Re:Which mobo chipset block(s)?
2010/05/29 22:11:34
You know I got some of their 1/2" ID 3/4" OD and I didn't feel safe using them. I put int he tubes and tightened them down and was able to pull the tube right out the compression fitting without any issues. I triple checked their size and my tube size...
Outside of that looking very good, its a shame your case doesn't have room for the Rez. Maybe you can customize your own holder for it?
