GTX 1070/1080 Hybrid Cooler Hose Location?
BigOne0311
2016/11/23 22:12:22 (permalink)
I currently have the GTX 1070 SC, works great, but am tossing around the idea of mounting the Hybrid Cooler on it. Had one on my 980, and it was really darn quiet. But I have an issue, the front of my card is partially blocked:
And I was hopping if one of the very kind forum members who have a Hybrid Cooler would be willing to pull off one of their side panels and measure the distance from the left hose to the left side end of the card. Like this:
I'm hoping to just run the hoses down and mount my radiator on the bottom where that fan is. I would rather mount a hybrid cooler than a NZXT G10, which I can route the hoses anywhere.
I'm sure someone will ask, but the little power supply on bottom is to power the top ITX computer, I wanted it to have its own PSU, and it must stay there. Its really there to just run virtual machines with, bottom one is my gaming rig.
Any help with this would be greatly appreciated.
2 Replies Related Threads
    Dr.Death
    Re: GTX 1070/1080 Hybrid Cooler Hose Location? 2016/11/24 05:17:33 (permalink)
    seems crazy they designed   the psu to mount in that way to start with ?   sees it was to lay ''flat'' instead of on its side [as most are for the normal]   there may be no issue then . looks like they had room to mount the psu  horizontal  as it should instead of vertically  and blocking the access to the motherboard   ,   and so you got to remove the psu every time  you need to service the card /slots ??    any way glad you pointed this out with that case [crazy]
    sorry I was no help on what you needed but I did find that interesting   on your case design
    DSP1
    Re: GTX 1070/1080 Hybrid Cooler Hose Location? 2016/11/24 05:23:46 (permalink)
    12cm or 4 5/8 inches
