Hot!EVGA LED Controller 1.2.1 - Now Supports EVGA Pro SLI Bridge!
EVGA_JacobF
EVGA Product Manager
  • Ribbons : 22
2013/09/23 14:24:24 (permalink)
Please note this tool only supports the "reference" style GTX 780/TITAN cooler and/or EVGA Pro SLI Bridges.
Version v1.2.1
Release: 9/23/13
  • Adds support to control EVGA Pro SLI Bridges - Important note: NVIDIA Driver 327.23 Required
The EVGA LED Controller application is available now! You can download it here.
Here is a brief overview on how it works. When I start the application I will see the below:
The first selector at the top left lets me select the card logo and/or SLI Bridge I want to adjust. In the example above, I have selected to control the EVGA Pro SLI Bridge that is connecting my GTX TITAN's. The selection directly below that lets me select various different options. IMPORTANT NOTE: Anything other than manual control REQUIRES EVGA Precision X to be running in the background! For FPS Monitoring make sure that you have FPS monitoring enabled in EVGA Precision X.
Lets select GPU Utilization. When EVGA Precision X is also running in the background (or minimized to system tray) the LED on my EVGA GTX TITAN, 780, 690 or Pro SLI Bridge will automatically adjust based on the GPU Utilization. In the below image I am running EVGA OC Scanner X to increase my GPU utilization to 94%, thus the illumination on my EVGA GTX TITAN is set accordingly. When I close EVGA OC Scanner X, the LED turns off.
Lastly, the apply at startup will ensure that my custom LED settings will always apply on Windows boot!
post edited by EVGATech_MattM - 2014/08/07 23:32:05
   jfreeZr - [rebuilding]  4770k @ 5.2ghz || evga z87 classified || 2x evga gtx 980 acx2 || 16gb 2.6ghz ddr3 || 500gb 840 evo raid0 || evga supernova 1000 P2
   hadronGTX - 4770k @ 4.4ghz || evga z9 stinger || evga gtx780 ti acx || 16GB 2.6ghz ddr3 || 480gb vertex3 raid0 || 500w gold
56 Replies Related Threads
    notfordman
    • Ribbons : 14
    Re: EVGA LED Controller 1.2.1 - Now Supports EVGA Pro SLI Bridge! 2013/09/23 14:34:30 (permalink)
    Awesome Jacob!  Does this tool still require user to have a 780/Titan? Or does this allow for user defined adjustment with only the SLI bridge? You guys are always innovating things!
    EVGA_JacobF
    • Ribbons : 22
    Re: EVGA LED Controller 1.2.1 - Now Supports EVGA Pro SLI Bridge! 2013/09/23 14:38:20 (permalink)
    It will work with any cards that allow the SLI Bridge to illuminate.
    EVGA_JacobF
    • Ribbons : 22
    Re: EVGA LED Controller 1.2.1 - Now Supports EVGA Pro SLI Bridge! 2013/09/23 14:50:36 (permalink)
    Also I want to mention, for the SLI Bridge LED adjustment, driver version 327.23 is required.
    TheProfosist
    Re: EVGA LED Controller 1.2.1 - Now Supports EVGA Pro SLI Bridge! 2013/09/23 15:35:28 (permalink)
    Great update, now if I just had a card that would illuminate the SLI bridge.
    mpoffo
    Re: EVGA LED Controller 1.2.1 - Now Supports EVGA Pro SLI Bridge! 2013/09/23 19:34:33 (permalink)
    It works as advertised.  At least with the SLI bridge as an option makes it is a bit easier to tell which graphics card you are selecting.   Jacob any way to add a number or something to the cards in the list to differentiate them from each other?
    post edited by mpoffo - 2013/09/24 19:22:58
    X79 System:
    Windows 10 Pro 64-bit | Intel Core i7 3930K (4.3 GHz)| ASUS Rampage IV Extreme | 32 GB 2133 G.SKILL Ripjaws Z Series
    Corsair 900D | Corsair AX 1200i PSU | Corsair H110 CPU Cooler (in Push/Pull) | EVGA GTX 1080 8 GB in SLI (x2)
    Samsung 840 PRO 256 GB | Samsung 850 EVO 500 GB | Intel 520 SATA SSD 240GB HD | 2 TB WD Black Hard Drive
    Creative Sound Blaster Z | Logitech THX 5.1 speaker setup | LG Blu-ray burner | Corsair AF 120 and 140 Fans
    2 x Samsung SyncMaster PX2370 | Samsung SyncMaster XL2370 | Nvidia 2D Surround Set-up
    GTXJackBauer
    • Ribbons : 10
    Re: EVGA LED Controller 1.2.1 - Now Supports EVGA Pro SLI Bridge! 2013/09/26 16:17:01 (permalink)
    My GTX 780 Classified Hydro Copper LED and EVGA LED SLI Bridge stay lit when using this software.  Could it be because I am using an older system?  i7-950, intel x58so
    I followed the directions exactly and nothing is happening.  I don't know what else to do.
    EVGA_JacobF
    • Ribbons : 22
    Re: EVGA LED Controller 1.2.1 - Now Supports EVGA Pro SLI Bridge! 2013/09/27 13:46:59 (permalink)
    mpoffo
    Yes will try to add in next release.
    mpoffo
    Re: EVGA LED Controller 1.2.1 - Now Supports EVGA Pro SLI Bridge! 2013/09/27 18:19:59 (permalink)
    Thanks Jacob.  I think it will help some in SLI since it is hard to tell what card you have selected.
    X79 System:
    pathfindercod
    Re: EVGA LED Controller 1.2.1 - Now Supports EVGA Pro SLI Bridge! 2013/10/03 19:38:54 (permalink)
    Does this tool allow you to control the bridge on 780 classifieds? Also does it work with the latest beta driver that was just released for BF4?
    post edited by pathfindercod - 2013/10/03 19:58:26
    DT:CaseLabs Mercury s8, Intel 4960X, 3 x EVGA K|NGP|N GTX780TI gpu's, 32gb Corsair Dominator GT, Asus Rampage IV Black Edition, full on EKWB water cooling, 2 x 512gb 840 Pro Raid 0, 2 x 3tb Seagate spindles, Corsair AX1500i PSU
    NB: AW m18x r2 3940x, 780m sli, 32gb HyperX, 2 x 480gb Intel 730 Raid 0 (Red)
    NB: AW m18x r2 3920x, 780m sli, 16gb Ripjaw, 2 x 240gb Intel 730 Raid 0
    NB: AW m15x 920xm, 980m, 16gb G.Skill, 512gb Criucial mx100
    NB: AW m11x r3 2637m, 540m 2gb, 8gb ram, 256gb Toshiba Pro SSD
    17" MBP, 13" MBA, !984 Mac Classic (works), Amiga 500, Amiga 2000HD
    mpoffo
    Re: EVGA LED Controller 1.2.1 - Now Supports EVGA Pro SLI Bridge! 2013/10/04 21:36:39 (permalink)
    Not sure about the 780 classifieds but I can tell you that the program does work with the latest beta that was released for BF4 (331.40).
    X79 System:
    dakon
    Re: EVGA LED Controller 1.2.1 - Now Supports EVGA Pro SLI Bridge! 2013/10/04 21:43:56 (permalink)
    LOL.
    I am now fighting with this app.
    I simply installed and have no custom options running.  Hell I just opened it to see what it was.
    However when my computer boots, the SLI LED turns off.
    post edited by dakon - 2013/10/06 13:58:38
    4770k @ 4.4 w/ Phoybia HeGrease
    Corsair Hydro Series H110
    Asus Maximus VI Hero
    Samsung 840 Pro 256gb x2
    Samsung 850 Evo 500gb
    Titan XP
    Asus Xonar Essence STX
    Corsair Dominator Platinum DDR3 2400 C10
    Corsair Air 540
    Corsair ax1200
    Deck Francium Pro 87 Key Brown Switch
    Beyerdynamics DT 770 Pro
    Asus ROG Gladius
    ASUS ROG SWIFT PG348Q
    2x Asus VX229H
    _Nite_
    • Ribbons : 46
    Re: EVGA LED Controller 1.2.1 - Now Supports EVGA Pro SLI Bridge! 2013/10/04 21:55:32 (permalink)
    dakon
    LOL.
    EVGA, like the bios on your prevous MB, pls do fault, error, and fail based testing.
    do you have 327.23 or later installed? he said above thats required to work.
    GTXJackBauer
    • Ribbons : 10
    Re: EVGA LED Controller 1.2.1 - Now Supports EVGA Pro SLI Bridge! 2013/10/06 05:11:48 (permalink)
    I still haven't had this program to work not just the SLI Bridge but for my 780 Classified Hydro Copper.  You would think it would work but would like to hear from EVGA for verification.
    michaelcollins
    Re: EVGA LED Controller 1.2.1 - Now Supports EVGA Pro SLI Bridge! 2013/10/06 09:18:33 (permalink)
    Awesome...  Thank you EVGA
    Folding System: E760 X58 Classified w/I7-920 @3.2oc 12gbs ram 2-EVGA 570
    Game System:   Z68 FTW w/I7-2600 @4.0oc 16gbs Ram 2-EVGA 770 and 1-EVGA 640 (3 monitors) Creative 3D Recon
    MarcSR2
    Re: EVGA LED Controller 1.2.1 - Now Supports EVGA Pro SLI Bridge! 2013/10/07 07:47:19 (permalink)
    hello
    Awesome...
    EVGA SR2
    2X 5650
    SLI GTX 680 SC
    Enermax Platimax 1500W
    SSD Samsung 830 256Go raid zero
    Dell U3014
    ZelmoQuad
    Re: EVGA LED Controller 1.2.1 - Now Supports EVGA Pro SLI Bridge! 2013/10/11 14:45:31 (permalink)
    Mine fired right up (327.23 installed). But ... this app does not control the led color. I expected Green LEDs.
    Was hoping this app would allow for changing color to match schemes much like the Antec920 does. Why would EVGA choose Blue LED's? Guess green just an NVidia thing. These are slick bling items.
    HAF X Nvidia-ASUS IV Formula/i7 3930K/C-M Nepton 280L/MZ-75E1T0B-AM/16G Corsair Dominator GT  2133C9/2way-Titan SLI/CM SPM2 1500W on 3x LG 24" Surround.
    HAF XM- ASUS Maximus-V Gene/3770K/Kuhler 920/Samsung MZ-7TE500BW, 500GB/8G Corsair Rampage 1600 XMP/GTX295/CM Silent Pro Gold 800W
    Stryker -Wht - ASUS Rampage V Extreme USB 3.1/i7 5930K  OC'd to 4.4MHz/C-M Glacier 240L/  16GB EVGA 16G-D4-2800-MR/EVGA Titan-Z/Samsung MZ-7TE500BW, 500GB/C-M V1000 1000W/G510 Keyboard & Nostromo/MadCatz MMO 7/Windows 7 Pro and 10 Pro  64-bit
    shadow84
    Re: EVGA LED Controller 1.2.1 - Now Supports EVGA Pro SLI Bridge! 2013/10/16 04:55:10 (permalink)
     I'm running on nvidia driver 331.40, evga precision X v4.2.1 and evga led controller v1.2. It lighted up when i put onto my Gigabyte GTX 770 2GB WF 3x OC. But when i ran the led controller with precision x running in background, it gave me the following message: This device is not supported!
    Is it due to the brand or due to it not detecting a second car in SLI?
    post edited by shadow84 - 2013/10/16 07:28:35
    fstauss
    Re: EVGA LED Controller 1.2.1 - Now Supports EVGA Pro SLI Bridge! 2013/10/21 16:36:07 (permalink)
    I ordered a bridge today.  Just to clarify... do I need the driver version Jacob specifically listed, or can I use a newer version?
    _REAPER_
    Re: EVGA LED Controller 1.2.1 - Now Supports EVGA Pro SLI Bridge! 2013/10/26 04:49:18 (permalink)
    Will this work on the EVGA TITAN HydroCopper?
    GTXJackBauer
    • Ribbons : 10
    Re: EVGA LED Controller 1.2.1 - Now Supports EVGA Pro SLI Bridge! 2013/10/31 14:03:09 (permalink)
    My Pro Connector and Evga Hydro Copper from the 780 Classified light up.  Everything is lit up but not doing any effect I choose from the listing even though it recognizes the GPU.
    Is this only for reference 780s?
    sourtimes9
    Re: EVGA LED Controller 1.2.1 - Now Supports EVGA Pro SLI Bridge! 2013/11/10 15:07:14 (permalink)
    Is this software getting an update ?  It's sorely in need of one as in its current incarnation it is buggy.
    - It loads at startup and resides in the tray, but if you open it there are only two buttons for minimize and close, minimize leaves it in the taskbar after you open it and there is no way to get it back in the tray.
    - More importantly; settings can be applied and work, but when choose you 'apply at startup', it seems to only make the program load at startup and sit in the tray but the LED settings are not applying.  This leaves you to have to open it to apply them every reboot.
    This is on 780 Classified HC SLI and the issues are with the SLI bridge lighting.
    Please get us an update.
    wrinvert
    R.I.P Friend
    • Ribbons : 17
    Re: EVGA LED Controller 1.2.1 - Now Supports EVGA Pro SLI Bridge! 2013/11/12 07:07:13 (permalink)
    the illuminations range needs to be lowered some for the sli bridges, 100-20 seems to all be the same brightness and from 19-0 does the dimming. 780 classy hydro blocks don't breath at all.
    Jacob fix us something :-)
    #23
    xboxexpert
    Re: EVGA LED Controller 1.2.1 - Now Supports EVGA Pro SLI Bridge! 2013/11/12 19:34:20 (permalink)
    I've used this software to create ground fx lighting on my case.   I soldered directly to the 12v lines for LED's and wired them to two 12v light strips and have control over the led's via the software.   It works wonderful.   I would like for you to add a option if its not too much to ask.    Strobe effect.  I'd like to cycle between 0 and 100% and enable the slider to control the strobe speed.   If this is possible it would look amazing.  Attached are pictures of the software working.   Strobe effect would just put it over the top for me.
    I cant post the youtube video but its watch?v=9RZBR1BNvIo
     Attachments are not available: Download requirements not met
    Operating System Microsoft Windows 7 Ultimate
    OS Service Pack Service Pack 1
    Motherboard
    CPU Type HexaCore Intel Core i7-4930K, 3600 MHz (36 x 100)
    Motherboard Name Asus Rampage IV Gene  (1 PCI-E x4, 3 PCI-E x16, 4 DDR3 DIMM, Audio, Gigabit LAN)
    Motherboard Chipset Intel Patsburg X79, Intel Ivy Bridge-E
    System Memory 32711 MB  (DDR3-1333 DDR3 SDRAM)
    DIMM-A1: Corsair Vengeance CMZ32GX3M4X1866C10 8 GB DDR3-1333 DDR3 SDRAM  (9-9-9-24 @ 666 MHz)  (7-7-7-20 @ 533 MHz)  (6-6-6-17 @ 457 MHz)
    DIMM-B1: Corsair Vengeance CMZ32GX3M4X1866C10 8 GB DDR3-1333 DDR3 SDRAM  (9-9-9-24 @ 666 MHz)  (7-7-7-20 @ 533 MHz)  (6-6-6-17 @ 457 MHz)
    DIMM-C1: Corsair Vengeance CMZ32GX3M4X1866C10 8 GB DDR3-1333 DDR3 SDRAM  (9-9-9-24 @ 666 MHz)  (7-7-7-20 @ 533 MHz)  (6-6-6-17 @ 457 MHz)
    DIMM-D1: Corsair Vengeance CMZ32GX3M4X1866C10 8 GB DDR3-1333 DDR3 SDRAM  (9-9-9-24 @ 666 MHz)  (7-7-7-20 @ 533 MHz)  (6-6-6-17 @ 457 MHz)
    BIOS Type AMI (08/29/2013)
    Display
    Video Adapter NVIDIA GeForce GTX 690  (2 GB)
    3D Accelerator nVIDIA GeForce GTX 690
    Monitor Asus VE248  [24" LCD]  (D4LMQS010281)
    Monitor Asus VE248  [24" LCD]  (B8LMQS013597)
    Monitor Asus VE248  [24" LCD]  (B8LMQS013606)
    Monitor Asus VE248  [24" LCD]  (B8LMQS013607)
    Storage
    Disk Drive Samsung SSD 840 PRO Series ATA Device  (SATA-III)
    Disk Drive ST3000DM001-1CH166 ATA Device  (3000 GB, 7200 RPM, SATA-III)
    Optical Drive ATAPI iHAS124   W ATA Device  (DVD+R9:8x, DVD-R9:8x, DVD+RW:24x/8x, DVD-RW:24x/6x, DVD-RAM:12x, DVD-ROM:16x, CD:48x/32x/48x DVD+RW/DVD-RW/DVD-RAM)
    Temperatures
    Motherboard 38 °C  (100 °F)
    CPU 24 °C  (75 °F)
    CPU Package 37 °C  (99 °F)
    CPU #1 / Core #1 30 °C  (86 °F)
    CPU #1 / Core #2 32 °C  (90 °F)
    CPU #1 / Core #3 27 °C  (81 °F)
    CPU #1 / Core #4 28 °C  (82 °F)
    CPU #1 / Core #5 31 °C  (88 °F)
    CPU #1 / Core #6 27 °C  (81 °F)
    PCH 43 °C  (109 °F)
    GPU1: GPU Diode 27 °C  (81 °F)
    GPU2: GPU Diode 26 °C  (79 °F)
    Samsung SSD 840 PRO Series 28 °C  (82 °F)
    ST3000DM001-1CH166 (Z1F2SF4Y) 31 °C  (88 °F)
    ST3000DM001-1CH166 (Z1F12G75) 31 °C  (88 °F)
    Attachment(s)
    #24
    kell0w
    Re: EVGA LED Controller 1.2.1 - Now Supports EVGA Pro SLI Bridge! 2013/12/03 14:18:38 (permalink)
    for some reason the download link doesnt work
    edit: had to refresh a few times for it to download. also it works great
    post edited by kell0w - 2013/12/03 14:42:13
    #25
    scirlos
    Re: EVGA LED Controller 1.2.1 - Now Supports EVGA Pro SLI Bridge! 2014/01/02 16:19:50 (permalink)
    works great on my 980sc cards
    post edited by scirlos - 2015/02/06 18:23:55
    #26
    RDKing2
    Re: EVGA LED Controller 1.2.1 - Now Supports EVGA Pro SLI Bridge! 2014/01/02 20:49:37 (permalink)
    Not sure if others noticed, this seems to be integrated into GeForce Experience now.  I don't care to use the effects so I do not know how it works.
    #27
    Q5Grafx
    Re: EVGA LED Controller 1.2.1 - Now Supports EVGA Pro SLI Bridge! 2014/01/25 16:59:36 (permalink)
    in GeForce Experience I get the bridge to light up and stay lit but no effects. I am assuming that since my 780 sc ACX cards have no leds that this is why the bridge only lights up but no effects.
    #28
    shadowboricua
    Re: EVGA LED Controller 1.2.1 - Now Supports EVGA Pro SLI Bridge! 2014/02/09 10:41:33 (permalink)
    Q5Grafx
    Is this true? Do the effects work with the ACX cards or not?
    Follow me on: http://www.twitch.tv/shadowboricua
    [font="verdana, arial, helvetica, sans-serif; font-size: 10px; line-height: 2"]
    #29
    Scarlet-Tech
    • Ribbons : 31
    Re: EVGA LED Controller 1.2.1 - Now Supports EVGA Pro SLI Bridge! 2014/02/09 11:44:56 (permalink)
    shadowboricua
    Q5Grafxin GeForce Experience I get the bridge to light up and stay lit but no effects. I am assuming that since my 780 sc ACX cards have no leds that this is why the bridge only lights up but no effects.
    ACX cards do not have controllable leds. Only the reference Cards with NVidia on the side.
    #30
