franco1012
I recently got the EVGA GTX 1070 FTW and the RGB feature was a big selling point for me along with many others and before I installed the drivers i noticed that the LED section closest to the 2 PCI-E power inputs was a bit off color wise from the other sections. I thought installing the drivers would fix this but no matter what color it is set to, the LED section is always a bit off from the rest of the card's led sections. The led color difference is really annoying because I have a case with a side window and it's on my desk next to me and I can see it out of the corner of my eye. Is this fixable? If not I am just going to replace it. Update: really getting annoyed with my this, might just replace with an ASUS STRIX Instead.
post edited by franco1012 - 2016/08/11 17:36:35
CoercionShaman
Re: GTX 1070 FTW LED issue
2016/08/11 07:54:53
Others in the forum have reported inconsistencies in the LED brightness and shading. Here is one user. I didn't go through the search any more than this one. http://forums.evga.com/FindPost/2498459
What use is knowledge if there is no understanding?~Stobaeus Intel i5 4670K @ 4.2GHz, Corsiar H100i v2 AIO, 32GB G-Skill Trident X @ 2133 MHz, MSI 1080 Gaming X w/ 2139 MHz boost, ASUS Maximus VI Hero, Samsung 840 EVO 240GB, WD 750GB, CM V1000, Dell U3415W 21:9 @ 75Hz, Windows 10 Pro AE, CM Storm Trooper
franco1012
2016/08/11 08:22:31
CoercionShaman Others in the forum have reported inconsistencies in the LED brightness and shading. Here is one user. I didn't go through the search any more than this one.
What did you search?
CoercionShaman
2016/08/11 08:25:16
2016/08/11 08:32:24
The letters "FTW" change colors slightly earlier than the rest of the lettering on the 1070 FTW I received.
If you would like to use an affiliate code to register a product, feel free use this one: >Click Here< This is not my affiliate code! This is a random users code. This code will change often, and you will never be told who it belongs to! If you would like the possibility of your code being listed above, it must be in your signature block. I will not take requests to use a specific code.
ksgnow2010
2016/08/11 08:34:08
That's normal behavior. It's because the base colors on the transparency strip are different. When the RGB LED is white, you'll see white and blue lettering. As you change the color of the RGB LED, the white and blue filters will cause different colors to show through.
Soplox
2016/08/11 08:44:28
Wheres the option to change colors? I cant find it
franco1012
2016/08/11 09:06:12
Soplox Wheres the option to change colors? I cant find it
Click on the gear on the bottom right of the precision x software. It's under the LED tab
2016/08/11 09:58:22
franco1012
You keep posting, then quoting and posting again. I have removed the double posts. If you want to quote after, you can edit your original post and put the quote in there.
franco1012
2016/08/11 10:06:41
Ok, thanks I'm new to this forum lol
2016/08/11 11:02:18
franco1012 Ok, thanks I'm new to this forum lol
No worries. :-) figured it would be easier to let you know for the future.
mahanddeem
2016/08/12 00:04:13
Sorry to hijack is there any possibly to make light breathing of gpu temp related?
franco1012
2016/08/12 00:11:51
nope, the yellow hue was like that out of the box.
ApexGuy
2016/08/15 15:13:39
Having the same Issue with the lights and uneasy about removing and stripping screws without some tips or clear instructions.... here is a shot of my card. Also this is my first post ever so im sorry if formatting is messed up in advance! I do not want to RMA this at all lol Just hoping for some help from you guys. Thank you!
darmine
2016/08/30 10:54:50
So how do you fix where on card keeps the desired color, but the other resets to white?
cNone
2016/11/13 08:55:45
I am having same issue. I have received my 1070 FTW and installed drivers on the cd and latest XOC there is a LED tab in XOC but it is not active. Now installed latest WHQL drivers from nVidia and issue still persists. Here is my GPUZ and XOC ss:
post edited by cNone - 2016/11/14 00:02:34
cNone
2016/11/14 00:02:56
So my FTW isn't really a FTW inside? EDIT:I have compared other users' sshots with mine and saw my card isn't even EVGA. ****??? I will register my unit as soon as I get home. So I can prove that I own a real EVGA 1070 FTW.
post edited by cNone - 2016/11/14 23:20:27
cNone
2016/11/20 01:46:20
I couldn't enable LED controls whatever I did: Upgraded BIOS to latest, Removed the drivers and cleaned all the settings and then reinstall Removed the XOC and cleared all the settings and then reinstall with no joy :( I think the FTW is my ugliest part in my rig unfortunately. Because every LED is red except the video card. It is unbearably bright white.. Now I don't even look at the thing... Closed all the covers so I won't see this ugly white thing! Should I open a ticket on support?
tonytony11
2016/11/21 06:56:29
cNone I couldn't enable LED controls whatever I did: Upgraded BIOS to latest, Removed the drivers and cleaned all the settings and then reinstall Removed the XOC and cleared all the settings and then reinstall with no joy :( I think the FTW is my ugliest part in my rig unfortunately. Because every LED is red except the video card. It is unbearably bright white.. Now I don't even look at the thing... Closed all the covers so I won't see this ugly white thing! Should I open a ticket on support?
Have you found any solution maybe?
Mertsi
2016/11/21 07:22:43
Why didn't you open a support ticket straight away? this thread is months old now and the issue could have been resolved 10 times already if you contacted evga support. (i don't understand who chooses his pc parts by leds but then again i never understood leds)
2016/11/21 16:29:52
The solution is to reflash the original vbios.
cNone
2016/11/21 22:35:04
Mertsi
Support ticket opened and the answer is: "I didn't read your ticket realy, just offering a noobie solution" Follow up ticket opened and I am waiting fr the REAL answer. Sajin
I don't want to be mean and if my language looks like it, sorry for that, because English is not my native language. Answer is straight NO. Because I am using the original VBIOS at first and hoping that would be solution, flashed the latest BIOS. That didn't worked out. It is very frustrating issue as I bought the FTW for this very reason amongst others: Customize LED color! But if you are referring by "original VBIOS" is flashing a NVIDIA reference BIOS I can't really say I would prefer that way. Waiting the support ticket to be solved. Thanks to all who tried to help on this issue.
post edited by cNone - 2016/11/21 22:39:08
