Helpful ReplyEVGA Power Boost!
Page: << < ..678910.. > >> Showing page 8 of 14
MSim
  • Ribbons : 28
Re:EVGA Power Boost! 2010/12/23 16:22:28 (permalink)
BioHazardSperm
Falcon_CMH
How old is the ATX spec. That is no excuse. EVGA sells the MB and GPUs. And employed Shamino who experienced the problem a long time ago. What is obvious is EVGA is legally responsible even to the most simple minds.
just wondering where is this information (link please)about Shamino saying this at the launch of these motherboards? Or did he say it after the 400/500 series cards were released?
Other users have posted the link showing where Shamino talked about it on another message board. I think the date of the post showed June of 2009.
BioHazardSperm
EGC Admin
  • Ribbons : 25
Re:EVGA Power Boost! 2010/12/23 17:20:29 (permalink)
so June 2009 the 400 series wasnt even out and with 200 series cards this was a issue?Sorry never seen/heard the thread or links.
I am  >>NOT< <   a  EVGA Forums Moderator or a EVGA.com  Employee.
I am only a  "Game Server Admin"
My posts and are my own and not EVGA's.
Steam  Heatware   EVGAWeb_ShaneD: BHS knows our terms better than some of our support agents
EVGAWeb_ShaneD  we don't care, we do what we want! (out of context but funny )
Sum1uNo83
  • Ribbons : 12
Re:EVGA Power Boost! 2010/12/23 19:28:18 (permalink)
IMO EVGA may have known about this potential issue, but was not an issue until now. sure shamino mentioned it and that it could happen, but it never did. Only after the 400/500 series launch was this an issue. maybe with the 200 series at extreme clocks and power consumption that is where he found it to be a potential issue. now 400/500 series with higher clocks and higher power consumption and now the issue happens more frequent because we dont need LN2 ect to see the risk, just air and water to find it now. So back then no it was not really an issue IMO, now it is. Well OK so EVGA is responsible, so they took action and fixed the potential issue with the powerboost. Done deal, they had a problem occur not many could predict and they made a solution. Sure many would like the molex to be on the board as it is now on newer boards, but back then it was not needed nor found a reason to be added to the motherboards. so for the older motherboards without it there is this powerboost to fix it.
IMO evga took action and fixed newer motherboards with the molex as many others did and produced a powerboost to fix older motherboards.I understand that wont sit well with everyone and for some it will. ASUS replaced the older boards without a molex with a new one with a molex, thats really cool. well EVGA did not, but they still made a fix regardless. weather you call it a cheap fix, hack ect it still does the same thing and works as such. EVGA has dealt with it there own way as other did there way. you can knock them for it or praise them your call, but they did nothing wrong imo, they still fixed the issue regardless if you like how they did it or not.
I stick by EVGA and like there products, sure there have been times were i had issue, but they were always resolved. CS imo is great and I honestly can't say anything bad about them. I received the powerboost in the first shipment, tested it and found it to work quiet well. Some say you need more than one or it will not work right, but i really dont see the difference from the powerboost vs onboard molex. electricity follows the least amount of travel to get to the source. so if the powerboost is installed at the top of the gpu slots lets say, it travels down to the rest, maybe losing power. The molex is no different, it will still trickle down into the slots as the powerboost would. IMO the only thing that would make sense to me would be if the traces for the molex on the motherboard that are capable, had the same length traces to each slot then i could believe you would not lose any power as you would if it ran down through the slots as normal or with the powerboost. just my thoughts
To sum it up here, i believe EVGA took action made a fix for older motherboards, produced newer motherboards to combat this threat. no matter how you look at it, they did something about it weather were satisfied or not is another story and i would assume people who are not will most likely go elsewhere those who are fine with it will stay EVGA IMO. either way I wish no one to have to go through an issue like this or have this 24-pin melt happen to them and i am glad to see every manufacturer and company to address this is some form or fashion.
Squall_Rinoa86
Re:EVGA Power Boost! 2010/12/23 19:30:14 (permalink)
So where can we buy this little thing? How much or how can i get one?
PSU: EVGA SuperNOVA 1300 G2
My Affiliate Code: AN1FW0VMG6
Nereus
  • Ribbons : 25
Re:EVGA Power Boost! 2010/12/23 21:23:53 (permalink)
Squall_Rinoa86
Right here. Already sold out - more coming in January.
fusionssl
Re:EVGA Power Boost! 2010/12/23 21:36:15 (permalink)
actually the issue first raised its head when running cf ati cards like the 3000 and 4000 cards
evga where the first to add a molex plug for pcie boost with the 762
sorry falcon asus just followed the others
rig 1
X79 DARK 3940k (4.4oc), corsair Platinum 2133mhz,Evga GTX580 2way sli, mountain mod assention,
rig 2
EVGA X58 759 CLASSIFIED  I7 930/ 4.5GHZ
Corsair Domminator 2153MHZ   10,10,10,24/1T
Evga GTX 460
okenraven
Re:EVGA Power Boost! 2010/12/24 07:22:37 (permalink)
Awsome, will definetly get one as my system is suffering from instabilities due to lack of power!
eppopipe
  • Ribbons : 7
Re:EVGA Power Boost! 2010/12/24 08:34:43 (permalink)
Just thought some of you would like to know. Being that I built my buddies computer, today we tried to RMA the board due to the "issue" at hand here. (Its a ASUS board!)
No go, no chance. Ive been on the phone with asus for a couple hours now with no sight of them replacing this board. Ive been told to call back for a RMA once and if anything does happen.
So there, in my own personal experience, I will not recommend ASUS, and commend EVGA for their efforts.
Sum1uNo83
  • Ribbons : 12
Re:EVGA Power Boost! 2010/12/24 10:44:09 (permalink)
eppopipe
interesting
Nereus
  • Ribbons : 25
Re:EVGA Power Boost! 2010/12/24 11:45:24 (permalink)
Falcon_CMH
Oh and also other Mfgs with the problem like ASUS actually fix the problem And RMA the defective MB for a brand new MB with the molex added to it properly
eppopipe
LOL
Naieve
Re:EVGA Power Boost! 2010/12/24 13:00:29 (permalink)
eppopipe
This is why I will never buy another Asus product.  I once sent in an m2n32 sli deluxe, they had it for almost two months.  I finally got it back, and happily hooked it up, and it was still dead.   No note, nothing.  Was under warranty and should have been covered.  So I called them to ask what was up, and after 45 minutes on the phone the guy I was speaking with asked me to hold and then hung up on me a few minutes later.  I tried to file another RMA and wasn't even denied, they just didn't respond at all.
Never again.   I learned my lesson.  We will see how my Gigabyte RMA goes, but I am really wishing I had bought the EVGA equivalent online instead of my impulse buy at MicroCenter, or had known of this problem and foregone the 3rd 480 and gotten a 762+ classified with the native power mod.
That's what I get for trying to save a couple bucks or waiting for availability.
Mountain Mods Ascension
Rampage V Extreme
5930k @4.6 1.325v EK RVE Monoblock
G.Skill 3000mhz C14
EVGA Titan X Tri-SLI EK Blocks and Plates
Samsung SM951 M.2 SSD + MX-100 1TB Raid 0
2x Antec HCP-1000 Platinum PSU's
3x HP ZR-30W
wmarples
Re:EVGA Power Boost! 2010/12/24 14:22:21 (permalink)
Glad to see these are on the way.  However, $20 for what amounts to a $5 part to fix a problem with a $400+ motherboard has definetly left a bad taste in my mouth.
Corsair 750D | Windows 7 | Intel I7-5930K on Corsair H110 | Gigabyte GA-X99-Gaming 5 | SLI EVGA 970 FTW | Corsair 16GB DDR4 |
Sum1uNo83
  • Ribbons : 12
Re:EVGA Power Boost! 2010/12/24 17:22:19 (permalink)
Kanti
I'm a little late to the party and have been skimming through this thread.  What exactly is the "problem" this "booster" fixes?  PCI slots is hot real estate in my case and having to sacrifice one is painful.
you can sacrifice a pci-e x1 slot not the x16/x8
eppopipe
  • Ribbons : 7
Re:EVGA Power Boost! 2010/12/24 19:53:32 (permalink)
@Falcoln, sounds like they only deal with you if your either A-influential in the community (therefore meaning you could lose them business) or B- (more likely) Your running more then 2-3 way SLI.
You dont know me nor how I treat situations, so please dont tell me its how I deal with them.
Oh and to your update- This system in question is running 3-way SLI 480's (All asus products btw)
@everybody else, The problem is not the fault of ASUS nor EVGA. The blame should be solely on NVIDIA/ATI. EVGA stepped up to the plate to fix the issue and have it avaliable for users with boards that dont use a molex (even boards from other manufactures). I commend them for that, and that alone.
Bruno747
  • Location: Looking on google to see what Nvidia is going to o
Re:EVGA Power Boost! 2010/12/24 22:23:04 (permalink)
You know I am sitting here just wondering what the actual ATX spec says. I think this whole issue ignoring manufacturer idependent designs is this.
ATX was introduced in what 1993 or before. Does the spec state just how much power is supposed to be available through the 24pin connector for slots in addition to board functions I mean really, back then was anyone that was working on these specs thinking Hmmm we better make this compliant incase some point in the future, a manufacturer makes a bord with 7 pci-e x16 slots that can draw 75w each. I kinda doubt it.
Specs need to be redrawn every so often because individual specs that are created separatly converge, and cause issues tying those seperate specs together, and trying to make everything work.
IE Jdec standard is 75w available power from a pci-e x16 2.0 slot.
BUT there is no standard as to how many slots can be on a board without having to have a dedicated line power like the power boost.
When the ATX spec and the Jdec Spec were tied together with boards that have 2,3,4,7 pci-e slots the hole that was left was the power distribution to the slots. (this is somewhat of an oversight on the part of board manufacturers.
Nvidia made the cards draw < or = to 75w out of the slot.(Supposedly) @Stock Settings
Evga made a board built to ATX specs and put 7 pci-e slots on it that meet jdec specs individually But the ability to power more than one or two slots (at the same time) appears to be an afterthought. IE the power mod, or the molex connector on newer boards.
Perhaps it is time for atx power specs to be redrawn to have a 28 pin, or a molex, or a new type of plug that gives dedicated power to the PCI-e bus with a max of 75w each, with a max of 4 slots. This covers both issues, board manufacturers can make boards compliant by this, psu manufacturers can make psu's compliant to this, and then the whole extra molex plug and melting 24 pin mess is gone for future boards. call it atx 2.0 lol.
The whole issue boils down to several things. Some what out of date specs due to technological advances, standards being created separetly, small oversights that lead to big problems by manugacturers, and finally users that run items outside of stock specifications. Tie them all together, and you are bound to find a weak link...in this case power distrobution to the pci-e bus.
Come to think of it, has anyone with a burnt plug been running everything at advertised stock settings.
PuffY
Re:EVGA Power Boost! 2010/12/25 01:17:00 (permalink)
only plate evga stepped up too is the dinner plate! YuM
|mm cyo|4960x|asus rivbe|2x evga gtx 780ti sc|gskill F3-2800C12Q-32GTXDG|evga 1.5k|samsung 840 pro|
|ek/bitspower watercooling|
(:I smoke video cards to get high:)
Kanti
Re:EVGA Power Boost! 2010/12/25 03:17:23 (permalink)
So what exactly is the deal, video cards frying mobos at random or people OCing so much that he VGA card eats too much power and blows a slot?  is this booster needed if you aren't bumping electrons past stock video settings or what? could it be possible to make some crap like this with a back jack similar to Christmas lights so you don't lose a slot?  If so PM me and lets get rich selling Power Boost DX.
Muh 'filiate code: 387JKEF57G
shdbcamping
Re:EVGA Power Boost! 2010/12/27 13:32:59 (permalink)
Teletuby
forget it I'm done with the thread people are simply looking for a place to complain they didn't get a 20 dollar part for there multi-thousand dollar rigs. Instead of blaming nvidia who actually makes the cards draw to much power.
It's like trying to sue the power company because you plugged 30 things into one electrical socket and burned down your house.
Big exception, the power companies were not helping you plug all that stuff in. Nor was the Power Company showing/giving the means to overvolt "all that stuff".
shdbcamping
Re:EVGA Power Boost! 2010/12/27 13:39:09 (permalink)
BioHazardSperm
Falcon_CMH
Why would it matter whether Shamino revealed this Before, During or After the launch? EVGA is/was aware of the issue at whatever time Shamino posted. EVGA chose to continue to BOTH design the flaw into other MOBO's as well as continue to sell the current MODELS. Continued to Market as "Classified" as well.
shdbcamping
Re:EVGA Power Boost! 2010/12/27 13:47:57 (permalink)
CDdude55
This is probably on of the most waste of time accessory for the price.
IMO, you are correct. Unless one is Tri-SLI'ing or folding  (3)480's or (3) 580's (possibly include the 470/570 for the paranoid) or folding 3 GTX295's. If the problem was to happen with less than that scenario, it would be a Manufacturing problem with that particular board.
Sean
shdbcamping
Re:EVGA Power Boost! 2010/12/27 13:56:50 (permalink)
Naieve
eppopipe
I don't know why this ASUS/Gigabyte board thing bothers you?? REALLY, you probably saved enough NOT buying the EVGA equivalent to get 3 of these Power thingies from EVGA. lololololololol. For those (MOST) that will never need it.... they simply saved money
Sean
shdbcamping
Re:EVGA Power Boost! 2010/12/27 13:59:06 (permalink)
wmarples
Glad you are able to get one. But I agree with the 'Bad Taste" part.
shdbcamping
Re:EVGA Power Boost! 2010/12/27 14:05:15 (permalink)
PuffY
+ a million. LOLOLOLOL
I bet ASUS and others are 'kicking' themselves at not being able to get in on this "WASTED" money Marketing gimmick for most Board owners.
shdbcamping
Re:EVGA Power Boost! 2010/12/27 16:30:46 (permalink)
Kanti
It is not a "wildfire" issue that anyone knows of to my understanding. If one Loads the PCIe physical X16 slots on three or 4 High end EVGA MOBO series that lack a supplemental PCIe Bus connector too much, the PSU to MOBO 24 pin power plug can melt and depending on the PSU could even possibly cause an electrical fire. That's an "In A Nutshell".
If you do not run 470 or higher power draw Graphics cards in Tri-SLI or in 3 card Folding, you do not need this device.
If EVGA would set a list of 'electrical conditions' where electrically this would become a problem, the issue would be closed, IMO. But they are not as of yet as far as I know.
Most users will be Throwing $20 away because of a lot of paranoia and EVGA (like any other Corp) is not going to slow it down even if one does not really require one.
There are a lot of posts about the device "smoothing" the power. They are rediculous electrical claims. Unless the power is coming from a different PSU AND is conditioned by the device.
For the last question, Just make one and let a bunch of other people claim it works. That way you are not lying as a manufacturer.
Sean
rcranfield
  • Ribbons : 25
Re:EVGA Power Boost! 2010/12/27 16:50:14 (permalink)
Everyone get back on topic. Personal attacks will not be tolerated.
shdbcamping
Re:EVGA Power Boost! 2010/12/27 18:00:59 (permalink)
Let me try this another way:
1) It is not the voltage draw that will melt the PSU to MOBO 24 pin plug. Are we all agreed on that?
2) Current WILL melt the 24 pin plug. Are we still agreeing?
3) The PSU attempts to provide a described voltage to a given electrical circuit. Are we still together on this one?
4) Given Ohm's Law (V=I*R). Hope we're all OK with that.
5) As the Number of applied cards increases the R of the PCIe Bus circuit changes. Still there?
6) As Power draw increases in a circuit, the resistance drops. Up heat down resistance. Unfortunately an electrical fact. Power is a different class, if you do not understand it, get some electrical courses under your belt.
7) The PSU's job is to keep voltage constant. Still agreeing?
8) Current on the circuit therefore must be adjusted to maintain the desired Voltage as it is the variable to getting the desired Volts. Still there?
9) Going back to Ohm's law, Current will go up as the PCIe bus demand (R) is increased decreased. Still with me?
10) You make the plug Amp problem go away by providing 'another' input circuit for the Voltage therefore lowering the current draw at the 24 pin plug. Problems yet?
11) If the PSU cannot maintain a voltage, the Amps are decreased as well for a given resistance (Power draw). this will be the point where simple GPU/system instabilitywill occur. So you see... the voltage on the PCIe bus is a function of the PSU. If one cannot keep the voltage, one should get another PSU with more amps on the 12V rail that will be feeding the BUS OR a different MOBO that does not have anything other than the PCIe bus on the circuit.
12) If the PSU is strong enough and fast enough to keep adjusting amps on a given Rail, the Voltage measured will remain constant. for the circuit. This is the problem with the 24 pin plug burning. The AMPS passing through the 24 pin plug outgrew the circuit ability to handle the heat, which is a byproduct of electrical work. This is why they added another 12V input to the circuit. It will do absolutely nothing for the system other than decrease the current through the 24 pin Pllug and thus avoid the melting problem.
In closing, EVGA should be able to look at each of the "affected" MOBO's and determine at what Wattage the PCIe bus should be supplemented. I understand that the GPU owner overclocking will affect these wattages. Burn up a "classy" and then drop the measured (to induce failure) wattage recommendation 25% or some other EVGA choice and then post it. That way the consumer won't be wasting their money on a lot of paranoia.
IMO, that's what a "Classy" vendor would do for it's customers.
As always YMMV.
Sean
Edit in bold above. oops
post edited by shdbcamping - 2010/12/27 23:32:30
Sum1uNo83
  • Ribbons : 12
Re:EVGA Power Boost! 2010/12/27 19:45:51 (permalink)
shdbcamping
9) Going back to Ohm's law, Current will go up as the PCIe bus demand (R) is increased. Still with me?
As always YMMV.
Sean
so are you saying its the psu's issues causing these problems or did i miss something?
shdbcamping
Re:EVGA Power Boost! 2010/12/27 21:52:05 (permalink)
jrmitchell1983
No, that's not what I'm saying... so given your other choice... Yes, you missed something.
Unfortunately, I'm at a loss on how to make the issue any less technical. For that I do apoligize. Some explanations require a rudimentary understanding in the area. That I cannot give to anyone.
post edited by shdbcamping - 2010/12/27 22:06:40
shdbcamping
Re:EVGA Power Boost! 2010/12/27 23:20:25 (permalink)
Kanti
This is an issue that affects ONLY the E758,E759 and E760 boards AFAIK with the possible inclusion of the E761. The E761 is because I seem to recall an offering without Supplemental power for the PCIe bus. CMIIW and then shoot me.
It is as well a very isolated problem with graphics cards, but if you are loading the Bus down with anything this could apply. See my explanation just up a bit.
Sean
  • Ribbons : 52
Re:EVGA Power Boost! 2010/12/27 23:22:32 (permalink)
The mods are working evry hard to try and keep this thread clean. We are trying our best to continue to allow this thread to keep on course but if repeated TOS violations occur then we will ask EVGA management for permission to lock it down.
