Scaro
SO I have 2 of this cards and I have manage to keep both cards around 70-80 (usually the first cards reaches 80) while gaming or doing stress test... I seriously don't like this temperatures and therefor I would like to use a different method of cooling now my question is this, can I use 2 H80i gt for my cards I have plenty space to fit 2 of this (780t corsair) and if this is possible where can i find the proper kit for this particular cards ?
- Ribbons : 282
Re: GTX 970 ftw water cooling"?"
2015/05/04 12:00:29
Add some Images/Photos to your and run some Benchmarks and post back.
MrImSoGood
2015/05/04 13:47:56
There is no watercoolin kit for video cards but you can use a CPU kit and just buy some waterblocks for them I say do a proper watercooling setup for them
Scaro
2015/05/04 13:52:35
Okay I update some info on my MODS RIGS page add a few photos and a 3dmark becnhmark , for now I have remove 1 of my cards until I found a better solution for my "cooling" issue ( is not such of big deal for most but to me it bothers me )
- Ribbons : 282
2015/05/04 14:07:35
Because your GPU is pushing the Air into your Windows on the Side Panel it might be a little hard to cool it down anymore then you now have it. One option you could review is to put a singe 200mm Fan in that Windows Pull the Air Out of the Case for an Exhaust of the hot air coming off the GPU. Most 200mm fans are also really quiet.
- Ribbons : 282
2015/05/04 14:09:06
Scaro Okay I update some info on my MODS RIGS page add a few photos and a 3dmark becnhmark , for now I have remove 1 of my cards until I found a better solution for my "cooling" issue ( is not such of big deal for most but to me it bothers me )
What slot do you have the 2nd card installed? Do you have one open or two open slots between them? +1 on your MODS RIGS.
Scaro
2015/05/04 14:12:13
Scaro
2015/05/04 14:15:05
I leave 1 slot between the cards maybe i should drop it down another slot since this mobo has plenty and thanks :) I really need to get a better psu and do more cable management
- Ribbons : 282
2015/05/04 14:37:24
Scaro I leave 1 slot between the cards maybe i should drop it down another slot since this mobo has plenty and thanks :) I really need to get a better psu and do more cable management
I would use Slot 1 Primary Card and Slot 4 for the Secondary Card. Remember to leave Slot 3 & 6 Empty this way you still have both cards running at X16. PCI-E Lane Distribution PE1 – x16 (x8 if PE2 is used) PE2 – x16 (x8 if PE3 is used) PE3 – x8 PE4 – x16 (x8 if PE6 is used) PE5 – x1 PE6 – x8
Scaro
2015/05/05 17:32:38
Well got me a GTX 980 ftw and gonna sell my other 2 GTX 970 and with buy a second one when ever that happen :) also ordering the evga cooling kit
stalinx20
2015/05/06 04:50:17
You obviously had some kind of airflow deficiency while using your gtx 970's. The cards shouldnt do that. I'm getting 60 max while running high demand software. You have a lack of airflow somewhere. As Bcavnough suggested, putting a 200mm fan would be nice on the window.
post edited by stalinx20 - 2015/05/06 04:54:27
Scaro
2015/05/06 08:56:28
Not sure how you manage to keep those cards @ 60 during any stress test ... you did some tweaking with the fans ?
stalinx20
2015/05/06 09:32:47
Scaro Not sure how you manage to keep those cards @ 60 during any stress test ... you did some tweaking with the fans ?
Yea, just a tad. Good airflow helps as well.
Scaro
2015/05/06 10:41:31
I have a 780t and I have plenty of airflow look at my mods rigs pics
stalinx20
2015/05/06 10:49:45
Scaro I have a 780t and I have plenty of airflow look at my mods rigs pics
We see that, but the suggestion was think about putting a 200mm fan on the side window, or 2 140mm fans to put airflow on the cards themselves.
Scaro
2015/05/06 15:33:28
I see that as well but I'm actually gonna use the evga water cooling kit that comes with the hybrid :) , so my high temperatures problems will be gone !
