Helpful ReplyHot!GTX 1080 Owners - What monitor are you using? Need recommendation please.
hansot85
Re: GTX 1080 Owners - What monitor are you using? Need recommendation please. 2016/07/28 20:20:22 (permalink)
Another Dell U3415W user here. I love it! I'll never go back to 21:9. Bring on the 4K 21:9 displays!
#61
xizorgetspeed
Re: GTX 1080 Owners - What monitor are you using? Need recommendation please. 2016/07/29 05:05:46 (permalink)
On my x34 (95 hz, screen craps at 100hz) I've been getting 95 frames stable on my 1080 FTW on doom everything turned highest. Witches 3 everything up gives me occasional dips into the 70s, and Tomb raider, everything up dx12 gives me 60s, but it's all butter smooth...
I think I'm keeping the x34. My Dell p2715q panel just doesn't have the response time or refresh rate to be stable at 60 hz. I tested this by turning down settings to make sure I'm getting stable 60+ frames and still I'm noticing skipping and tearing in fast movements.
Now, I purposefully bought from Best Buy right, I'm gonna attempt an exchange to see if I can get a better panel of the X34. The one I got has a dead pixel right in the Center and also 95hz. Wish me luck guys and thanks for all the help and guidance!
#62
nunzmon
Re: GTX 1080 Owners - What monitor are you using? Need recommendation please. 2016/07/29 05:34:37 (permalink)
Just got this..Asus pg348q monitor
Asus Rampage IV blk 4930k @ 4.6 1.29v
4x4g corsair Dominator gt ram 2400 9.11.11.31 1t
2 NVIDIA Titans X hybrid Asus pg348q monitor
#63
KickAssCop
Re: GTX 1080 Owners - What monitor are you using? Need recommendation please. 2016/07/29 05:38:01 (permalink)
Asus PG279Q. I tried the PG348Q but it gave me nausea when playing shooters and was only 100 Hz. With 165 Hz my gaming is blissful.
Intel i7 5930K @ 4.6 Gigawatts | Asus X99 Deluxe | EVGA GTX 980 Ti Classified SLi @ 1506/8200 | ASUS VG278HE 144 Hz 3D LED | Samsung EVO 850 1 TB SSD | Samsung EVO 840 500 GB SSD | Samsung 830 256 GB SSD | WD 1TB 64 MB Black | WD 500 GB 16 MB | WD 250 GB 16 MB | Seagate 80 GB 8 MB | G Skill Ripjaws 16 GB DDR4 2666 | Pioneer Blu Ray Burner | EVGA Supernova 1300W G2 | Cooler Master HAF X | EK Predator 360 | Roccat Kone XTD | Logitech G510s | Logitech G930 | JBL Charge 2
#64
D Apocalypse
Re: GTX 1080 Owners - What monitor are you using? Need recommendation please. 2016/07/29 11:40:00 (permalink)
xizorgetspeed
You're welcome and good luck.  I had a similar but worse issue with the same monitor which I returned.  Mine stopped OC'ing completely!  So it was stuck basically at 75hz.
#65
Yachtor
Re: GTX 1080 Owners - What monitor are you using? Need recommendation please. 2016/07/29 20:06:03 (permalink)
Asus Rog Swift PG348q and 1080FTW.  Monitor overclocked fine to 100Hz on Windows 7.  However, I am only offered 60Hz with my newly installed Windows 10 version even though the monitor menu still says it is boosting to 100Hz.  Any ideas on how to get 100Hz listed in the screen refresh rate drop down box?
#66
hehehippie
Re: GTX 1080 Owners - What monitor are you using? Need recommendation please. 2016/07/29 20:20:41 (permalink)
Yachtor
have u tried changing it in the Nvidia control panel?
Nvidia Control Panel > Change resolution > Customize
Snow White: NZXT Switch 810 case, Intel 6700k @ 4.7Ghz, Asus Z170 Deluxe MoBo, NZXT Kraken x61, 16GB Corsair Dominator Platinum DDR4-3000 with Light Bar Kit, Samsung 850 Pro 512GB, SeaSonic Snow Silent 750w PSU, Windows 10 Pro, (4) Noctua fans, Dell U3415W Ultrawide Monitor @ 80Hz, Corsair Strafe RGB Silent, Corsair SP2500 2.1 System, White CableMod Kit, EVGA 1080 FTW Hybrid - EK Vardar F4-120ER (black cable) on the radiator
#67
Yachtor
Re: GTX 1080 Owners - What monitor are you using? Need recommendation please. 2016/07/29 20:35:46 (permalink)
Thanks for the reply but unfortunately, I need to change the screen refresh rate, not the resolution.
#68
Yachtor
Re: GTX 1080 Owners - What monitor are you using? Need recommendation please. 2016/07/29 20:39:11 (permalink)
Doh, I was too quick on the response..It worked!!!!
#69
hehehippie
Re: GTX 1080 Owners - What monitor are you using? Need recommendation please. 2016/07/29 22:10:36 (permalink)
lol yeah. that's the menu u have to go into to overclock the refresh rate. glad everything worked out.
#70
Balubish
Re: GTX 1080 Owners - What monitor are you using? Need recommendation please. 2016/08/01 01:39:04 (permalink)
So I have an AOC 28" 4K 60Hz display, can I OC that? Is it possible I can break it?
Balubish Tech on Youtube, Gaming, Watercooling etc
Balubish Music - Youtube, Google Store ,Electronic beats
#71
kb5266
Re: GTX 1080 Owners - What monitor are you using? Need recommendation please. 2016/08/01 02:31:26 (permalink)
Using a AMH 409u v2 4k 60hz monitor. Just got it last week and absolutely love the 40" real estate. Have 2 FTW 1080's, but still waiting on the hb 3-slot EVGA sli bridge I ordered, but runs fine with one FTW already. I got the second one to make sure my fps doesn't dip in games with all ultra settings.
Intel Core i7-5820K CPU @ 4.4GHz || PNY Anarchy 64GB (8x8) DDR4 2133 || ASUS x99 Haswell-E Deluxe (BIOS 3101) || EVGA GTX 1080 FTW ACX 3.0 SLI || Corsair H110 || Corsair AX1200 || Corsair Carbide Air 540 ATX Cube Case || LG WH10LS30 & GH24NS50 Optical Drives || Samsung SSD 840 256GB || HGST 7200rpm 6TB & 4TB Internal(s) || Hitachi (2x) 500GB Internal || Western Digital Green 2TB External & 1TB External || Logitech K800 Illuminated Keyboard & MX Performance Mouse w/ 5.1 Surround X-530|| AMH 409u v2 || Windows 10 Education (build 10586), 64-bit
#72
gregoryv
Re: GTX 1080 Owners - What monitor are you using? Need recommendation please. 2016/08/01 02:59:49 (permalink)
1st - Dell U2715H 27" LED IPS
2nd - Dell U2412M 24" LED IPS
Intel i7-6700K @ 4.8GHz | Corsair H110i GTX | Gigabyte Z170X-Gaming 7 | Gskill F4-3000 2x8GB| Samsung 850 EVO 250GB | Sandisk Ultra II 480GB | EVGA GeForce GTX1080  FTW | Corsair 750D airflow | Seasonic 850W 80+ bronze | Asus Xonar D2X |Dell U2715H | Dell U2412M |
#73
nycalex80
Re: GTX 1080 Owners - What monitor are you using? Need recommendation please. 2016/08/01 08:03:37 (permalink)
ROG swift pg278q.
i was an early adopter of g-sync. dropped 800 bones for this when it came out.
although it is a TN panel, it is a VERY nice TN panel. this swift replaced my ebay korean 27" 1440p IPS screen.
IPS is hands down prettier to look at, but GSYNC is where's at.
Once you go Gsync, you cannot go back to regular monitors.
i have 1 dead spot near the center of my screen, i think i might let this go and buy me either acer predator or the IPS version from asus.
Be Quiet! Dark Base Pro 900 orange edition
Asus ROG maximus viii hero
I7 6700k @ 4.5 1.32v
Corsair H115i cooler with 4 x noctua nf14 fans, push/pull.
32gb Gskill trident Z
Evga supernova P2 1000w
Evga gaming acx GTX 1080
500 gb samsung 960 Pro nvme ssd
240gb samsung 840 pro
500gb samsung 850evo x 3
Hitachi X300 6tb HDD
LG blueray burner/player
absolutelly ZERO cable management (i'm too lazy)
#74
nunzmon
Re: GTX 1080 Owners - What monitor are you using? Need recommendation please. 2016/08/01 09:35:58 (permalink)
KickAssCop
After trying the pg34 there was no going back........
post edited by nunzmon - 2016/08/01 12:02:21
#75
  • Ribbons : 52
Re: GTX 1080 Owners - What monitor are you using? Need recommendation please. 2016/08/01 10:13:40 (permalink)
I have a 27inch 4K monitor but would gladly go to 3440 x 1440 if funds were available
#76
