GTX 980 KINGPIN LED keeps going out, also weird behavior
ssj92
2015/11/24 21:57:42 (permalink)
So at first both cards LED would go out and shutting down the computer and turning it back on would solve the issue. The bottom card is completely fine now, but the top card's LED will randomly start blinking then turn off. Shutting off the computer and turning it back on is the only way to restore the LED.
Now another weird thing is, I cannot control the LED anymore for card 1. Also, in the classy voltage tool, the first card has a different option at the bottom, as can be seen in the pics.
Here's a video of what happens: https://vid.me/K1VU
Also I did a bench at 15XX/8000 : http://www.3dmark.com/3dm11/10548971
and 15XX/8400: http://www.3dmark.com/3dm/9404366
Do those scores seem right?
Thanks
Alienware Area-51M Laptop: Intel Core i9-9900K @ 5.3Ghz | nVidia GeForce RTX 2080
Alienware Aurora R4 Desktop: Intel Core i9 10980XE | nVidia Titan V
Alienware M18xR2 Laptop: Intel Core i7 3920XM @ 4.7Ghz | nVidia Quadro RTX 3000
Alienware X14 Laptop: Intel Core i7 12700H | nVidia GeForce RTX 3060
7 Replies Related Threads
    Vipergtspa
    Re: GTX 980 KINGPIN LED keeps going out, also weird behavior 2015/11/25 10:23:22 (permalink)
    My two KPE 980's and 980Ti's both did that and EVGA completely blew me off with helping solve this issue, I have just lived with it.
    If you do find a fix please let me know.
    Thanks
    Intel i7-8700K 5.1GHz 1.344V-Asus ROG Maximus X Formula Z370-EVGA GTX 1080 Ti FE 2100MHz/6496MHz -16GB Corsair Dominator Platinum@3200Mhz-EVGA SuperNOVA 1000 T2-EK Custom Water Loop-2 Samsung 850 EVO 500GB SSD -1 Samsung 970 Pro 500GB M.2-Phantek Enthoo Luxe Tempered Glass-Windows 10 64bit-Dell S2716DG 27" G-Sync 2560X1440-Klipsch 2.1 Pro Media Speakers
    ssj92
    Re: GTX 980 KINGPIN LED keeps going out, also weird behavior 2015/11/25 13:12:41 (permalink)
    Can you at least control the LED once you turn off the computer and back on?
    Also does your classy controller show the same options for both cards? When I originally got the cards, both cards had the same options but after the LED turned off it hasn't gone back to the same and I haven't been able to change the LED.
    Might just return the cards if EVGA didn't help you either. Wonder why it happens.
    Re: GTX 980 KINGPIN LED keeps going out, also weird behavior 2015/11/25 13:19:28 (permalink)
    Are both the cards running the same vbios? If not, try flashing the vbios from card 2 onto 1 to see if it fixes the options issue.
    ssj92
    Re: GTX 980 KINGPIN LED keeps going out, also weird behavior 2015/11/25 13:22:38 (permalink)
    Yeah same vBios on both cards, I tried all three vBIOS' on both cards and still the same issue. What concerns me more is the fact that I can no longer control the LED and that the first card has PWM freq now instead of OCP and Vdroop. I feel like there may be a underlying problem.
    Also does it look like the cards are performing fine judging by the benchmarks? The Firestrike GPU score seems kind of low to me.
    Re: GTX 980 KINGPIN LED keeps going out, also weird behavior 2015/11/25 13:46:28 (permalink)
    ssj92
    Yes, but they certainly aren't the fastest.
    Vipergtspa
    Re: GTX 980 KINGPIN LED keeps going out, also weird behavior 2015/11/25 14:03:54 (permalink)
    ssj92
    Yes, after rebooting I can control the led's with PX. If I do not restart the controls are blacked out and nothing can be changed.
    I have to manually set both card's for it to work.
    EVGA is normally very helpful but with this issue they started to help then just never answered my phone calls or emails.
    There is a how to that fixes the led flicker issue, it's on the kingpin forums. However I do not fill comfortable doing that and I also feel like with the led's turning off and not being able to control until the system is rebooted there must be other issues going on.
    I have not looked into this since end of summer, so let me know if you find anything out.
    Thanks
    ssj92
    Re: GTX 980 KINGPIN LED keeps going out, also weird behavior 2015/11/26 09:20:32 (permalink)
    Well I regained control of the LED by reinstalling the driver (clean) and the classy tool now shows the same option, but the LED will still go out on the top card.
