FTW/Classified LED color
808sting
2016/08/05 14:17:10 (permalink)
Trying to see which card is off.  The top card is slightly dimmer in default white or red.  It's more sky blue.  Bottom card looks like a tinge on the purple side, but closer to white.  I darkened the shot to highlight the color difference, but in person, it's much brighter and color differences is greater using default white.  The longer I look at it, the more I irritated I get.
Which card matches the normal FTW "white" color?  Will RMA one of them.
i7 5960X @ 4.75 Ghz, Asus X99 Deluxe II MB, 64GB G.Skill Trident Z DDR4-3200 at 3000C13
EVGA 1080GTX FTW SLI
EKWB Predator 360 Push/Pull
Corsair 900D Case w/custom fan setup
Samsung 950 Pro SSD 512GB, Samsung 850 Pro SSD 1GB, WB Black 6TB
Asus & LG BD-RE
Corsair AX1200i PS
Eizo FS2735 27" (main), 2x Asus PG279 27" (surround)  120Hz ULMB
1 Reply Related Threads
    chaosminionx
    Re: FTW/Classified LED color 2016/08/05 15:52:51 (permalink)
    Honestly luck of the draw, the RGB stuff is not calibrated from factory very well. You will have different colors and hues, it takes a bit of work to get them looking the same, hopefully EVGA releases something to reset the color back to the out of box colors.
    I already RMAd one card because of it, and honestly the new card has the same issue, going to chalk it up to the LEd controller not being a very robust solution, and the lack of a dedicated white LED causes a severe lack in color spectrums, especially in dealing with a white color look.
    In my own personal case, I almost think the brighter card is the outlier in the bunch, the one card I RMAd had about the same brightness as the new cars, so thinking my one card is just a lot more bright.
    post edited by chaosminionx - 2016/08/05 15:56:39
