Helpful ReplyEVGA Power Boost!
Page: << < ..678910.. > >> Showing page 6 of 14
jjkz24
Re:EVGA Power Boost! 2010/12/22 16:38:54 (permalink)
waveskimmer9431
      I will support my clients AND NOT charge them for the mods; I'll absorb the cost.
With your way of thinking, ANYTHING that happens to that PC for your client, they can in return, blame you for the design, manufacture flaw, and bash your product on the interwebz.  How ironic.
-Jason
2010 Carlisle P&S 1st Place Acura Class Winner
2009 Carlisle P&S 2nd Place Acura Class Winner
2007 Tuner-Evolution 1st Place Acura Class Winner
438whp/303wtq @ 19psi
https://www.facebook.com/jjkz24
Modboxx
Re:EVGA Power Boost! 2010/12/22 16:45:08 (permalink)
I just ordered a new EVGA X58 Classified3 PART NUMBER: 141-GT-E770-A1 and three 570s for sli is this little dongle thing needed for my board?
Naieve
Re:EVGA Power Boost! 2010/12/22 16:45:15 (permalink)
jjkz24
waveskimmer9431
I agree, this wasn't a design flaw by the mobo manufacturers, this is what happens when gpu designers build gpu's that are energy hogs and then allow you to run them in SLI/TRI without letting you know that the 24 pin might not be able to handle the load.
If anything EVGA should be getting massive props for doing this.  They are the only mobo manufacturer actually acknowledging the problem and instituting a solution.
@modboxx  pretty sure the 770 has the native power mod fix.
Mountain Mods Ascension
Rampage V Extreme
5930k @4.6 1.325v EK RVE Monoblock
G.Skill 3000mhz C14
EVGA Titan X Tri-SLI EK Blocks and Plates
Samsung SM951 M.2 SSD + MX-100 1TB Raid 0
2x Antec HCP-1000 Platinum PSU's
3x HP ZR-30W
CDdude55
Re:EVGA Power Boost! 2010/12/22 16:45:19 (permalink)
i seriously doubt this can make any difference at all. vga cards are not unstable because of power delivery issues from the socket.
and $20 .. cmon ... $3 maybe and they'd still make a ton of profit
if your (evga?) motherboard doesnt work right without it, then you bought a POS motherboard that is not engineered properly[QUOTE\]
Core i7 920 @3.5Ghz
EVGA X58 SLI (E758)
6GB Patriot Vipers 1333Mhz
EVGA Geforce GTX 470
WD Velociraptor 300GB
Corsair TX850w
Windows 7 Home Premium 64-bit
Nereus
  • Ribbons : 25
Re:EVGA Power Boost! 2010/12/22 16:50:11 (permalink)
waveskimmer9431
     Well, Jacob closed the other thread and stated that they sent out 75 free mods and they're not doing any more than that.  Well I'm done with EVGA for good.  EVGA will get my $20.00 for my personal power mod, and I'll order a few others for my clients.  Unlike EVGA, I will support my clients AND NOT charge them for the mods; I'll absorb the cost.
     I will never again purchase another EVGA product again unless forced to because of stock shortage.
     I wish all of you on the forum the best of luck in the future.  For those of you that provided me support---Merry Christmas.   For those of you that offered counterpoints (including "fanboys")---Merry Christmas.
     For EVGA---May you find lumps of coal in your stockings; boneheads!!
Shelby
Your prerogative bro, but I think you said yourself that EVGA make the best quality components, so you're not really doing yourself or your clients any favors by refusing to use EVGA branded components in future because of an issue that has relatively negligible cost to fix, and has only effected a fraction of a percent of boards. Also there's the fact that EVGA are the only company to have actually done anything at all about this issue..so feel free to jump to one of the manufacturers who have done nothing at all. This isn't "fanboy" speak, this is just fact.
Best wishes to you and your business.
Nereus
  • Ribbons : 25
Re:EVGA Power Boost! 2010/12/22 16:52:00 (permalink)
Modboxx
Nope. The 770 already has a molex plug built in at the bottom below the PCI slots..
KMoore4318
Pistoj Doulos Unum Pluribus
  • Ribbons : 233
Re:EVGA Power Boost! 2010/12/22 16:52:44 (permalink)
Modboxx
Your fine You dont need power Boost plug.
Modboxx
Re:EVGA Power Boost! 2010/12/22 16:53:19 (permalink)
Nereus
Modboxx
Thanks
jjkz24
Re:EVGA Power Boost! 2010/12/22 16:55:49 (permalink)
Modboxx
Great combination!  I also have 3 570's and the E770 mobo.  You will be o.k.
-Jason
Moltenlava
  • Ribbons : 28
Re:EVGA Power Boost! 2010/12/22 16:57:13 (permalink)
KMoore4318
Modboxx
What would happen if you accidentally touched the naked metal parts connecting the molex connector to the board when it was on? anyone know?
jjkz24
Re:EVGA Power Boost! 2010/12/22 17:02:12 (permalink)
Moltenlava
KMoore4318
Modboxx
As far as getting "shocked"?  Nothing.  It's 12v, DC supply so nothing would happen.  However, that being said, it's never a good idea to be working on your mobo, with "live" juice going to it.
-Jason
Moltenlava
  • Ribbons : 28
Re:EVGA Power Boost! 2010/12/22 17:06:31 (permalink)
jjkz24
Moltenlava
KMoore4318
Modboxx
yeah your right, sometimes I am lazy though, just wanted to make sure nothing too adverse would happen.  That said there is not really anything around that area that you would need to tinker with.
BioHazardSperm
EGC Admin
  • Ribbons : 25
Re:EVGA Power Boost! 2010/12/22 17:10:48 (permalink)
For those who have had a 790I Ultra :
With the known Vdroop on this mobo would i benifit from this with my Current Corsair Hx1000 and 480's in SLI(Oc'ed or not same issue) ?
My PSU at idle (GPU's downclocked atm) is showing
+12 - 11.88
+5  -  4.87
I know it dips lower underload .My  qx9770 is @ 4.0 and im runnning 8 gigs of DDR3 @ 1600 L/S
I do have random complete system lockups ,none of them get fully recorded in Eventlogs so im guessing its a power stability issue .Would this benefit me or is it cut and dry i need to move on to a 1200W PSU ?
I am  >>NOT< <   a  EVGA Forums Moderator or a EVGA.com  Employee.
I am only a  "Game Server Admin"
My posts and are my own and not EVGA's.
Steam  Heatware   EVGAWeb_ShaneD: BHS knows our terms better than some of our support agents
EVGAWeb_ShaneD  we don't care, we do what we want! (out of context but funny )
Sum1uNo83
  • Ribbons : 12
Re:EVGA Power Boost! 2010/12/22 17:17:23 (permalink)
my +12v was 11.98 before powerboost stable no up and down. with powr boost i see now 12.04 stable no up and down.
dont know if this will help your situtation but will provided better stable volts for the +12v (fact)
shdbcamping
Re:EVGA Power Boost! 2010/12/22 17:48:27 (permalink)
jjkz24
Watching this, it reminds me of a plate of cookies getting taken away from a bunch of whiney 1st graders.
Wahhh.  I have to spend $20 on my $8K rig.....wahhhhh.
Someone saw you coming. Next time go with a reputable retailer like NewEgg, then you won't be BS'd into spending $8K on system with one of these boards as the base. Wow, what a maroon as Bugs would say.
shdbcamping
Re:EVGA Power Boost! 2010/12/22 17:52:23 (permalink)
BioHazardSperm
its been said before,its not EVGA fault this even needs to be a part ,the fact they took the time and effort to even make it is lets see ...100% more then ANY other vendor has done .Why should EVGA be punished and expected to offer this FREE to everyone who wants one when no one else even bothered to address the issue ?Kind of a double standard to hold the company who stepped up and offered a fix responsible to provide it for free,while expecting and demanding nothing from the others who still sit idle doing nothing and offering nothing  isnt it ?
I guess if one hears a rumor 3 times it makes it a fact. Blah Blah blah. "Quit picking on EVGA" wah wah wah.
Sum1uNo83
  • Ribbons : 12
Re:EVGA Power Boost! 2010/12/22 17:58:30 (permalink)
EVGA is a company like everyone else. if this issue had been know it would have solved long ago. the company has made a solution for the issues and you can bet all highend motherboards will have the molex connector now imo. Put high end gpus in any motherboard such as the 400/500 series and the same issue occurs, some sooner than other. the GPU manufactures are pushing the limits imo and now the motherboard manufatures will need to adjust. faulty mother board imo no, just cant handle the load that was unknown at the time.
shdbcamping
Re:EVGA Power Boost! 2010/12/22 18:03:05 (permalink)
EVGA_JacobF
Like has been said from day one.
If the issue occurs we will either give you a new motherboard that has the fix, or a power boost.
To date this issue is extremely rare, only a few confirmed cases.
So I guess you're willing to sit back as EVGA and allow the forum Cronies to keep this up instead of having anything official from EVGA??????
Pathetic!  What a role model for New Corporate strategy?
Sean
EDIT: please link me to that information to back up that claim, as I have been following this and have no recollection of any such EVGA statement. Not calling you a liar, just saying that I think you are embibing a bit much so far before Christmas. There have been posts stating contrary to the "we'll work with you" junk claims as well.
post edited by shdbcamping - 2010/12/22 18:08:09
jjkz24
Re:EVGA Power Boost! 2010/12/22 18:03:58 (permalink)
shdbcamping
jjkz24
I, for one, did not spend 8K on my rig, nor do I plan to do so.  And, NewEgg & TigerDirect are my retailers of choice...thanks.
-Jason
boomerman18
Re:EVGA Power Boost! 2010/12/22 18:06:51 (permalink)
WILL THIS WORK with crossfire 5850s on an evga board? x58 tri sli to be exact.
Charlie sheen if he was a robot
jjkz24
Re:EVGA Power Boost! 2010/12/22 18:07:01 (permalink)
shdbcamping
EVGA_JacobF
Sean
...waiting for the pom-pom's to come out.
-Jason
ZachA
  • Ribbons : 29
Re:EVGA Power Boost! 2010/12/22 18:13:16 (permalink)
firerx
ZachA
If anyone is really mad enough why not just go on to Nvidia fourms and complain to the people who actually caused the problem?? EVGA is a medium we use to get NVIDIA products, so if theres a design flaw with the hardware itself then 99.99% of the time it will be the people who designed the reference boards and GPUs ie. NVIDIA/AMD.
I dont know how many of you really have read the technical white sheets, but you will never find a molex 4pin power connecter to stablize or increase the 12v on any standard design feature from NVIDIAor AMD. So why would EVGA even think to add one?
Now with the cases of EVGA creating there own PCB boards like the E-762 / SR-2 and P55 equal they knew that they would be stressing the 24pin 12v and then added the molex connecter to counter this.
But now after all this disorganized mess were dealing with it will hopefully become standard pratice by NVIDIA/AMD in there refernce designs... This is why NVIDIA/AMD should be made aware of the problem/design flaw they have created by STRAYING AWAY FROM POWER STANDARDS AND LIMITATIONS OF A HARDWARE POWER DRAW.(refreing to the fact that the 24pin when it was first designed was never ment to power multiple high wattage using GPUs)
As far as the power boost is considered, it should be handed out for free for user that are "AT RISK" (2+ 200series GPUs or newer).
For everyone else, as of right now it sucks but $20 with free shipping is a drop in the bucket for something that was never intended to be needed or made by anyone. So if you dont like the price ask or better yet tell NVIDIA/AMD to compinsate you for there screw up. So consider yourself lucky EVGA spent the time and money to CREATE a fix for there Parent companies shortfalls, I garentee you EVGA will never be compinsated by NVIDIA for there work/effort.
Edit: change ATI to AMD, since ATI is now just AMD
I was with ya, til you tried to convince me that the E-759 Classified is a reference board. Wasn't marketed  that way.
I over looked that board on accident, the boards I listed were just examples of what THEY DID add the molex connecter to
Sum1uNo83
  • Ribbons : 12
Re:EVGA Power Boost! 2010/12/22 18:14:04 (permalink)
you guys need to understand this subject is very sensitive and required alot of research before anyone can say anything official. they have offered a fix weather member like it or not, weather free or pay you still got one. jacob is correct and there are few case of this happening and its not affecting everyone, so to find an exact cause when the variables are to far different from each other is hard to do, thus comming up with a 100% answer for anyone. imo its safe to say there were no issues when the same mb's in question on the forums here with the 200 series gpus. now the 400/500 there is with the same motherboards in some fashion.
shdbcamping
Re:EVGA Power Boost! 2010/12/22 18:14:46 (permalink)
jrmitchell1983
And EVGA is "in-bed" with them as a partner. I don't care about any other MFGR. WE BOUGHT EVGA. Are you saying it's a good thing that EVGA will Lower itself to a mediocre MFGR's level???? what kind of argument is that?????  I've got a used car to sell you too, just driven back and forth to church by a 90 year old lady>>>>>lololololololol.
Pathetic and ignorant excuses...
5thduke
Re:EVGA Power Boost! 2010/12/22 18:15:14 (permalink)
i have to say something here, i have never won anything from evga im not eligible for step ups i pay more for the name as i live in Oceania. they sent me that little booster, i live on the other side of the world i got it in 3 days  it was not sent by post in an envelope but by friggen fast courier it was pure luck that i was picked im sorry for everyone that missed out but its not personal its just the way they do things.
post edited by 5thduke - 2010/12/22 18:24:34
never attempt to remove a fly from your friends head with a meat cleaver .
ZachA
  • Ribbons : 29
Re:EVGA Power Boost! 2010/12/22 18:20:49 (permalink)
boomerman18
Yes, the power boost is a none sofware item that soly increases stable power on the 12v PCB lines throughtout the board, it does not care what you have in your computer or who makes it, its just a universal power mod.
Sum1uNo83
  • Ribbons : 12
Re:EVGA Power Boost! 2010/12/22 18:23:32 (permalink)
shdbcamping
jrmitchell1983
EVGA is doing what they can imo to accomidate user of there motherboards imo. i agree it would be nice if evga replaced every motherboard without the molex, but instead of replacing them the better solution is to fix them with the powerboost. this issue was unknow at the time the motherboards were manufactured so of course they could not do anything. now the issue has appeared and the fix was created. just becuase on company replaces motherboards, does not mean everyone should. each company handles there issues differently. im not say its a good thing or bad for them to decide to make a fix instead of a motherboard replacement. this issue will be argued for sometime with people who are grateful just to have a fix and people who think otherwise and want somethig different to make them happy.
btw- you wise crack are not welcome
5thduke
Re:EVGA Power Boost! 2010/12/22 18:41:18 (permalink)
not to be personal here falcon but why did you buy an sr2 if your so into asus please dont flame me its just a question
waveskimmer9431
Re:EVGA Power Boost! 2010/12/22 18:49:10 (permalink)
shdbcamping:
Be nice now, or the EVGA gremlins, moderators, or forum moderators/powers at be (i.e. Jacob) might shut this thread down to for "verbal abuse" of one of their "chosen ones."  Remember, EVGA's satraps are well protected and even get first shot at special promotions/give aways for their allegiance.
Shelby
Silverstone Raven RV02B-W case
EVGA E760 Classified
Intel i7 960 @ 3.4MHz
Tunia Tower 120 Extreme CPU Cooler
Corsair XMS3 6GB Triple Channel
EVGA GTX 770 Classified 4GB SLI Configuration
Corsair TX950w 79a 12v single rail
Asus Blu-ray player
Asus DVD/CD RW
Seagate Barracuda 7200.12 1TB 32mb cache primary
Creative X-Fi Professional
Dell 2707 widescreen monitor
Klipsch THX 475w 5.1 Ultra--175w sub/dual 8" woofers
Logitech G15 keyboard
Turtle Beach 5.1 headphones
Enstranged
Re:EVGA Power Boost! 2010/12/22 18:53:59 (permalink)
While I admit I have seen a few names on giveaways far more than my own, I really cannot complain with the service EVGA has given me over the past few years.
4770k - Asus Z87 Gene - Evga GTX580 - Corsair H100i - Corsair 8gb kit 2133mhz dominators - Corsair AX850w PSU
