Re: GTX 960 2 GB ACX 2.0,SSC PCI 8 PIN TO PCI 6 PIN
2015/07/07 09:12:02
I would use option 1 if I was you, but you should also reconsider upgrading your power supply. I don't know you budget but evga has a lot of good budget power supplies that will accommodate you GPU nicely. Evga powersupplies have better ripple compressing, less noise, while having 80+ efficiency and higher.
Anyway, have a nice day ;)
