Re: GTX 960 FTW GAMING ACX 2.0 Fan problems
2016/05/25 17:33:38
Pulled it out, plugged in properly. Even in GPU stress test, 0 rpm confirmed by my hand, but the monitor shows 0 rpm even under extreme load. Either the PCB connection is faulty or the fans are. Since both fans are out, I bet it's the connector on the board. I had to put my 7850 2GB back in for now.
