Geforce GTX 550Ti 2gb Graphics card problem?
Achroth
2012/08/17 18:10:40 (permalink)
I recently got a new graphics card, i got the GeForce GTX 550Ti 2gb and im having some issues. Ever since i installed (i don't even know if i installed it correctly i just winged it, but i mean its working right now i see everything fine) every so often my computer will freeze or the image will stutter and freeze, the fans seem to be blowing really loud also. I think i have successfully deleted the old drivers from my computer since they're not showing up on the "Uninstall a Program" in Control Panel and i have downloaded the newest drivers for the new graphics card.
Computer specs:
Windows 7 Home Premium 64-Bit (if this matters)
Processor: AMD Anthlon(tm) II X2 260 Processor ~3.2GHz
Memory: 8192MB RAM
Any help is appreciated!
Thanks! Let me know if you need additional info and where i can locate it for you.
Box says minimum watt supply needed is 400w and i have a 500w power supply!
I did the update drivers step as indicated and it says i have the latest drivers already installed.
I just tested with speed fan and here are the results after playing a game:
56C ~ GPU
51C ~ Temp1
50C~ CPU
And yes this only happens when im playing a game.
Sometimes comp drops to like 04FPS and i have to restart to get it working again
28 Replies Related Threads
    FUSIONCHA0S
    Re:Geforce GTX 550Ti 2gb Graphics card problem? 2012/08/17 20:00:21 (permalink)
    First things first, what version is your gpu? is it stock clock, overclock, or superclock?  Next, have you messed with any of the settings in evga precision?  If none of those, then it might not be your gpu.  just because your screen freezes does not mean it is your gpu.  It could possibly be your CPU or ram.  But if your fps is dropping to 4, then it seems like its throttleing.
    ajax7302
    Re:Geforce GTX 550Ti 2gb Graphics card problem? 2012/08/17 22:39:16 (permalink)
    im having a problem where i tab out from my game and when i tab back the card is using 99% processing power and making them game lag
    Achroth
    Re:Geforce GTX 550Ti 2gb Graphics card problem? 2012/08/17 22:56:17 (permalink)
    @Fusionchaos
    I havent messed with any of the clocking stuff ever since i bought this already built computer from wal mart so its stock clock. I don't know what the problem is, i was just guessing it was the graphics card since all this started when i put in this new graphics card. Computer would run perfect with the last graphics card so i assumed the graphics card was the issue.
    maniacvvv
    • Ribbons : 159
    Re:Geforce GTX 550Ti 2gb Graphics card problem? 2012/08/17 23:12:40 (permalink)
    I highly suggest that you -uninstall- SpeedFan
    *SpeedFan is KNOWN to have serious issues when using Windows 7, a modern 500 series Nvidia card and using such older MB/BIOS/CPU
    Use the latest version or Precison or Afterburner
    Achroth
    Re:Geforce GTX 550Ti 2gb Graphics card problem? 2012/08/17 23:17:06 (permalink)
    I recently just installed speedfan, just because someone asked me what were the temps on my computer but i never use it.
    maniacvvv
    • Ribbons : 159
    Re:Geforce GTX 550Ti 2gb Graphics card problem? 2012/08/17 23:19:53 (permalink)
    Uninstall it
    Use the latest version of EVGA Precision or MSI Afterburner to monitor your videocard
    If the fans are "Blowing really loud" as you said, then you might be having temp issues due to airflow
    What computer case are you using?
    post edited by maniacvvv - 2012/08/17 23:22:01
    Achroth
    Re:Geforce GTX 550Ti 2gb Graphics card problem? 2012/08/18 00:19:38 (permalink)
    Alright, will do.
    Well i purchase this computer from Walmart heres the item page.
    http://www.walmart.com/ip/CyberpowerPC-Gamer-Ultra-GUA120-Desktop-PC-with-AMD-Athlon-II-X2-260-Processor-ATI-Radeon-HD-6450-1GB-VGA-Card-and-Windows-7-Home-Premium/16672334
    Only thing i have modified was adding more ram to make it 8gbs and new graphics card
    maniacvvv
    • Ribbons : 159
    maniacvvv
    • Ribbons : 159
    Re:Geforce GTX 550Ti 2gb Graphics card problem? 2012/08/18 00:30:29 (permalink)
    You say you "added" RAM
    That system comes with 4 gigs.....
    Did you buy (4) 2gig sticks to make 8gigs -or- did you buy (2) more 2gig sticks to "add" to the ones you had?
    If you did just buy (2) more sticks, what is the exact make and model of the "extra" sticks you bought?
    I belive that THIS IS PROBABLY your primary issue
    post edited by maniacvvv - 2012/08/18 00:55:46
    maniacvvv
    • Ribbons : 159
    Re:Geforce GTX 550Ti 2gb Graphics card problem? 2012/08/18 00:34:51 (permalink)
    EDITED until we see how you respond to the RAM question
    post edited by maniacvvv - 2012/08/18 00:56:41
    Achroth
    Re:Geforce GTX 550Ti 2gb Graphics card problem? 2012/08/18 00:56:05 (permalink)
    Motherboard only has 2 ram slots so i purchased (2) 4gb ram sticks.
    As for the models and stuff ill check and see if its really necessary sinc eim using the comp right now but will find out if needed.
    maniacvvv
    • Ribbons : 159
    Re:Geforce GTX 550Ti 2gb Graphics card problem? 2012/08/18 00:58:45 (permalink)
    Achroth
    Where did you get the sticks you added?
    I could not find any information on the installed RAM (that came with your system), so how did you buy sticks that are matches for what you had?
    I belive that this is what is causing your problem
    post edited by maniacvvv - 2012/08/18 01:01:02
    Achroth
    Re:Geforce GTX 550Ti 2gb Graphics card problem? 2012/08/18 01:05:41 (permalink)
    Im sorry i added (1) 4gb ram stick to make it 8gb.
    I purchased the ram stick from a local store called Geeks they have a website also called "geeks.com"
    I personally dont know anything about computer hardware all i did was see that it was 4gb and that it fit my motherboard and i bought it and put it on turned on the computer and played.
    I will open up my computer and let you know the models of the ram sticks.
    maniacvvv
    • Ribbons : 159
    Re:Geforce GTX 550Ti 2gb Graphics card problem? 2012/08/18 01:12:44 (permalink)
    Shut down the computer, then turn OFF the switch on the powersupply.
    Remove the 4gig stick you added in....  your computer should now work fine.
    Your system uses Dual Channel memory sticks, they come in "pairs" of (2) sticks each.
    By adding in just one stick of non matching RAM you "broke" the Dual channel mode your system uses.
    Your computer uses a very old MB chipset called a NF630
    This chipset can only run certain RAM sticks (speed, voltage), and they -must- be installed in matching pairs.
    I highly suggest you call CyberPower tech support and find out the -EXACT- RAM (with Speed, timings and voltage) needed for your system. Then either buy a "matching" pair for the sticks you have, or throw away what you have and replace it with "new" sticks (always in matching pairs) that go with your motherboard (speed, voltage) that you got the information on from CyberPower.
    For now, just remove that stick you added and see if the problems go away or not
    post edited by maniacvvv - 2012/08/18 01:24:19
    Achroth
    Re:Geforce GTX 550Ti 2gb Graphics card problem? 2012/08/18 01:27:27 (permalink)
    I took the ram sticks off and i copied everything in each sticker from each ram.
    And response to your feedback i don't remember which exactly was the one i purchased since i purchased long time ago when i got the computer and this problem only started happening when i purchased this new graphics card.
    stick #1:
    Cendyne
    4gb DDR3 PC3-10600
    CDN1333D3D8C9-4G
    VA1 1124A
    stick#2:
    ADATA
    AD301333C4G9-B
    DD3  1333(9) 4 GX16 U-DIMM
    10 241922
    I also got the power supply info in needed.
    Achroth
    Re:Geforce GTX 550Ti 2gb Graphics card problem? 2012/08/18 01:30:56 (permalink)
    I also ran the Driver Fusion program you told me to run and this is what pops up.
    maniacvvv
    • Ribbons : 159
    Re:Geforce GTX 550Ti 2gb Graphics card problem? 2012/08/18 01:42:45 (permalink)
    So you only have (2) sticks installed?
    One 4gig "Cendyne" and one  4gig "ADATA"?
    I can find no information on the ADATA stick whatsoever with the numbers posted.
    The Cendyne stick is not much better...
     http://www.amazon.com/CenDyne-DDR3-PC3-10600-240-Pin-DIMM/dp/B004Y1N4OK/ref=sr_1_1?s=electronics&ie=UTF8&qid=1345279247&sr=1-1&keywords=pc3-10600+ddr3
    Achroth
    Re:Geforce GTX 550Ti 2gb Graphics card problem? 2012/08/18 01:49:55 (permalink)
    Yes that is correct i only have (2) sticks no more slots for more.
    Thats all the info on the stickers on the RAM sticks.
    So out of the 2 which one you recommend i take out?
    maniacvvv
    • Ribbons : 159
    Re:Geforce GTX 550Ti 2gb Graphics card problem? 2012/08/18 01:51:48 (permalink)
    Run a analyze pass on "AMD Display Drivers"
    see what comes up
    For the RAM sticks I guess they were working, put them back in (same slots). We can check them with CPUZ later.
    Its 2am here, how about we pick this back up tomorrow night?
    Achroth
    Re:Geforce GTX 550Ti 2gb Graphics card problem? 2012/08/18 01:56:57 (permalink)
    Yes thats fine ! I really appreciate your help, i will look forward to a reply from you on here.
    Do you accept donations through paypal for your help? Or anything i can do for your help?
    I ran the Analyze on the Driver Fusion for AMD and i got a bunch on different files
    Type: Display Location: C:\Windows\system32 for a lot of files
    Also different display files with different sources:
    Source: Directory
    Source: Registry Key
    Source: Service
    post edited by Achroth - 2012/08/18 02:01:16
    maniacvvv
    • Ribbons : 159
    Re:Geforce GTX 550Ti 2gb Graphics card problem? 2012/08/18 02:04:41 (permalink)
    Achroth
    I will be here (on the forums) on and off tomorrow during the day, and for certain be here tomorrow night after 9pm PST for 2-3hrs
    I have never accepted anything from the people I help, but thanks for offering
    If we get you fixed up, just do something nice for someone else bro.....
    maniacvvv
    • Ribbons : 159
    Re:Geforce GTX 550Ti 2gb Graphics card problem? 2012/08/18 02:06:10 (permalink)
    Achroth
    Source: Directory
    Source: Service
    Yeah, as expected.... we will have some work to do tomorrow bro. Just hang tight till then
    If you have some free time, read over my Nvidia driver guide http://forums.evga.com/fb.ashx?m=1174372
    Dont do -anything- just yet, but just reading up will help you understand what we will be doing tomorrow
    *If you live in the U.S. I may just give you my phone number and walk you thru the process
    post edited by maniacvvv - 2012/08/18 02:10:04
    #23
    Achroth
    Re:Geforce GTX 550Ti 2gb Graphics card problem? 2012/08/18 02:14:01 (permalink)
    Oh ok thanks ! I appreciate it greatly, this has been frustrating me for days!
    And yes i live in Cali, we can do it phone or over skype doesnt matter to me!
    And yeah ive been reading the guide >.o
    #24
    maniacvvv
    • Ribbons : 159
    Re:Geforce GTX 550Ti 2gb Graphics card problem? 2012/08/18 02:15:38 (permalink)
    OK, California.. thats great, same time zone.
    I am going to PM you my number, check your PMs
    #25
    maniacvvv
    • Ribbons : 159
    Re:Geforce GTX 550Ti 2gb Graphics card problem? 2012/08/18 10:02:34 (permalink)
    Good Morning, call me anytime bro
    #26
    Achroth
    Re:Geforce GTX 550Ti 2gb Graphics card problem? 2012/08/18 12:01:38 (permalink)
    THANK YOU SO VERY MUCH!!!
    Maniacvvv took the time out of his day to really help me out, cleaned out my pc and helped me delete my old drivers and install my new ones perfectly.
    My game now runs with 107fps, runs perfect!!
    Helped me out step by step and took the time to explain everything that was going on and answered all my questions.
    Most helpful guy out there and does it for the good and not for any payment or anything just because he really wants to help!
    Im really grateful he helped me out and got me sorted out!
    Thanks Maniacvvv!!
    #27
    maniacvvv
    • Ribbons : 159
    Re:Geforce GTX 550Ti 2gb Graphics card problem? 2012/08/18 12:26:55 (permalink)
    Your most welcome bro, was pleasure to work with you
    Thats what the EVGA fourms are all about
    #28
    AgentDae
    Re:Geforce GTX 550Ti 2gb Graphics card problem? 2012/10/26 13:26:54 (permalink)
    Could you guys tell me how the problem was resolved i seem to have the same issue
    #29
