Hot!Evga 1070 sc blackscreens with fans at max
PalleGTX
Re: Evga 1070 sc blackscreens with fans at max 2016/10/19 23:29:33 (permalink)
PalleGTX
The asus software said 800 MHz at idle yesterday.
Im not home so i cant runt cpu z right now
Asus ai suite?
Yup, correct
#31
PalleGTX
Re: Evga 1070 sc blackscreens with fans at max 2016/10/19 23:31:18 (permalink)
PalleGTX
Asus ai suite?
Yup ,correct
#32
  • Ribbons : 122
Re: Evga 1070 sc blackscreens with fans at max 2016/10/19 23:31:44 (permalink)
PalleGTX
PalleGTX
Asus ai suite?
Yup, correct
Yeah, uninstall that asap. Use CPU-Z/Core Temp to watch your cpu clocks while putting a load on the cpu.
#33
PalleGTX
Re: Evga 1070 sc blackscreens with fans at max 2016/10/19 23:32:41 (permalink)
Luta Wicasa
What confuses me is the stock core clock 4000 MHz but max turbo 1202 MHz......
yeah i really dont know how that can be
#34
  • Ribbons : 122
Re: Evga 1070 sc blackscreens with fans at max 2016/10/19 23:34:06 (permalink)
PalleGTX
Luta Wicasa
It could be 3dmark reading your clocks wrong. I've seen that happen before. Checking your cpu with CPU-Z/Core Temp with a load on the cpu is best. You can use prime95 to put a load on the cpu.
#35
PalleGTX
Re: Evga 1070 sc blackscreens with fans at max 2016/10/19 23:37:31 (permalink)
PalleGTX
Luta Wicasa
I will try that asap when i get home.
If the clocks really are off on the cpu aswell then that will answer the poor performance question. But not the blackscreen tho
#36
PalleGTX
Re: Evga 1070 sc blackscreens with fans at max 2016/10/20 09:01:17 (permalink)
The clocks on the cpu are correct what i can see, full load at 4218MHz.
#37
  • Ribbons : 122
Re: Evga 1070 sc blackscreens with fans at max 2016/10/20 10:28:36 (permalink)
PalleGTX
#38
