GTX 980 ACX 2.0 running a little hot at Idle.
ReconAvenger
2015/05/26 11:39:54 (permalink)
So i recently built a new PC and installed EVGA's GTX 980 ACX 2.0 model into it after reading some pretty good reviews about it. About 2 days ago i noticed that the GPU would run 37-40° C when idling. Prior to purchasing the model I read multiple reviews that stated that it should be running at 34° C. Should I be concerned or is this supposed to be normal? If not, any ideas or methods i should take into fixing it?
7 Replies Related Threads
    Re: GTX 980 ACX 2.0 running a little hot at Idle. 2015/05/26 11:43:38 (permalink)
    34-40C is perfectly normal depending on your room temp.
    bsmegreg
    Re: GTX 980 ACX 2.0 running a little hot at Idle. 2015/05/26 11:44:07 (permalink)
    I would not stress over the temp, it could idle at 60C and be okay forever. 3C is really nothing for these cards and everyone's case and room temp etc.
    Fennicillin
    Re: GTX 980 ACX 2.0 running a little hot at Idle. 2015/05/26 16:10:24 (permalink)
    Sounds perfectly normal.
    djmorgan
    Re: GTX 980 ACX 2.0 running a little hot at Idle. 2015/05/26 16:43:49 (permalink)
    Need to know your ambient temp! the temp surrounding your box, clearly if the outside temp is 40 Degrees you are not going to have your PC components less than that with the exception of refrigerated cooling in your PC. Now that would be worth seeing
    David
    ASUS P6X58D Premium LGA1366 X58
    Intel core I7 950 @3.68GHZ CPU
    1 X EVGA GTX 980 FTW
    12Gb Corsair TR3X3G1600C8D 1600MHz
    Corsair H70 Water cooling
    Corsair HX1000W PSU
    Intel 240Gb 510 SSD
    2 x Seagate ST31000524AS 1Tb @ 7200rpm
    Dual 24" 144Hz 2Ms 1920 x 1080 monitors
    Windows 7 Pro X64 SP1
    bsmegreg
    Re: GTX 980 ACX 2.0 running a little hot at Idle. 2015/05/26 20:53:21 (permalink)
    djmorgan
    David
    Stick it in one of those walk in freezers and see it cool itself nicely.
    stalinx20
    Re: GTX 980 ACX 2.0 running a little hot at Idle. 2015/05/27 06:24:47 (permalink)
    Mine runs idle between 36-37. it's fine.
    EVGA X79 Dark
    2080 Black edition
    980
    EVGA 1000 gold PSU (Gold)
    4820K CPU
    16x G-skill
    ReconAvenger
    Re: GTX 980 ACX 2.0 running a little hot at Idle. 2015/05/27 09:09:35 (permalink)
    Thanks for all the insight everyone. It's put me at ease, really appreciate it.
    post edited by ReconAvenger - 2015/05/27 09:13:20
