PalleGTX
Hi eveyone, first post so be nice.
I bought a 1070 card a few months ago and has worked great untill yesterday. I was playing wow legion when my screen went all black with the sound from The game still playing in The background. Also, The fans maxed out and The only option was to do a hard reset. When i got back into desktop and started The game again, i was getting low fps and performance in general. Any ideas in what happened? All drivers are The latest
Temps are fine, 40c at 50% load on gpu and 25 on cpu
Specs: I7 6700k no oc 1070 sc stock 8gb corsair ram Ssd as primary Hdd as storage
CoercionShaman
Re: Evga 1070 sc blackscreens with fans at max
2016/10/18 07:34:59
Which version of Windows are you on? Before going any further, go through this thread: http://forums.evga.com/FindPost/2504606 Also verify that all of your power connectors are in firmly, especially the one to the video card.
What use is knowledge if there is no understanding?~Stobaeus Intel i5 4670K @ 4.2GHz, Corsiar H100i v2 AIO, 32GB G-Skill Trident X @ 2133 MHz, MSI 1080 Gaming X w/ 2139 MHz boost, ASUS Maximus VI Hero, Samsung 840 EVO 240GB, WD 750GB, CM V1000, Dell U3415W 21:9 @ 75Hz, Windows 10 Pro AE, CM Storm Trooper
PalleGTX
2016/10/18 07:40:10
I got windows 10 I've tried most of them if not all and nothing :/ Also tried re-seating The card and change/try some of The other cables. And since it only has happened once i fear that i will take some time to rule out most things to get a solution
post edited by PalleGTX - 2016/10/18 08:05:35
CoercionShaman
2016/10/18 08:16:48
But you are still getting poor frame rates? And is that only in WoW that you have taken a performance hit?
PalleGTX
2016/10/18 08:33:15
Still getting poor fps. Played cs go and wow. Both with same settings as i've been playing on before. Tried lowering the settings and then setting them back manually to the original settings with no luck. Cs go wasnt even playable, well under 30 fps, same with wow but not as bad
PalleGTX
2016/10/18 10:50:25
I've been running "Heaven Benchmark" now for about an hour with full load on the card with no crashes or temps going higher than 60c. Been stressing the cpu aswell to if that caused it but it also runs about 65-70c under full load. Im clueless to what is causing it. One thing i noticed tho is that the benchmark displayed the 1070 as a 4gb card, bug maybe ? And in wow the card is at 50-60% load only , same with cs go
arestavo
- Ribbons : 8
2016/10/18 11:01:33
Heaven and Valley don't detect more than 4GB of VRAM, so what you're seeing there is normal.
EVGA affiliate code: 9ZWDWFNW6A (Don't forget to upload your invoice or no credit is given!) FOLD ON
2016/10/18 12:53:59
PalleGTX
2016/10/19 01:44:43
The psu is a coolermaster g750m, maybe 1 year old
post edited by PalleGTX - 2016/10/19 04:22:38
2016/10/19 09:25:26
If you run unigine heaven 4.0 for 15 minutes at max settings does it cause the same issue?
PalleGTX
2016/10/19 09:29:24
No, it doesnt. Ran it for about an hour on loop yesterday
2016/10/19 09:33:41
Which graphics driver are you currently running? Have you tried any older graphics drivers to see if it helps fix the problem in wow legion?
PalleGTX
2016/10/19 09:35:59
i'm using 373.06, did try the version before the current and with the same issues
2016/10/19 09:37:29
PalleGTX i'm using 373.06, did try the version before the current and with the same issues
Do #4 listed here. Let me know if it helps.
PalleGTX
2016/10/19 09:40:05
PalleGTX
2016/10/19 22:14:44
I've been talking to support for a few days now and they asked me to do firestrike so we could see if there really was a performance issue aswell. Final results were at 7800 points, with a 6700k and the 1070.. Support told med that this was well below of what it should be and told me to RMA it. So this is what im doing, will update with the new card
2016/10/19 22:23:14
PalleGTX I've been talking to support for a few days now and they asked me to do firestrike so we could see if there really was a performance issue aswell. Final results were at 7800 points, with a 6700k and the 1070.. Support told med that this was well below of what it should be and told me to RMA it. So this is what im doing, will update with the new card
Do you have a link to your score?
PalleGTX
2016/10/19 22:44:24
I cant link for some reason?
post edited by PalleGTX - 2016/10/19 22:48:49
2016/10/19 22:48:36
PalleGTX I cant link for some reason?
Not enough posts yet.
My Affiliate Code: 8WEQVXMCJL
PalleGTX
2016/10/19 22:49:41
Is there another way to link it ?
2016/10/19 22:50:06
PalleGTX Is there another way to link it ?
Put spaces in the link.
2016/10/19 22:57:21
^ This
PalleGTX
2016/10/19 23:01:16
^ This
w w w . 3dmark. com / 3dm / 15531697
Luta Wicasa
2016/10/19 23:12:05
??? Time measuring inaccurate: This message indicates funny business with the system clock during benchmark run. In most cases, this means that, no, you cannot cheat in 3DMark by adjusting Windows timers during the benchmark run or otherwise tampering with the measurements done by the benchmark. If this message persists and you have not done anything out of the ordinary, it may indicate a hardware issue with the real time clock in your system or the presence of a background program that somehow twists the time-space continuum of your operating system in such a way that this anti-cheat detection is tripped.
2016/10/19 23:15:14
PalleGTX
^ This
Wow, yeah, your clocks are way off. Even your cpu clocks are off. Does your cpu clock up to its rated speed when gaming?
PalleGTX
2016/10/19 23:17:58
Damn.. its a new build. Havent touched anything on the cpu. I was just measuring the temps and load of The cpu and gpu.
Luta Wicasa
2016/10/19 23:22:53
For s&g's.....run cpu-z see what it says about cpu clocks.
PalleGTX
2016/10/19 23:25:37
The asus software said 800 MHz at idle yesterday. Im not home so i cant runt cpu z right now
2016/10/19 23:28:43
PalleGTX The asus software said 800 MHz at idle yesterday. Im not home so i cant runt cpu z right now
Asus ai suite?
Luta Wicasa
2016/10/19 23:29:33
What confuses me is the stock core clock 4000 MHz but max turbo 1202 MHz......
