GTX 690 serious problem
BullDempsey
2015/01/26 00:47:56 (permalink)
For some reason, one of the gpus are freaking out
Everything is mega laggy. The other gpu is at like, 6%. And my brother has the same setup and his works fine.
I've updated my drivers before, but also tried going back to older ones to see if that was the problem.
Is my card just broke? What would make one gpu hog all the power? Please help me!
5 Replies Related Threads
    Re: GTX 690 serious problem 2015/01/26 12:00:35 (permalink)
    Looks like the card is done. RMA time if you're still under warranty.
    BullDempsey
    Re: GTX 690 serious problem 2015/01/26 13:20:41 (permalink)
    So you're positive it's finished? Cause I just wanted some closure, even that would be nice to know. And no, sadly the warranty is long passed. Thanks, though. Time to get a new card.
    I mean, I've only had the card for 2 years going on 3. Wonder what broke it. Only thing I can think that I did that my bro didn't do was update drivers. But everyone does that :/
    Re: GTX 690 serious problem 2015/01/26 13:37:52 (permalink)
    Yes, i'm pretty sure the card is done. Try testing it in your brothers PC to see if the card has the same problem running in his system, if it does end up having the same issue in your bothers system the card is defective.
    BullDempsey
    Re: GTX 690 serious problem 2015/01/26 15:45:09 (permalink)
    Alright. Thanks a bunch.
    _JamesR
    Re: GTX 690 serious problem 2015/01/27 13:01:03 (permalink)
    I concur with Sajin, it does look like one of the GPUs on your 690 has failed. If you'd like to inquire about warranty replacement, please feel free to contact us by phone at 888-881-EVGA (3842) or send us an email at support@evga.com. We can help assist with warranty options from there.
    EVGA Z97 Classified w/ i7 4790 | 32GB Crucial Ballistix Elite | 2x EVGA GTX 980 Ti ACX 2.0 | EVGA 1000w G2 | Samsung EVO 840 120GB | Samsung 850 EVO 250GB | Seagate 3TB | 3x WD 2TB (Raid-5) | Corsair H100i GTX | 3x Asus VS278P-Q 27" 1080p 1ms GTG monitor (surround) | 1 Monoprice 28" 4K 5ms GTG (accessory)
