Huntyka
Hello everyone! It's a strange problem, but it occures everytime, when i start Far Cry 4. Video: /watch?v=DAOSGHe7xns (just put youtube before it) (It starts at 0:11) So in 10/2 times, the pc restarts, in the remaining 8 times, when the game reaches it's main menu, the creeking voice stops. I finished far cry 4, played over 20 hours with it, without a problem. My rig: I5 4690k z97 Gigabyte UD3H R9 280x 8 gb Hyperx Fury 1600hz cl9 Corsair h105 cpu cooler 1 hdd/1ssd 5 fans in total. It looks like when a powerful task comes up, it makes that noise. What should i do now?
post edited by Huntyka - 2014/11/28 02:26:18
Vlada011
- Ribbons : 11
Re: EVGA SuperNOVA NEX 750B problem, please help me!
2014/11/28 03:10:33
That's whine noise, typical for some PSU. You should leave week or two maybe gone if not you can contact EVGA and ask advice or RMA PSU. It's really nasty on this video.
Huntyka
2014/11/28 10:17:47
Vlada011 That's whine noise, typical for some PSU. You should leave week or two maybe gone if not you can contact EVGA and ask advice or RMA PSU. It's really nasty on this video.
Thanks, this is not new, so i should speak with somebody from EVGA. Yea, really nasty:(
Vlada011
- Ribbons : 11
2014/11/28 10:46:48
What is exactly model of your PSU, EVGA 750 B1? EVGA 750 B2 is completely different PSU based on Super Flower Golden Green platform. It's same Bronze standard but most famous power supply tester/site confirm EVGA 750 B2 can pass as Silver PSU. It's only 10$ more and score is 9.5. Usually such noise show up immediately or never, but you say PSU it's not new, and that nasty sound show up soon. Example when I buy something and when picture is same only other part number and price difference no matter 5$ or 30$ I always compare and try to search why price is different, why different serial numbers and etc... If no answer on net than I try to ask manufacturer.
post edited by Vlada011 - 2014/11/28 10:56:09
Huntyka
2014/11/28 11:46:22
Vlada011 What is exactly model of your PSU, EVGA 750 B1? EVGA 750 B2 is completely different PSU based on Super Flower Golden Green platform. It's same Bronze standard but most famous power supply tester/site confirm EVGA 750 B2 can pass as Silver PSU. It's only 10$ more and score is 9.5. Usually such noise show up immediately or never, but you say PSU it's not new, and that nasty sound show up soon. Example when I buy something and when picture is same only other part number and price difference no matter 5$ or 30$ I always compare and try to search why price is different, why different serial numbers and etc... If no answer on net than I try to ask manufacturer.
I think my psu is B1, i got it in june, and worked perfectly, and still works perfectly if i play. It is really strange, that only Far Cry 4 can cause this noise. I think i will contact support, but before i will run some VGA+processor tests, to add more W for the psu. I forgot to tell, that nothing is overclocked in my system. But maybe i will overclock them for the test. Is that a bad idea?
Vlada011
- Ribbons : 11
2014/11/28 11:57:17
It's not bad idea if you have one graphic card and if power consumption is not over 700W. Weird... Only in Far Cry 4 that happen?!?! If that's only application when you hear noise than not worth to RMA because of that.
Huntyka
2014/11/28 12:00:53
Vlada011 It's not bad idea if you have one graphic card and if power consumption is not over 700W. Weird... Only in Far Cry 4 that happen?!?! If that's only application when you hear noise than not worth to RMA because of that.
Yes, only at FC4, i will write after i run some tests. Thanks for help!
