xizorgetspeed
Hey guys, EVGA officially rocks, and so does this community! I swear we've got a good thing going here! I just landed the FTW and this makes it officially my 4th EVGA card (Pair of 8800GTs -> GTX 480 -> 1080 FTW) So I have been away from the scene for a while and my current monitor is the Dell P2715q 4K IPS monitor. http://accessories.us.dell.com/sna/productdetail.aspx?c=us&cs=19&l=en&sku=210-ADOFIt's 60hz. I picked it about a year ago and at that time I wasn't gaming at all, used it with my MacBook Pro, work stuff, hobby photographer, just wanted a nice display and colour. Absolutely love this monitor... Although, I'm wondering how great it is for gaming... I had a buddy come over and he owns the Acer GSYNC 27 IPS 1440p monitor. XB271HU http://www.ncix.com/detail/acer-predator-xb271hu-bmiprz-27in-33-118288.htm He mentioned he can notice the difference in GSYNC and non GSYNC, though at that time I didn't have my GTX 1080 yet and he had brought his system which had a GTX 980 in it. Basically, I'm trying to figure out what to do. Now that I'm looking for it, I can see that gameplay is not smooth. I can't always see frames cause it seems FRAPS is hit/miss (is there a better tool nowadays?). I'd like to have the best possible experience and visual quality. So I'm hoping you guys can help me between the following. 1. Keep my display. 2. Acer XB271HU 3. Acer X34 When it comes to the 4K options (1 and 3) I'm worried about performance. A single 1080 isn't quite there and I don't want SLI. Although, the X34 isn't quite full 4K so it won't tax as much. If you have an x34, mind sharing your results? Also, because it's a bigger screen 34" I'm worried it won't look as sharp, PPI is higher. Or am I incorrect in this thinking? Option 2, I know will get me the best performance, cause this card can crush any current game on ultra at 1440p, but then again, how does this compare to 4K res... is it noticeable? Aaaah... first world problems ;) Thanks in advance for your help guys!
richurd
Re: GTX 1080 Owners - What monitor are you using? Need recommendation please.
2016/07/23 09:26:26
If you don't want to SLI, don't go with the x34. I have the Asus PG348Q, which is the same panel and at first I didn't want to SLI but the 100 FPS capable caused me to do it.
jgonz
2016/07/23 09:44:37
Asus PG278Q RoG Swift 144hz G-Sync I have had it since it launched and I LOVE IT!
ASUS x99-A i7 5820k @ 4.5 GHz Corsair Vengeance LPX 16 GB 2800mhz (@ 2800 MHz) 240 gig Intel 530 SSD EVGA GTX 1080 Founders Edition Klipsch Pro Media 2.1 Speakers 2x 1T Storage Hard Drives EVGA SuperNOVA 1000 G2 Asus PG278Q RoG Swift 144hz G-Sync CM Storm Keyboard Razer Deathadder Mouse
Meric1837
2016/07/23 10:40:57
I've got a 1080 SC and the Acer X34, works fine for me. Most games stay in the 70-90fps area based on my tweaking. Older games max the 100hz refresh. I don't use MSAA that much, but apart from that, I have no issues running with one 1080. I do HIGHLY recommend Gsync. This is my first gsync monitor, and there is a huge difference in how smooth everything is. The 100hz is great too, I feel that much past that you get diminishing returns, but the 75-100hz range is a nice sweet spot; and I'm coming from 1080p surround at 120hz. The X34 was definitely an upgrade from that. Wouldn't bother with 4K just yet, the ultrawide aspect ratio gets my vote.
Processor: Intel i7-6700K GPU: EVGA GTX 1080 SC (08G-P4-6183-KR)RAM: 16GB G.Skill DDR4-3000 Motherboard: Asus Z170 RangerSSD: 400GB Intel 750 SeriesPower: EVGA 850w P2Monitor: Acer X34 @100Hz G-SyncOS: Windows 10 Home 64-bit Dog: Corgi, Air Cooled w/Tongue Heatsink
d.burnette
- Ribbons : 12
2016/07/23 10:47:46
Man that X34 Predator does look sweet. I really don't need the temptation lol.
Don EVGA X-79 DarkIntel I7 4820K @ 4.50 Ghz (+35 Vcore offset) Bios 2.13Corsair H100i cooling systemEVGA GTX 1080 FTW 16 gb (4x4) Corsair Dominator Platinum 2133 MHz 1.5v ram2ea Samsung 840 Pro 256gb SSD's ( non raid)Sound Blaster ZKlipsch 2.1 Pro Media SpeakersNZXT Phantom 820 caseWindows 10 64 Bit
Crimson AL
2016/07/23 10:58:26
27" 4k seems too small for that resolution....I have the x34 and would like to get 4k but only 32" or larger with Gsync. 21:9 is an experience for sure and I love it. My second monitor is the ROG Swift 144hz 1440 monitor and I don't miss the extra 20-44 refresh difference (120/144 vs 100). It's 344x1440 so it's the same as 2560x1440 but with more resolution on the side to answer your question about it being wider and that affecting the look, it doesn't. But odds are though once you play in 21:9 the 16:9 will looks cramped if you go back to it. Downside is not all movies will fill the screen and some games don't support it (Looking at you Blizzard). For me when I go 4k it'll be 32" or larger monitor. IMO the 27" is too small for 4k for me.
Systom
2016/07/23 11:11:16
the best middle ground monitor between higher resolutions/higher frames so far and for a while now is the X34/PG348Q. I have the X34 and have used a 1080 Strix, in Witcher 3, I would get anywhere from 50-80FPS, everything maxed out, with Gsync, you never miss a beat. you can go higher resolution for 4k but trapped at 60hz (until they breach 60hz, this is not an option for me personally. also agree that 27" 4k is too small. although have not personally tested, many say the 1080 handles 4k/60hz pretty well.) or if you want higher than 100hz frames which many will argue is not very distinguishable between 120hz/144hz, your next option would be 1440p/144hz, 165hz with Acer/Asus. (I don't think I could go back to non-ultrawide, I've always used dual monitors until I switched to ultrawide, for gaming or productivity. only downside is not all games support it.)
2016/07/23 11:20:06
jgonz Asus PG278Q RoG Swift 144hz G-Sync I have had it since it launched and I LOVE IT!
+1 Truly a stellar monitor. It was worth the fight to find it in stock. They can be had for much cheaper now. I've seen them in the marketplace here for about $400 which is an ABSOLUTE STEAL!
Cheetah13mo
2016/07/23 11:33:22
I have this as well and goes great with my 1080 SC. Couldn't be happier with the visuals and performance.
Core i7 4790K 212 Evo Cooler 250 SSD 1Tb HDD 32 Gb ram EVGA GTX 1080 SC EVGA 850 GS PSU Google Fiber: 944 Mb up and down
CHammock
2016/07/23 11:57:35
This. The Swift is a great monitor and I love mine.
Currently under construction
Beasthunt
2016/07/23 11:59:22
I have the Dell s2716dg, it's a fantastic monitor. I think it's on sale right now as well. Gsync, 144hz, ulmb and all that jazz.
xizorgetspeed
2016/07/23 12:42:25
For the x34 owners, any issues with games not supporting ultra wide? Besides blizzard I guess...
Meric1837
2016/07/23 13:13:08
xizorgetspeed For the x34 owners, any issues with games not supporting ultra wide? Besides blizzard I guess...
Not really. I came from surround and it's easier than that to work out. Fallout 4 was kinda tricky, but I got it sorted. Probably wanna download Flawless Widescreen and keep http://www.wsgf.org/ bookmarked.
xizorgetspeed
2016/07/23 13:37:46
Meric1837
Meaning it's not plug and play, or just choose the resolution in game menu and away you go...
DarthYodi
2016/07/23 13:44:54
I have the 24" version of the Dell 4K you listed as my center monitor. It works great for me, I just use scaling in Windows to combat how small everything is and compatiblity mode the games to disable scaling.
hehehippie
2016/07/23 14:21:40
Meric1837
what this guy said. i have a Dell U3415W overclocked to 80Hz and love it. i don't think i'll be going back to 16:9 for my desktop.
Snow White: NZXT Switch 810 case, Intel 6700k @ 4.7Ghz, Asus Z170 Deluxe MoBo, NZXT Kraken x61, 16GB Corsair Dominator Platinum DDR4-3000 with Light Bar Kit, Samsung 850 Pro 512GB, SeaSonic Snow Silent 750w PSU, Windows 10 Pro, (4) Noctua fans, Dell U3415W Ultrawide Monitor @ 80Hz, Corsair Strafe RGB Silent, Corsair SP2500 2.1 System, White CableMod Kit, EVGA 1080 FTW Hybrid - EK Vardar F4-120ER (black cable) on the radiator
TheBurgerSlayer
2016/07/23 15:23:00
I had an Asus VG248QE, and stepped up to a PG279Q right before the 1080. Absolutely no complaints here, great monitor.
R.O.G. - Classified CPU: Intel Core i7-6700K @ 4.5GHz 1.4v | AiO CPU Cooler: NZXT Kraken X61 | Motherboard: Asus Maximus VIII Formula | RAM: Avexir DDR4 ROG Impact 16GB 2666MHz |SSD: (2) AMD Radeon R7 (120GB + 480GB) | GPU: EVGA GTX 1080 Classified | PSU: EVGA 1000P2 |Chassis: Phanteks Evolv ATX - Black | Monitor: Asus PG279Q 165Hz IPS GSync | Mouse: Razer Naga (Green) | Keyboard: Razer Blackwidow Ultimate (Green/Orange Switches) | Headset: SteelSeries Sibera 800 | Controller: Microsoft XBOX Elite | OS: Windows 10 64bit Home Edition | Lighting: Corsair RGB LED Strip x3 (RED)
VooDooPC
2016/07/23 15:45:10
I have an Acer XB270HU and my brother has an Asus PG278Q. Before I bought my Acer I used my brother's Asus for a few weeks to see if I wanted a GSYNC monitor or a 4k monitor. I decided to buy the Acer XB270HU. The Acer uses an IPS screen, which I think looks better than the Asus TN screen. The Asus has a weird noticeable grain on the matte screen I really didn't like. The Acer doesn't support Nvidia 3D Vision, if you're into that. The Acer ULMB also only goes up to 100hz, I think the Asus goes up to 120hz, but I always use GSYNC and never use ULMB. If I had to do it again I would still go with the Acer. I am not sure how much of an improvement the PG279Q is over the PG278Q in these regards. I know it uses an IPS panel now. Good luck buying a monitor though. It always makes me nervous because of all the horror stories you read about dead pixels and weird light bleeding stuff.
post edited by VooDooPC - 2016/07/23 16:47:23
xizorgetspeed
2016/07/23 15:52:36
Man, I've confused myself even more. I booted up star wars battlefront on my dell and ran the game on 4K everything ultra and then 1440p everything ultra... I totally noticed the difference in sharpness. I'm thinking if I go with the Acer XB271HU, the image will look like what I see in front of me on my Dell set at 1440p resolution. Of course, my frames are locked at 60. I can disable vsync and get 130 frames on 1440p (70 on 4K), but then I get tearing on this monitor...
Also, the x34 is really 1440p not 4K, the extra pixels are on the edges right, so really the image quality will be similar to 1440p not 4k...
hehehippie
2016/07/23 15:56:14
☄ Helpfulby xizorgetspeed 2016/07/23 17:30:15
there's quite a few videos on Youtube that compare 3440x1440 to 4k. another option would to order from a reputable place like Amazon and return whichever one u don't like.
Systom
2016/07/23 16:11:32
Most likely older games won't support ultrawide, this is where WSGF will help with tweaks/software (flawless widescreen) to make it possible. it may not be plug and play, but it's not very hard to do to take full advantage of your ultrawide monitor. I consider 3440x1440 to be 3K if anything.
hehehippie
2016/07/23 16:30:10
gaming aspect aside, i really love everyday life with my 21:9 monitor. it's like having dual monitors, but without any borders. i can have 3 full sized browsers on my screen if i wanted to.
FancyPilot
2016/07/23 17:22:05
Beasthunt I have the Dell s2716dg, it's a fantastic monitor. I think it's on sale right now as well. Gsync, 144hz, ulmb and all that jazz.
I too have the Dell Gaming S2716DG. Its a 1440p 144hz 1ms G-sync monitor that is amazing and no quality issues like Asus or Acer. Dell is #1 in monitors for a reason. You just have to get a gaming one! Highly, highly recommend this monitor.
~The Mini Beast~ Water cooled I7-6700k OC'd to 4.7 Ghz, EVGA GeForce GTX 1080 FE OC'd to constant 2kmhz, Asus Z170i Pro MB, G.Skill 16GB 3000Mhz Ram, Samsung 950 Pro NVMe SSD, Modified EVGA Hadron Air case with integrated 500W Gold power supply
hehehippie
2016/07/23 17:32:15
i, too, prefer Dell monitors. i wish they made a gaming version of their 21:9 monitors. mine's running at 80Hz and 4 or 5ms response time in 'Fast Mode' so it's good enough for me. i got my U3415W for free, so i can't really complain lol. i'll sell it later on for a bigger 21:9 ratio monitor with G-Sync when one get's released.
post edited by hehehippie - 2016/07/23 17:34:43
xizorgetspeed
2016/07/23 17:33:13
hehehippie there's quite a few videos on Youtube that compare 3440x1440 to 4k. another option would to order from a reputable place like Amazon and return whichever one u don't like.
Lol, I didn't even think of this... Okay people, I appreciate all the advice. I just placed an order for the x34. Got bestbuy to price match another shop and snagged it for $1470ish CDN plus taxes. Just under $1700 all in. Ouch, as much as my 6700k build minus the 1080. I figured, I'd run it through it's paces and like hehehippie said, if I'm not happy, I'll simply return it. BestBuy has no restocking fee or anything like that.
hehehippie
2016/07/23 17:37:08
i think u'll love it, bro. u might be losing a tad bit of sharpness compared to your 4k monitor, but the x34 will feel alot more immersive. u can always adjust the picture to make up for it too. it also has a big wow! factor that a 16:9 monitor cannot duplicate. everyone that has come over to my house has given me compliments on my 21:9 monitor.
FattysGoneWild
2016/07/23 17:40:20
FancyPilot
I can vouch for this monitor. You wont find any thing better for $449 right now. BUT. They do have QC issues. No where near like Asus/Acer though. I received 2 brand new Dell's that was bad. One had a dead pixel right in the middle of the screen. The other brand new replacement had some kind of dirt/smudge physically underneath the screen. I am going on my 3rd replacement. I am working with Dell directly this time. They are sending me a brand new replacement through dell.com The other 2 came from BestBuy.com That should tell you how much I liked the monitor and willing to go the length for a good working one. Bestbuy has been a rock star during this whole process. Zero complaints with them. Dell just needs to improve QC a little bit more. Sorry OP. Just looked and it is now sold out at the $449 price. They did not last long.
post edited by FattysGoneWild - 2016/07/23 17:47:23
HP Envy Phoenix 810-430qe OS: Windows 10 64 bit MOBO: MSI Kaili2 Z97 CPU: Intel i7 4790K liquid cooling RAM: 16GB DDR3 1600 GPU: EVGA GTX 1080 Founders Edition PSU: EVGA SuperNOVA 650 P2 SSD: Samsung 256GB MZ7TE256HMHP HDD: 2TB Seagate Barracuda ST2000DM001 Sound: Logitech Z623 THX 2.1 Speakers Monitor: Dell S2716DG 2560x1440 @144Hz G-Sync calibrated with ColorMunki Display Keyboard: Razer Blackwidow Chroma Mouse: Razer DeathAdder Chroma EVGA Affiliate Code: C3OXU3I2N9
jerzeeloon
2016/07/23 18:19:27
I have a old 23in samsung sync master. Basic 60hz 1080p waiting for one of these gsync monitors to get cheaper. But anyway just got a 50in samsung 4k TV and I been gaming on it and it looks pretty amazing. Even when I play at 1080 it upscales it and looks close to 4k quality without the performance hit.
corsair 350D Asus Maximus VI Gene 4770k @ 4.2ghz 8gb rip jaws X series 1600 888/24 500gb crucial m4 ssd 1tb wd caviar black Corsair AX760 Gtx 980ti
fearpoint
2016/07/23 18:27:56
Same Amazing monitor for gaming!
 Not my fault if you're offended.
richurd
2016/07/23 18:37:48
If you have the funds, dell up3017q. OLED 4K 120mhz. Supposed to be released in March but was pushed back.
