaline wears off though!
Mobo: tbd CPU: tbd
GPU: tbd
RAM: tbd HD: tbd
johnksss
Re:Get It Colder......2 2010/01/04 21:15:28 (permalink)
oh yeah...i can tell those we're all gpu's there! witha  212, that's a gpu over clcok. the 3984 is your cpu over clock.
very nice indeed!!
and here you we're having issues...can't see how now...lol
Q56_Monster
Re:Get It Colder......2 2010/01/04 21:34:12 (permalink)
Thanks John.  Yea, I was having issues.  Power being one and physx being the other.  Got the big ol beefy PCP&C 1200w and never looked back!
Mobo: tbd CPU: tbd
GPU: tbd
RAM: tbd HD: tbd
johnksss
Re:Get It Colder......2 2010/01/04 21:42:40 (permalink)
same physx driver or different one?
nateman_doo
  • Ribbons : 52
Re:Get It Colder......2 2010/01/05 02:46:26 (permalink)
SAWEEETT!!!  your more then halfway to 47K!!  OUTSTANDING Q!
217 bclk is a magic number isn't it
That cold front thats been here all week doesn't have anything to do with it does it?
post edited by nateman_doo - 2010/01/05 03:36:13
voklskier4452
  • Ribbons : 8
Re:Get It Colder......2 2010/01/05 04:49:11 (permalink)
3oh6
voklskier4452
Well even if this chip turns out to be a bad batch, ive got a i7 860 ready to go as well.   Will also be picking up a Classy and W3540 over the summer.
and yes i will be sure to post up some benchmark results ;)
Q56_Monster
Re:Get It Colder......2 2010/01/05 10:46:38 (permalink)
johnksss
No, the August release one you mentioned.  But I don't think it was the driver, because it did the same as the older one (low physx scores) up until I installed the new PSU.
Mobo: tbd CPU: tbd
GPU: tbd
RAM: tbd HD: tbd
Q56_Monster
Re:Get It Colder......2 2010/01/05 10:48:36 (permalink)
nateman_doo
Yea, and it's supposed to be 10 degrees colder on Friday night!!   "Get it Colder", right?
Mobo: tbd CPU: tbd
GPU: tbd
RAM: tbd HD: tbd
johnksss
Re:Get It Colder......2 2010/01/05 10:52:20 (permalink)
then power was your enemy!
so how much power you running now? total..just 1200 watts?
Q56_Monster
Re:Get It Colder......2 2010/01/05 11:27:19 (permalink)
johnksss
Yea, just the 1200w.  I'm afraid to attach the TT power express 650W...don't even know if it works.  It might have been fried with my enermax, which is now being RMA'd.
Mobo: tbd CPU: tbd
GPU: tbd
RAM: tbd HD: tbd
nateman_doo
  • Ribbons : 52
Re:Get It Colder......2 2010/01/05 11:38:33 (permalink)
ha!  man you better take advantage of that cold weather!!
good to know I can use just my 1200.  I got the 800W for the extra card.
johnksss
Re:Get It Colder......2 2010/01/05 11:46:24 (permalink)
1200 watts ran mine..but it was very close at times...when the peak power draw was at 1350 watts...and i hadn't added my physx card yet...lol (heavily over clocked gpus and cpu)
nateman_doo
  • Ribbons : 52
Re:Get It Colder......2 2010/01/05 12:10:31 (permalink)
I think I am going to finish this RMA process and get back in the swing of things.  John, hows your 'project' treating you?  dial in any good stuff with it?
johnksss
Re:Get It Colder......2 2010/01/05 12:13:54 (permalink)
not yet...im a bit scared with this new bread of cpu...seems they want to be stuck in the low bclk range. i managed to get up to 226, but locked at 227... when i was able to boot 230+ with no problems at all.
nateman_doo
  • Ribbons : 52
Re:Get It Colder......2 2010/01/05 12:17:53 (permalink)
you got a new CPU?  or is this the new board you got?
johnksss
Re:Get It Colder......2 2010/01/05 12:21:23 (permalink)
everything is different.
and it's no where near where it should be. and the cpu is of the 3900 batch.
Q56_Monster
Re:Get It Colder......2 2010/01/05 15:28:16 (permalink)
What RMA you got going Nate?  I thought you just got a dual pcb 295 back from RMA.  Did it not work well?
Mobo: tbd CPU: tbd
GPU: tbd
RAM: tbd HD: tbd
nateman_doo
  • Ribbons : 52
Re:Get It Colder......2 2010/01/05 15:35:57 (permalink)
new motherboard.  My ram slot was bad.
