AnsweredEVGA nForce 790i Ultra SLI Motherboard Battery Replacement Model
HerbalNekoTea
2016/10/07 11:18:20 (permalink)
Hi, i found this motherboard in the trash, it has no battery, i would like to know the battery type for the cmos, i could not find anything in the manual nor google. Thank you.
bob16314
  • Ribbons : 204
Re: EVGA nForce 790i Ultra SLI Motherboard Battery Replacement Model 2016/10/07 12:02:45 (permalink) ☼ Best Answerby HerbalNekoTea 2016/10/09 14:22:06
Welcome to the forums..CR2032
* Cooler Master NV-334 * ASUS P8Z77-V LE PLUS * Intel i7-2600K @ 5.0GHz * Corsair H80 * Seasonic M12II 750W * 4x4GB 2133MHz Patriot Viper Xtreme * EVGA GTX 760 SC * 2 x WD 500GB Caviar Black RAID 0 * Toshiba DT01ACA 500GB * Dual-boot Win7 Home Premium 64-bit/Win10 Home 64-bit *
"If it ain't broke, fix it untill it is"
  • Ribbons : 92
Re: EVGA nForce 790i Ultra SLI Motherboard Battery Replacement Model 2016/10/07 20:58:50 (permalink)
bob16314
 +1
My Affiliate Code: 8WEQVXMCJL
HerbalNekoTea
Re: EVGA nForce 790i Ultra SLI Motherboard Battery Replacement Model 2016/10/09 14:21:42 (permalink)
Thank you, i was not sure since it looked smaller than my memory.
