I have a problem, my GTX 260's are not detecting my monitor only with the DVI port. It is labeled as "Digital Display" under the Nvidia Control Panel instead of VW246H (ASUS VW246H Monitor). It started to happen after I had dusted my PC. The monitors native resolution is at 1920x1080, but the resolution could only max 1280x720 and could not detect the native resolution of 1920x1080. Are there any solutions to this? The DVI port on my GTX 260's work fine when I used the DVI-to-HDMI adapter (The adapter was placed on the GTX 260) and so did my Xbox 360 Slim when I connected the DVI-to-HDMI (Xbox 360 Slim does not have a DVI port, so I connected the adapter to the monitor) to the monitor and displayed full HD resolution. I'm really frustrated right now, can anyone please offer a solution?
Also, during the PC load screen (The screen where you could access the BIOS) where all the Hard drives, DVD Drives, and devices are displayed, the resolutions differ. When I used the HDMI-to-DVI adapter, the boot screen resolution was displayed in the native resolution of 1920x1080. When I used the DVI cable, the boot screen resolutions were enormous.
Is this caused by a faulty DVI cord or something else?
