Re:EVGA Power Boost!
2011/03/03 18:08:09
Hi giadartis. To answer you. Yes it is safe to install even if you only have one card. It will not harm or overvolt your pci slots,i am using it with just one card and have had no ploblems.
My specs. Case-Corsair 800D full tower~LG Bluray Burner. Processor-Intel I7-3770K @4.2GHZ~Lighton Bluray Burner. Motherboard-ASUS P8z77-v Deluxe Memory-G.SKILL Ripjaws x 32GB. DDR3 1600 Dual Channel. GPU-EVGA GTX-TITAN SC x2 in SLI Water cooled EK full XXL blocks. Power Supply-Corsair AX1200 Gold. 1 OCZ VERTEX 4 512GB SSD Boot Drive.1 Crucial M4 128GB SSD cache for Hitachi 2TB storage drive. 1 WD Caviar Black 1-TB. 7200RPM Hard Drive. Intel RTS2011LC Liquid cooling Solution for cpu. Sound Blaster Zx soundcard. Win.7 64BIT Professional.(Now playing with Win 8.1 to see how i like it.)
KMoore4318
Pistoj Doulos Unum Pluribus
- Ribbons : 233
2011/03/03 18:14:49
You do not need it with a single 260, But I would want one with a single 480/580, or a high power draw ATI card, all it does is provide a secondary path, for voltage, But electronic devices only take what they need. Since Voltage, resistance and curent respond to each other, E=I/R
Just clink Link to Register > My Affiliate Code:VTJPDC4OMB 1)965 V-8 E758(77)580 AX1200 2)980 NH-U12P-SE E761(77)2(980) AX1200 3)980X H-70 E770 (77)2(590) AX1200 4)980X H-70 E762(77)2(580) AX1200 5)920 EVGA Super Cooler E756(82)590 HX1000 6)680I 2(560-ti) HX1000W
2011/03/03 18:22:31
Thanks Enigma. @KMoore: Well im currious to see if will help stabilize my card more during overclocking because of something that just happened to me while gaming in the Crysis 2 multiplayer demo. My overclocked card reverted to idle mode clocks 4min in to gameplay. Now i run my overclocked card through OC scanner which said i had no artifacts. Also between crysis warhead and BFBC2 i have had no issues running it for hours at those OC settings. But when i play the demo in the factory clock settings, i dont have any problems. So im wondering why and if my psu is not doing the job properly, im wondering if this will help stop that annoying occurrence, because the older cards before fermi used to use a lot of power from the pci-e slots.
Core i7 6700k @4.6ghzEVGA Z170 Classified K MotherboardEVGA GTX980ti SC ACX 2.0+ w/ EVGA BACKPLATE Corsair H80i v2 (push, pull fan setup)Crucial MX100 512gig SSD Gskill TRIDENTZ 2x8gig DDR4 3600 Ram OCZ ZX 850watt Modular Gold CertifiedCoolermaster MasterCase Pro5ASUS 27inch LED Backlit Monitor (1920x 1080) DELL 23inch LED Backlit Monitor (1920x 1080) __________________________________________________________ MY EVGA Affiliate Code: CKDW370PVK
KMoore4318
- Ribbons : 233
2011/03/03 18:35:07
According to Nvidia the max power a 260 will draw at stock is 182W, I suspect even overclocked you wouldn' t see a demand more than 200. where as the Max Power draw on a 480 is 250 watts, Stock,and we all know that was a under exagerated Lie. I suspect your issue is going to be a driver patch, or update issue, and not a power draw related issue. I would not be suprised if Nvidia, had not been able to prepair for a demo game yet, and may not have it resolved before release.
2011/03/03 18:49:08
alright thanks alot. I will have to buy one anyway now because my friend who has GTX470's in SLI asked me to send him one and he is in germany for another 7months on an exchange program. thanks again. PS. props to your folding setup
2011/03/10 07:06:13
Wow EVGA you are awesome !!! I ordered yesterday at 4pm the EVGA Power BOOST from the EU EVGA webpage. And today, what was in the mail !! The EVGA Power BOOST !! That was fast EVGA... That is the reason, why i have only EVGA stuff !!!
Thank you EVGA u are the best...
markistheone
2011/03/10 16:51:18
So I just got my Power Boost and all I can say is WOW, more than what I expected. The box was big enough for 3 full size video cards and weighed almost as my 295. I opened this box to see a tone of shipping peanuts covering another slightly smaller box. SO...... I get in that box and find a bubble ESD bag, OK. I then go in to that bag and FINALLY get to the Power Boost. Which had its own little packaging. I am just in absolute awe at how much shipping went in to protecting a wire thats 5 inches long, a Molex connecter and a small one inch PCB. Not to diss the company that I LOVE for computer parts but WOW I Would have rather had a 2 foot long wire on this than all that packaging.
EVGA X79 DARK Motherboard, Intel 3930K Kingston KHX24C11T3K4/16X, 3x GTX 480 Corsair AX1200, Corsair 800D Case.
2011/03/10 17:11:58
Hehe.. yeah it was amusing opening the layers for me as well, but hey, it's better to overdo it than to have insufficient packaging.
Knud
2011/03/15 08:20:21
Main rig: CM ATCS 840 | X58 Classified | i7 @ 3.8 Ghz | Ever changing GFX card HTPC: Silverstone LC12 | Mini-ITX 780G m/b | AMD Athlon 2x 4450e LAN Party rig: CM 690 | P35 m/b | QX6850 @ 3.3 Ghz | GTX 460 | Antec H20 620
raycboyd@gmail.com
2011/03/31 18:03:56
I agree
big_willie
2011/04/07 12:54:07
Big box wasted on this tiny cord But it saved me from having to RMA
chuntergb
2011/05/27 03:16:00
is this needed on an sli le ?
loveha
- Ribbons : 53
2011/05/27 05:23:30
chuntergb is this needed on an sli le ? Only needed if you are running a System that is overclocked with high end SLI Video Cards. GTX470/570 SLI and up are the biggest causes for concern. If you are just running one card you should have no reason to concern your self. I have SLI 470's and not to worried about a melt down. I plan to pick one up eventually, just no hurry...
Case: Corsair 900DMotherboard: EVGA Z170 Classified E179CPU: Intel Core i7 6700K 4.6GHzRAM: 16GB Corsair DDR4 2133 16-15-15-36GPU: EVGA GTX 1070 FTW DT SLIPSU: EVGA 1000w G2SSD: Samsung 512GB 950 Pro NVME M.2Monitor: Acer Predator X34 100Hz G-SyncSound: Schiit Modi 2 DAC~Schiit Vali 2 AmpHeadphones: AKG K7XX Massdrop Edition
KMoore4318
- Ribbons : 233
2011/05/27 05:24:12
chuntergb
I would if that le was running two 480's, but wouldn't if I were running two 460's hard to answer with the information you provided.
chuntergb
2011/05/27 06:11:58
well i'll be putting 2 480's in soon so will probably pick one up then.cheers
siffert
2011/12/15 22:27:13
Got my Power Boost yesterday for my 780i FTW. Got a SLI 285 GTX setup and tried to put in on that small white slot behind the 3rd PCI 16 green slot where #2 GTX sits and it was underneath it (though not touching it). Installed correctly but my my Dell XPS 630i would not power on. Got scared for my mobo (whew-booted up without it after taking it out) and was thinking of getting rid of it but took a chance and put it on the empty #2 PCI 16 slot. Voila it worked and booted up! I have an Antec HPC 1200 watt PSU which was running at +12v 12.09 volts and boosted it up to 12.18 volts. Not much difference (though it does work!) but since it is almost impossible to find another of the discontinued 780i FTW mobo's, I suppose it is worth the insurance for the $9.95 I paid for it here.
post edited by siffert - 2011/12/16 00:21:13
_MatthewH
2011/12/15 22:47:17
Ta1k0n dakon I ordered one to give it a try as I think it is a unique product. Now for the problem. Why oh why, would this ship out signature required when the signature required box was not checked? I can only imagine that the shipping costs more than the product itself. This should of just gone via USPS. I have had more problems with shipping errors over the years with EVGA than any other company I have ever dealt with. Once again, can we get this fixed so I do not have to drive 45 minutes to pick up a 20 buck item... +1 This has been changed, that goes for RMA's as well.
2011/12/16 08:25:53
Oh hello Jacob hmm 75 ok later everyone.
Affiliate Code:H4NN05P25X
slash-2cpu
2012/01/16 20:50:55
I bought one of these out of curiosity. I have an Asus P9X79 Pro with 2 EVGA GTX 560 TI's in SLI at stock clocks and volts. CPU is an 8-core extra-special with a 150W TDP and a 9.5% OC for 3286MHz. It draws 530-560W at the wall when running Folding@Home with -smp 16 and 2 GPU clients. It has no additional power connectors besides the 24-pin and the 8-pin 12V. I was concerned about just how much was being pulled through the motherboard's power connectors. I bought an 8-pin extension to plug into my PC Power&Cooling Silencer 910W's extra 8-pin connector. I spliced 2 pairs of the 8-pin to the EVGA Power Boost and the other 2 pairs to the 12V molex to power my DD CPX-Pro pump. With a multimeter wired in parallel on the 12V line on the Power Boost, I get 0.27A at idle, and 0.88A when running Folding@Home. When running Left4Dead2 maxed out, load varies between 0.40-0.93A. Same meter measuring the ground leads sees similar numbers, maybe 0.05A lower. Makes sense given that there are more ground pins on the motherboard's power connector than 12V pins. Motherboard's sensors under load used to read 12.000V. Now I get 12.096-12.192V. No gain in any clocks. Still stable as before.
xarot
2012/03/13 02:39:03
Hi guys, I built a second computer with Rampage III Black Edition mobo, but the case and PSU blocks my molex cable that I could attach to the mobo at the bottom. Question: Even that the mobo already has the molex connector which I now cannot use, could I solve this issue by simply using EVGA Power Boost? I already have one at home, never used it?
Core i7 Extreme 5960X, Alphacool XP3 waterblock Asus Rampage V Extreme 16 GB G.Skill Ripjaws4 2133 EVGA GTX Titan X SLI, EK-FC Titan X waterblocks Custom Water Cooling with 360+480 radiators + D5 pump Phanteks Enthoo Primo Corsair AX1200 Corsair Force GT 180 GB Asus Xonar Essence One Win 8.1
KMoore4318
- Ribbons : 233
2012/03/13 03:22:22
2012/03/13 03:51:48
ummm i would call ASUS and let them decide as i dont see a PCI slot giving the same power to the mobo as a 4/6 pin connector .Maybe im wrong ,but until someone explained how it would work exactly i would be highly doubtful risking it.
KMoore4318
- Ribbons : 233
2012/03/13 04:27:18
The Molex connector simpley connects 12V to that part of the board, to the traces that connect to the PCIe slot through the card, the power boost just connects it to the pins insted of the board, you get the same results namley a second source, regardless of which you use. The power boost is you molex connector if you bord doesn't have one, ( or if you cannot use the one it has) There is a third option outlined in a thread here http://forums.evga.com/tm.aspx?m=749507&high=PCIe+power+mod that tells you how to modify your board and connect a molex directley to the board, but that would void your warranty. If you go this route, Make sure you isolate conections to prevent shorts, either with electrical tape, sleving, or Nonconductive glue. http://forums.evga.com/tm.aspx?m=749507&high=PCIe+power+mod
post edited by KMoore4318 - 2012/03/13 05:43:22
xarot
2012/03/13 05:40:57
Thanks guys! So I think it should be all good to use the Power Boost. However I attached a picture to describe the situation (sorry if I borrowed someone's picture, quick googling result). So I already got a molex connector on board but it's unusable since there's no way I could fit a molex cable between the PSU and the mobo's molex connector. That's why I'd like to use the power boost on this board.
2012/03/22 23:20:32
So when I bring up everest it shows my 12v at 11.67v if I use cpuid hardware monitor it shows 0.90 to 1.15v,So I was wondering if the power boost would fix this? I have a new coolermaster 800w silent gold psu,I also got these reading with my old psu and I thought a new psu would fix them but nope :) I have a older system which is a Q9450@3.7Ghz 8GB gskill ripjawsX 1600 ram 1.5v 7-7-7-22-2t a gtx460@820Mhz and a evga gts 250 physX card plus 64Gb SSD for OS and a 500&320Gb wd HDD's for games and junk all on a Gigabyte EP45t-DS3R, SO what do you all think would this help me get a 12v reading ? Also as a side note I have a second psu installed that just runs two coolit eliminators that cool my cpu and soon to run a third eliminator to cool a gtx 275 that I want to add as a phsX/folding card to replace the gts250, no sli as it is a cfx board only:( but can I run the power boot off the second psu? Thanks in advance for any help
KMoore4318
- Ribbons : 233
2012/03/23 04:08:32
My 12V readings Before and after Power Boost : Before: After : ATX acceptable Standards:
topgun0254
2012/03/25 22:00:31
what do we think of the power boost with one evga gtx680? i had one in use with my evga 570 SLI and am curious if there is any use to keep it installed?
ASUS DIRECT CU II GTX680 TOP + MSI GTX680 TWIN FROZR III OC IN SLI... UNIQUE CHOICE FOR SLI I KNOW (EVGA GTX680 vanilla in roommates' comp at the moment) i7-2600k @ 4.8 asus p8p67 ws revolution 8gb gskill 2133 MHz thermaltake gt lvl 10 corsair h80 OCZ 120GB SSD
KMoore4318
- Ribbons : 233
2012/03/26 00:18:20
Well The burnt Power plug issue has been seen on SLI 280,295,480, and 580; The 280 had a max draw of 236 Watts , the 295 draw was 289 Watts max, the 480 max wasn't listed and the 580 was 244 Watts Max the 680 lists max at 195 Watts , So I would guess that you are not going to need it, but there is no down side to having it, All your doing is providing another source for 12V and a system will NOT pull more power than it needs. The power boost does NOT detract from bandwdth, or drop a PCI lane from 16X to 8X, If it were me, I would NOT buy one to put with a 680, BUt I would not stop using one if I had one either,
post edited by KMoore4318 - 2012/03/26 00:20:19
voodoo do-er
- Ribbons : 9
2012/03/26 00:25:18
quick ? dose this help with oc;ing? like can it help with getting an oc stable?
KMoore4318
- Ribbons : 233
2012/03/26 00:28:30
voodoo do-er
No ; All the Powerboost does is Provide a second source of 12V to the PCIe lanes, so they do NOT have to draw all their power from two yellow wires on your 24 pin Power plug, or from the plugs on the cards. AS long as your card is not asking for more than youe system can provide your fine, With that being said, I have no idea what a Overclocked 680 will ask for, and the more amps you run through a wire, or conection, the hoter it will be. ( E in volts, Times I in amps will equal Power in watts. ) E*I=P
post edited by KMoore4318 - 2012/03/26 00:33:32
