Just curious, with 900-series cards ASIC quality was the determinant factor for maximum Boost 2.0 clock speeds out of the box for the exact same model of GPU that had the exact same listed base/boost clock speeds. ASIC quality could cause the maximum Boost 2.0 speeds to vary by over 100MHz for the exact same models.
I have seen a few posters saying the out-of-the-box Boost 3.0 maximum speed for the GTX 1080 FE is 1911MHz. Is this what you see?
Currently GPU-Z doesn't display the ASIC quality of 1000-series cards, so this will be a good way to know if ASIC still plays a role in maximum boost clock speeds.
Also, it would be good to list the maximum voltage observed (which should occur when the clock speed is at its highest).
Thanks!
